Old 14th September 2007, 15:10   #141  |  Link
The Scientist
The Scientist's Avatar
I've just tried: http://www.clonead.co.uk/ worked fine.
The Scientist is offline   Reply With Quote
Old 14th September 2007, 15:21   #142  |  Link
weaver4
Just tried it again. I get an error.
What is the IP address? Could be DNS entry problem.
Also tried www.dvduk.pwp.blueyonder.co.uk and it did not work either.
I am in the US, east coast.
weaver4 is offline   Reply With Quote
Old 14th September 2007, 20:27   #143  |  Link
weaver4
The link is now working again.
BTW: I think it was a DNS problem not a server problem because my local DNS server could not resolve the IP address.
Old 15th September 2007, 19:00   #144  |  Link
The Scientist
I forgot about index.NET when I changed some paths for avi.NET thus index.NET will not work with the v2.5.6.0 (14th Sep). Fixed version re-uploaded, sorry.
Use v2.5.6.0 (15th Sep).
Old 14th October 2007, 22:23   #145  |  Link
fana
Hello!
First of all, thank you for the great program and support.
I installed the latest version (15th september) and avi.net keeps crashing. It happens after indexing, just when the message "Loading Movie" appears. The program is then closed without any notice.
I then downloaded your support pack and installed everything. Same error. Tried with another DVD and nothing, both from the direct source and the pgc.net file.
The older version worked just fine.
These are my specs:
Windows Vista 32bits Ultimate
Xvid 1.1.3
Vobsub 2.2.3
Avisyth 2.5.7
avi.net 2.5.6.0 (15th september)
Pentium IV 3.0
1024 RAM
I had it working fine with version 2.5.1.0
Hope you can help me figuring this one out.
fana is offline   Reply With Quote
Old 22nd October 2007, 12:16   #146  |  Link
J-Wo
Hi Scientist! I just started to use your great program for my DivX encodes and had a couple questions:
1) Which quantization matrix is used for DivX? I rather like the H263 Optimized matrix but I'm not sure which one the program uses
2) Can I manually edit the AVS file before the encode? I'm converting a tv show (Dexter S1) and avi.net (as does DGIndex) detects the material as 29.9fps interlaced. However a simple telecide/decimate will produce 23.976fps progressive frames. With avi.net my only choices are to leave the material interlaced or deinterlace and encode as 29.9fps progressive
3) Is it possible to select a "no resize" option? I encode my dvds at 720x480 with 16:9 NTSC pixal aspect ratio, which is the highest resolution that my standalone player will accept. It recognizes the PAR flag and plays the files at the correct aspect ratio. Which brings me to my next question
4) Can I select the PAR that the program uses to encode? Currently it uses 1:1 square PAR, and I can modify the output with MPEG4 Modifier after the fact. But it would be nice if I could select this option through the program outright.
5) Just wondering how avi.NET is handling the 2nd pass of DivX encodes. When I do my encodes manually with VirtualDub, the 1st pass (fast mode) takes 15 min and the 2nd pass usually 30 mins. However with avi.NET both passes are done in 15 mins! I'm impressed and just curious as to what's going on in the background.
6) I would like an option for the preview window to not autoplay after loading the source file. I'm constantly right clicking and hitting pause immediately because I don't want to be spoiled by episodes I'm encoding that I haven't seen yet!
Thanks again for a great program, and I hope I'm not asking too many questions on my first post in this thread.
J-Wo is offline   Reply With Quote
Old 31st October 2007, 02:48   #147  |  Link
J-Wo
Just wanted to bump this thread.. Hoping someon can respond, thanks.
Old 31st October 2007, 21:04   #148  |  Link
avdw
Banned
Hehehe,
I just installed this avi.NET tool, did my first encode to Xvid size 700 MB, width 560x256...... ended up with a horrible 250MB encoded file. This tool is a joke
avdw is offline   Reply With Quote
Old 31st October 2007, 21:37   #149  |  Link
J-Wo
avdw: you must install the XviD version that comes with the program (it's available in a seperate support file). Here's a link
http://www.dvduk.pwp.blueyonder.co.u...vi.SUPPORT.zip
Old 1st November 2007, 00:03   #150  |  Link
avdw
Banned
Aaaah, much better. Thanks J-Wo !
Old 1st November 2007, 14:18   #151  |  Link
avdw
Banned
Just one more Q, why does avi.NET add so much junk to the avi file ?
Old 1st November 2007, 18:13   #152  |  Link
The Scientist
It doesn't.... DivXNetworks DivXMux does.
Old 2nd November 2007, 11:07   #153  |  Link
avdw
Banned
Thanks Scientist, just three more questions ...
1) How come none of my encoded (to Xvid .AVI) DVD's play on my standalone ?
They all show weird coloured contours.
Is there an option I have to (un)check to make the encoded AVI compatible with standalone players ?
2) Also, how come converted movies show bigger black borders on TV than original ?
3) GSpot shows a min quantizer of "1" for every encoding, is it possible to change this into "2" which would allow much better overall quality per compression ?
Thanks a lot in advance !
Old 3rd November 2007, 02:08   #154  |  Link
J-Wo
Scientist:
Is there a way to select which quantization matrix is used for either XviD or DivX?
Old 3rd November 2007, 03:00   #155  |  Link
The Scientist
Try it without "HQ" selected and as for problem number 2 it's most probably because you have a crap standalone, check your settings, if it's a dodgy ESS based player they have a habit of playing in extra-skinney vision.
Old 3rd November 2007, 12:30   #156  |  Link
avdw
Banned
Thanks the scientist,
I pretty much gave up on Auto Gording Knot, since whatever Xvid codec was installed, it keeps on spewing out completely undersized encodings and it aint even able to remember default advanced settings I always choose. On the other hand, your tool really looks promising, is there any option to encode the audio in 112kb/s instead of 128kb/s ? I didn't find it in the current version.
Just to add, I'm currently in an episode of filling my free days encoding DVD's using multiple tools (AGK, AutoMKV, FairUse Wizard 2 & Avi.net) and whatever options I choose, or even out of the box encoding, I can only conclude something that sounds impossible, but it seems even true : avi.NET not only is the fastest of them all, it also produces the best results. That can only be done by a truly great author who actually KNOWS what he is doing.
Once again, thanks a lot !
Old 4th November 2007, 17:34   #157  |  Link
avdw
Banned
Sorry, can I just ask a few more questions ?
Your answers can make a lot clear and hopefully get more people to use this tool since, however you do it, it's great !
Q1) Is there any option to encode the audio in 112kb/s instead of 128kb/s ? I didn't find it in the current version.
Q2) I have a DVD movie which starts with some text displayed on a black background, I guess this is the reason why avi.NET thinks the upper&lower black borders are bigger than they actually are.
When converting to Xvid (700MB) with a chosen with of 480, it resized to 480 x 208, correct me if I'm wrong, but I think the height of 208 is too low, hence the poor quality of the encoded AVI.
So, Is there any change to make avi.NET guess by looking for borders not from the start of the movie, but say for a certain frame-range ?
Thanks in advance for this nice tool !
Old 15th November 2007, 00:01   #158  |  Link
avdw
Banned
The avi.NET project is abandoned, disregard previous posts.
Old 15th November 2007, 12:58   #159  |  Link
digidragon
digidragon's Avatar
Do you mean that your project is abandoned, or the avi.NET project?
digidragon is offline   Reply With Quote
Old 9th December 2007, 04:57   #160  |  Link
s3rious
s3rious's Avatar
can anybody confirm whether the avi.NET project is abandoned or not ?
s3rious is offline   Reply With Quote
