17th August 2010, 16:17 | #4201 | Link |
With madVR 0.27 , the FS and Window mode switching works a lot faster than it under 0.26. It is especially very obvious on my machine under WinXP x64 + 7300GT.
With 0.26, I got random Win7 frozen with some video clips under pausing. They are not easily to be duplicated. Hope such issue will never happen to 0.27 again. For one particular AVI file encoded with MPEG4 (704x544 25fps) + AC-3 (448Kbps 4ch), if it is played with MPC-HC + Xvid 1.2 decoder + ACM decoder + madVR 0.26/0.27 at 1400x1050 60Hz monitor, the video is frozen and displayed around 10 seconds later. If the video rednerer is changed to VMR9 , it works fine. Very weird... Maybe it is due to different muxing method, which makes madVR AV sync mechanism does not quickly response? Here is the media info. It is related to Violin Concerto , Mutter, Karajan , 1990 ... Format : AVI Format/Info : Audio Video Interleave File size : 954 MiB Duration : 50mn 23s Overall bit rate : 2 646 Kbps Writing application : VirtualDubMod 1.5.4.1 (build 2178/release) Writing library : VirtualDubMod build 2178/release Video ID : 0 Format : MPEG-4 Visual Format profile : Simple@L3 Format settings, BVOP : Yes Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Custom Codec ID : XVID Codec ID/Hint : XviD Duration : 50mn 23s Bit rate : 2 191 Kbps Width : 704 pixels Height : 544 pixels Display aspect ratio : 1.294 Frame rate : 25.000 fps Resolution : 8 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.229 Stream size : 790 MiB (83%) Writing library : XviD 0.0.09 (UTC 2003-03-25) Audio ID : 1 Format : AC-3 Format/Info : Audio Coding 3 Format_Settings_ModeExtension : CM (complete main) Codec ID : 2000 Duration : 50mn 22s Bit rate mode : Constant Bit rate : 448 Kbps Channel(s) : 4 channels Channel positions : Front: L R, Side: L R Sampling rate : 48.0 KHz Stream size : 161 MiB (17%) Alignment : Split accross interleaves Interleave, duration : 80 ms (2.00 video frames) Interleave, preload duration : 500 ms Last edited by pie1394; 17th August 2010 at 16:22. |
17th August 2010, 23:10 | #4202 | Link |
Madshi I have a few debug Logs I can send on if useful showing some periods of frame drops at the start of movies. This evening I watched Hannibal and at the end of the movie I had just 1 delayed frame but 179 frame drops most of which were noticeable. The log was almost 2gb though so I'll just send on the smaller ones.
18th August 2010, 00:03 | #4204 | Link |
maybe. But 2 gig file in 2 hours when. My hdd can write 2g in 17 seconds doesn't really add up to "busy". I doubt that causes such a slowdown in hdd reads to cause frame drops. The log is being written to c drive anyways and movie was on f drive. CPU usage is in low 2-3 percent even on max hdd reads.
18th August 2010, 01:52 | #4205 | Link | |
Another problem: Whenever I go to the MadVR properties to change a setting (i.e. Exclusive mode), the properties window is so long that I can't even hit the apply/ok button, even when I minimize my taskbar @ 1024 X 768. I have to temporarily raise the monitor resolution just so I can see the apply/ok button. Just to be sure, does the full-screen exclusive mode only enable better playback performance? Or, does it improve image quality also thanks, madshi |
18th August 2010, 03:38 | #4206 | Link |
Bugs/problems:
1. One of the following, depending on what your intentions were: a) When seekbar is enabled, but automatic exclusive mode is disabled, the seekbar is still enabled in "normal" fullscreen. b) The seekbar box is grayed out and can't be altered when auto-ex-mode is disabled. 2. You remember the shifted chroma plane issues with non-mod16 videos way back? I'm having those again when exiting exclusive mode. 3. Exiting exclusive mode is slow. Video will go black and pause for a second. 4. If you go from exclusive mode to windowed and then close the player, the screen will go black for a split second exactly when the player disappears from task manager. Win 7 x64 HD4850 MPC-HC madVR 0.27 Last edited by ajp_anton; 18th August 2010 at 03:50. |
18th August 2010, 03:49 | #4207 | Link |
Hi madshi excellent renderer, but is it possible to get exclusive mode to work on a secondary display?
I'm using mpc auto change, when i go full screen my second display stays blank while exclusive plays on my primary display. But when I put my mouse cursor on the second display it shows the video but says in window mode then goes blank after a couple seconds. I also can't get the madvr seekbar to show up. My spec: Ati 5850, windows 7 64-bit, ffdshow, coreavc. Thanks! |
18th August 2010, 04:00 | #4208 | Link | |
Spec: Intel Core i5-3570K, 8g ram, Intel HD4000, Samsung U28D590 4k monitor+1080p Projector, Windows 10. |
18th August 2010, 05:49 | #4210 | Link | |
3 eyed CRT supporter
With interlaced res's and powerstrip, you cannot use powerstrip to do the initial swap from a progressive res to an interlaced res. You must set the PC/graphics driver to "interlaced mode" by setting either the Windows graphics settings OR ATi CCC to a stock interlaced res first. After that is set, you can then tweak it in Powerstrip. If I try and set an interlaced res directly in Powerstrip, you get this weird effect where you only see the top half of the screen. I'm not sure it will affect what you are doing, it's just a quirk. Last edited by Mark_A_W; 18th August 2010 at 08:30. |
18th August 2010, 08:09 | #4211 | Link | |
18th August 2010, 08:14 | #4212 | Link | |||||||||||||
That's the way it is and I can't do anything about that, either. Or does this effect not occur when exiting the media player, after having used EVR fullscreen exclusive mode? |
18th August 2010, 08:37 | #4214 | Link | |
The thing is, sometimes the video is jumpy, but sometimes it looks perfect. Using High and Aero timings seems to lessen the effect when it occurs, but it is still there. |
18th August 2010, 12:42 | #4215 | Link | |
http://www.multiupload.com/75QNFST5AN Using MPC-HC's internal stuff for everything, no external splitters/decoders. Last edited by ajp_anton; 18th August 2010 at 12:46. |
18th August 2010, 12:55 | #4217 | Link | ||
18th August 2010, 16:41 | #4220 | Link |
Basic starter guide
Hi there
I might have missed the obvious while trawling through the 200 odd pages but could anyone point me to info on how to install madvr from scratch (using say...MPC-HC as the player)? i.e. Do I JUST need MPC-HC and MadVR. Or do I need more? I have the following setup: - a ASUS N71 laptop (which has a Core I7-720 M CPU and 1 GB ATI 5730) - I connect this with a HDMI v1.3c cable to a 50inch plasma (a Panasonic Viera NeoPDP S20, model no TX-P50S20B) - I have Catayst 10.6 installed on Windows 7 (64bit) - I had installed CCCP (Combined Community Codec Pack) and then installed MadVR. I then simply went into MPC-HC and changed output to MadVR - my TV allows me to choose 23hz as a refresh rate so I've chosen that (which i think means 23.976) - I've also read in the forums that its best to change the pixel format so I've changed from the default of "YCbCr 4:4:4" to "RGB 4:4:4: Pixel Format PC Standard (Full RGB)" I mainly watch 720p/1080p x264 movies on the TV. Only thing is i'm not sure if the above way is the ideal way to using MadVR? With the above setup the playback is still not smooth so I fear I might not be installing things in the most efficient manner or simply have it configured incorrectly. Appreciate any help....this thread btw is a great read! Oh and madshi, its impossible to go back to anything else now that I've seen madvr....thanks so much for your efforts thus far! Last edited by bulaboy; 18th August 2010 at 16:47. Reason: Forgot to thank madshi ! |
