3rd November 2007, 10:14 | #161 | Link |
HDConvertToX author
update to 2.9
added "change fps to 29.97" (need optimization, aka suggestion is more then welcom) varius optmization to code (automen.exe is 2kb less ! ) BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
3rd November 2007, 12:18 | #162 | Link |
Thanks buzzqw.
Did a small encode and change fps to 29.97 not working. Fps were still at 23.976. In the video resize slider if I pick a resolution of 352 with adding cropping of 16,72,16,72, I get a final resolution of 352x244. Is there a way to get a resolution 352 x480? Thanks David Last edited by Dkruskie; 3rd November 2007 at 12:43. |
3rd November 2007, 13:00 | #163 | Link |
Hi buzzqw!
I just love the way this little program develops :-) Is there a chance that you will include lame encoding to 44.1kHz? I am backing up a very old tv show that has an annoying very high pitched sound in almost all episodes. When i encode to Lame in 44.1Khz using AutoMKV, the annoying sound is gone. It would also be great if i could choose if i want to normalize the audio or not. Just some suggestions, keep up the great work! |
3rd November 2007, 14:46 | #164 | Link |
HDConvertToX author
Update to AutoMen 3.0
added possibility to enable/disable audio normalization added possibility to change ssrc. Attention ! lame bitrate is tied to particular sample rate value @Dkruskie what is the original ar ?... mencoder will automatically scale to correct aspect ratio you will need manual set of ar.. must wait another update about fps... check in mpeg2.bat is -ofps 30000/1001 is present.. also try with 3.0 version @DIEGO7-5 BHH
3rd November 2007, 14:57 | #165 | Link | |
3rd November 2007, 15:10 | #166 | Link |
HDConvertToX author
@Dkruskie
624/352=1.772 352/244=1.444 (yea.. the crop values...) BUT 352/480=0.733 so it is a problem of ar (and not only) your image will be "deformed" passing from 624/352 to 352/480 i can check in mencoder how to force ar.. but in this case .. are you sure of what doing ? BHH
3rd November 2007, 15:25 | #168 | Link |
HDConvertToX author
ok... now i have understud..
actually isn't possible.. maybe in a future update BHH
3rd November 2007, 15:55 | #169 | Link |
HDConvertToX author
@Dkruskie
try this build http://www.64k.it/andres/data/automen/AutoMen30a.exe in advanced settings is possible to specifu the height. Not setting it will bring an automatic resize by mencoder BHH
3rd November 2007, 19:52 | #170 | Link |
Thanks buzzqw.
After doing multiple tests, I concluded its better to let mencoder do the resizing when setting the width and cropping and change fps to 29.97 I can still set dvdlab pro to accept non dvd sizes so no worries here |
6th November 2007, 12:43 | #172 | Link |
HDConvertToX author
@dansus
no.. you can open the bat to check.. but i suppose that you ffed x264 with a avs.. and in avscould be present colormatrix.. or other color conversion ? BHH
9th November 2007, 19:36 | #173 | Link |
I really like automen, but there is one thing I wished it would do and that is to give me a status bar to let me know what it is really going to do something like.
Input - 1:36; Video - XviD - Single Pass Q = 3; Audio - mp3 - cbr 128kbs I find myself always wondering what it really is going to do when I say "Start" Thanks for the great program. |
9th November 2007, 20:59 | #174 | Link |
HDConvertToX author
i am working on
i hope a new build for tomorrow BHH
9th November 2007, 21:40 | #175 | Link |
As long as you are working on it I also noticed that my last video was:
Video: XVID 640x258 29.97fps [Video 0] Audio: MPEG Audio Layer 3 48000Hz stereo 128Kbps [Audio 1] Any chance you could do IVTC and get the framerate to 24? |
9th November 2007, 22:32 | #176 | Link |
HDConvertToX author
just select "Progressive NTSC" in deinterlace box
BHH
10th November 2007, 10:52 | #178 | Link |
HDConvertToX author
update to 3.1 link in first post
added: detect crop button added: preview crop added: multi track audio selection. If a file contain more then one audio track is possible to select wich one to encode added: preview (crop or the P button) now play the selected audio track added: status bar with encoding info BHH
10th November 2007, 12:33 | #179 | Link |
I think i have found a bug in crop module(preview); i have tested two mpeg files and result is the same: every value set in the "crop box" will ignored in preview box.
P.S. DVD Structure(for encode) is supported by AutoMen?
sorry for my bad english |
10th November 2007, 13:36 | #180 | Link |
buzzqw: Since I overlooked something so obvious yesterday I want to check to see if I was missing something else.
When I have a group of Linked Vob files I have been using VobMerge to make one large vob file out of it before I drop it on your application. Is there another (better) way? Thanks, |
automen, ffmpeg, handbrake, mencoder, x264 |
