26th November 2011, 17:24 | #7341 | Link |
Hi Nev would you possibly consider at some point adding a sharpening filter like swscaler? Tbh its the only reason i still use ffdshow raw filter, its the best sharpener i have have used to date.
26th November 2011, 17:31 | #7342 | Link |
Hello nev. Remember when you asked few months back what feature people would still need? I think most votes had the stereo downsampling request, since now you need to add ffdshow to the mix and most would like to get rid of it. Same goes for me. Just to remind you.
I can live like this, since you are a genious and made such a wonderful product for us to enjoy for free. I have used the trunk builds from the start and had no real problems and thats impressive. Keep up the great work! |
26th November 2011, 18:10 | #7343 | Link |
To remind you: http://code.google.com/p/lavfilters/issues/detail?id=11
26th November 2011, 20:00 | #7345 | Link |
AAC decoding with libavcodec has problems with some SBR and PS files. So I'd like to use libfaad2.
The werid thing is, that only in ADTS it does not work. In isomM4A it works perfectly. Last edited by BloodySword; 26th November 2011 at 20:03. |
26th November 2011, 20:25 | #7346 | Link |
ADTS has a special header so that you can switch channel count mid-stream, which is not supported otherwise. A clear short-coming of libfaad, imho.
Thats also the reason the header was not removed - because with it LAV Audio supports on-the-fly channel layout changes (which happen on live tv). Stupid ffdshow somehow accepted my special ADTS media type...
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 26th November 2011 at 20:28. |
26th November 2011, 22:02 | #7348 | Link | |
I fixed it, though.
26th November 2011, 22:43 | #7349 | Link |
LAV Filters 0.40 bug report (splitter in particular):
MKV[H.264+Vorbis] sample For some mysterious reason the LAV Splitter refuses to connect to FFDShow's Audio Decoder. The LAV Audio Decoder always kicks in. Just try this sample in MONOGRAM GraphStudio and manually add FFDShow's Audio Decoder. The LAV Splitter and FFDShow's Audio Decoder don't seem to agree with each other.
My hobby website |
26th November 2011, 23:01 | #7350 | Link |
Found another problem: When I have a MKV file with WAVEPack audio in hybrid mode (lossy) with 96KHz 32 bit float, the WAVEPack decoder messes eveything up, the renderer tries to render it with 16 bit, the playback is 50% slow, is distorted and the video is stuttering. When I think of it, I can not realize what goes wrong here. When I play the WAVEPack file alone, everything works fine.
26th November 2011, 23:03 | #7351 | Link | |
27th November 2011, 02:21 | #7352 | Link | |
C:\>dir "c:\Program Files (x86)\LAV Filters\dts*.*" /sAny guess on what might be wrong with my setup? |
27th November 2011, 05:15 | #7353 | Link |
Otaku
subtitles with undetermined language will not be displayed by default unless a "und" 3-letter code is added to the subtitle option in the splitter.
Cheers!
In the school, the three guys met. Their relation had been changed in the season, and turned into three love stories.
27th November 2011, 08:15 | #7354 | Link |
Thats how its supposed to work.
27th November 2011, 11:03 | #7355 | Link | |
This MKV[H.264+Vorbis] sample is the exception. I have a lot more MKV-files where the LAV Splitter connects to FFDShow's Audio Decoder effortlessly. I just can't figure it out.
My hobby website |
27th November 2011, 12:11 | #7356 | Link |
Bitsream DTS-HD and not DTS?
Hi, I am new to LAV and previously used ffdshow. Loving the rules-based subtitle functionality in LAV splitter.
I am tying to use audio decoder as follows: - if audio is DTS-HD, bitstream - if audio is DTS, do not bitstream I wish to use reclock to slow down my PAL DTS DVDs, hence need PCM out with DTS audio. How can I achieve this? The options in the audio decoder only permit DTS-HD to be bitstream if DTS is also bitstreamed. Using ATI5750 card with HDMI, Windows 7 32-bit and MPC-HC. |
27th November 2011, 13:35 | #7357 | Link | |
When I Demux it, the audio file plays normal with LAV Splitter and ffDSHOw, only in MKV it does not play sound at all. MKV is very buggy I think. I get problems with WAVEPack audio in 32 bit float. It plays as 16 bit signed integer and it sounds slow and distorted. Just use MP4 with AAC SBR+PS. Sounds not as good as vorbis, but it just works and it is standard. But I think as soon as LAV Splitter and the Audio and Video filters have the functionality I need wich is in ffDSHOW, I will remove ffDSHOW. I only need kernel deinterlacer and yadif for interlaced material, audio seems to be ok. Last edited by BloodySword; 27th November 2011 at 13:38. |
27th November 2011, 13:52 | #7359 | Link | |
MKV is a container, Containers cannot be "buggy". Its most likely just the muxer that produced something horrible, or the demuxer not reading it properly (or the format just being screwed up in general, like WavPack Hybrid, horrible idea of a format) MP4 is a even worse container, fwiw. Take a already horrible container based on QuickTime, and try to add some rather odd ideas an top, and then call it a ISO standard .. voila, MP4 PS: If you ever want something fixed, i need a sample of a failing file. Not with LAV Audio. DTS-HD is DTS, just with some extra data, separating the logic for the two would add quite some complexitiy for some rather obscure use-cases. I mean, if you want to use ReClock, just decode all audio.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 27th November 2011 at 14:02. |
27th November 2011, 14:14 | #7360 | Link |
To use binary XML for a container format is a very bad idea. It's just too complicated to deal with, I hate MKV and I always remux files with H264 and AAC to MP4, because it just works - and it just works on my Samsung Galaxy S, too. I got several problems with MKV, so I dropped it.
I did a draft for a simple but universal container format. If you are interested, write a PM. What is wrong with WAVEPack Hybrid? It sounds 10000x better than any psycho format like mp3, AAC and vorbis, because it does not touch the frequency spectrum. That's why I wanted to use this. The WAVEPack decoder in libavcodec is not usable, it is very buggy. Sometimes you can hear "ticks" and sometimes any channel gets muted. The original decoder filter of core codec does not work when demuxed from MKV. @PS: How can I cut an MKV to a piece of 3 seconds? Does MKVMerge support it? Last edited by BloodySword; 27th November 2011 at 14:28. |
