Old 10th October 2008, 16:02   #2641  |  Link
brogan
Hello,
I have been trying to re-encode a file & RipBot gets through the 1st pass but just hangs afterwards...it will just say: Pass 1...
and never start Pass 2...this has happened while trying to re-encode a file that's like 8.25 GB in size & I'm trying to shrink to 7.95GB in Blu-ray structure to fit on a DL DVD...the video is H.264 (1920x1080, 23.976 fps) & the audio is DTS (768 kbps)
I've tried a .mkv, .ts, .m2ts extensions of the same file w/the same result...the files play fine in VLC, Nero Showtime & WMPC...I've been using RipBot 1.10.7 on a Vista Ultimate 64-bit system & haven't had any problems w/similar files...does anyone have any ideas what could be the problem?? Thanks in advance...
brogan is offline   Reply With Quote
Old 10th October 2008, 22:21   #2642  |  Link
dvgeek
Hello Atak,
Can you please clarify if the program would benefit running on an SSE4 platform as compared to an SSE3 platform (Intel Q8200 / Intel Q6600)?
dvgeek is offline   Reply With Quote
Old 10th October 2008, 22:24   #2643  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Originally Posted by dvgeek View Post
Hello Atak,
Penryn is faster clock-for-clock at x264.
But if you're buying a new computer, wait for the Nehalem. My preview Nehalem box tells me that its awesome, but I can't give any numbers right now
Old 10th October 2008, 23:03   #2644  |  Link
nurbs
I am currently waiting for the Nehalem. Since you can't give any numbers can you maybe tell us if this anandtech preview gives us a good idea about the performance gains?
Old 10th October 2008, 23:17   #2645  |  Link
gav1577
gav1577's Avatar
There is a teaser review here http://www.anandtech.com/cpuchipsets...spx?i=3326&p=6
EDIT damn just realized its the same review above lol
gav1577 is offline   Reply With Quote
Old 10th October 2008, 23:18   #2646  |  Link
Dark Shikari
x264 developer
Yes, that looks about right. However, there will be many places for future optimizations, some of which I am working on right now
Old 11th October 2008, 05:01   #2647  |  Link
Ajax_Undone
I dont care so should you
Ajax_Undone's Avatar
Sweet I am going to buy me a new rig in about 6 months can't wait...
My Installer's ||
Ajax_Undone is offline   Reply With Quote
Old 11th October 2008, 08:32   #2648  |  Link
Paddy97
Originally Posted by Paddy97 View Post
Sorry to report that the Tvix bug is not resolved in the .8 version. Same symptom as the .7 version. One tvix with older firmware reboots and the one with never firmware stutters severly.
I am now running an encode at 24000 maxbitrate (edited the cmd files ) to see if the problem persists.
Sorry to say even with a lovered bitrate the tvixes can't handle the files. Looks like there is something else in the profile that messes with the tvix.
Paddy97 is offline   Reply With Quote
Old 11th October 2008, 14:52   #2649  |  Link
laserfan
Aging Video Hobbyist
x264 still crashes for me in Version .8. Using .5 successfully. I suspect something about my Pentium 4 perhaps, as Atak has/tests with a Quad core, but otherwise have tried & failed figure it out.
laserfan is offline   Reply With Quote
Old 11th October 2008, 19:44   #2650  |  Link
prettyboy85712
I have the same issue with my other system which is a P4 WinXP w/SP2. The only difference is I can run 1.10.6. Any version higher than .6 crashes immediately upon encoding.
My primary AMD based system has run every version without problem.
prettyboy85712 is offline   Reply With Quote
Old 11th October 2008, 21:18   #2651  |  Link
laserfan
Thanks pb, you have confirmed my suspicions (my P4 is WinXP w/SP3). I hope someone who understands x264 processing options can suggest a fix/workaround for this...?
Old 12th October 2008, 02:57   #2652  |  Link
mmmmdonut
Which Tvix model(s) are you using?
mmmmdonut is offline   Reply With Quote
Old 12th October 2008, 07:34   #2653  |  Link
Paddy97
I have two HD M-6500A. Both are v2 models ( the ones that tvix have updated with heatsinks and such ). I use one for my home cinema with a 108" screen and projector and one for my old fat TV.
One I keep at the last stable firmware ( home cinema ) and the one for the TV I keep up with the latest beta firmwares just to see if they work.
Old 12th October 2008, 08:01   #2654  |  Link
Paddy97
Last try with the .8 profiles. With these settings ( after reading another thread at doom9 about safe limits for limited hardware ) and truning of bpyramid. The problem persists with the tvix as a player.
BufferSize=14745
MaxBitrate=17500
I am using .6 version successfully but I have one Disney Bluray that this one do not handle successfully so I am very keen on finding the problem with the .7 and .8 releases.
Old 12th October 2008, 13:51   #2655  |  Link
boissy
dreamer
boissy's Avatar
tvix 7000 firmware update
I have the tvix 7000,
do you think the firmware update is nescessary .
NjB
boissy is offline   Reply With Quote
Old 12th October 2008, 18:18   #2656  |  Link
laserfan
I have found that my crashing problem is owing to Atak's using a build of x264 for core2 computers, and then specifically it doesn't like the --nal-hrd option. If I use a build optimized for my P4 computer (found in this post) then everything works!
EDIT: According to at least this post from Sharktooth and this post from LoRd_MuldeR using an x264 build made for core2 CPUs and above does not enhance speed and thus unnecessarily reduces compatibility.
Old 12th October 2008, 18:28   #2657  |  Link
brogan
If I have a 1920x800 file & just want to keep that resolution w/out stretching the video, is there a line I can add in .avs script to to just add the black bars (add borders)?
Some of the videos that I've converted have looked a little too stretched, it's a little distracting
Old 13th October 2008, 08:29   #2658  |  Link
juGGaKNot
juGGaKNot's Avatar
Near the "remaining time" box there should be a "elapsed time" box.
Or a log at the end with "total encoding time"
juGGaKNot is offline   Reply With Quote
Old 13th October 2008, 16:46   #2659  |  Link
bigggt
Posts: n/a
Has anyone had any luck using Ripbot for the Popcorn Hour.
I select the Level 4.0 profile and cq22 and the resulting file won't play, when i select it ,it just goes back to the menu
On a side note i have questions about the cq 22
i did Baby Mama with cq22 and resized to 720x384 and the file ended up being only 750mb with a bitrate of 700 , does this seem correct.
i also tried Transformers HD at 1280x720 (just cut a 20 second clip to test) and the result is bitrate of around 5000 but when played on 50" tv it does not look that good
Old 13th October 2008, 20:21   #2660  |  Link
weaver4
I use RipBot to make videos for my Popcorn Hour A-100. Never had a problem. I also use cq22. But I had been using the old 4.1 profile. Be sure to use the AAC-LC audio.
weaver4 is offline   Reply With Quote
