27th April 2007, 22:41 | #1101 | Link |
Turkey Machine
Yes, but just because it's enabled doesn't mean it's used. It says it'll use it if it's there, which it plainly isn't, and I have no idea what the inherent difference is between Intel's MMX and SSE, and AMD's 3DNow!
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld |
28th April 2007, 05:13 | #1104 | Link |
Angel of Night
Until recently the AMD processors were always optimized much better for 3dnow than for SSE/2, but they gained rough parity in later revisions of the K8. There were also a few things you could do better in 3dnow anyway, but they've been incorporated into the SSE monster set over the years.
28th April 2007, 06:58 | #1105 | Link | ||
ffdshow user
I''ll try to fix this bug. Quote:
SSE3 in xvidcore 1.2. SSSE3 in x264. SSE4(2) maybe it will be used in x264. Last edited by _xxl; 28th April 2007 at 07:01. |
28th April 2007, 10:06 | #1106 | Link |
Swallowed in the Sea
Best patch of the year...
Index: bin/clear.bat =================================================================== --- bin/clear.bat (revision 1125) +++ bin/clear.bat (working copy) @@ -1 +1 @@ -rm *.exe *.dll *.ilk *.ax *.vdf *.acm +del *.exe *.dll *.ilk *.ax *.vdf *.acm |
29th April 2007, 20:10 | #1108 | Link |
ffdshow/AviSynth wrangler
Here's yet another update of my AviSynth patch - sorry for the two-week delay caused mainly by my TFT monitor's backlight dying:
* Disable buffering when "Apply pulldown" is off and ahead and back buffers are set to 0 (i.e. the old AviSynth filter behaviour) * Use original timestamps when the number of frames isn't changed Patch (against rev. 1125) Download (pure MSVC 8/GCC 3.4.4 build with ICL9 kerneldeint/tomsmocomp DLLs) I'd consider this version feature-complete; all that's left is adding a help-file documenting the AviSynth filter settings and operation and, of course, priming the help button on the AviSynth page to bring it up - but I thought another release while I'm tackling that can't hurt... np: Hug - Tactic Without Practice (Heroes)
now playing: [artist] - [track] ([album]) |
29th April 2007, 23:06 | #1109 | Link |
I just wanted to thank you for your work on this, Leak, as I've been looking for a good on-the-fly IVTC solution to watching anime DVDs for a very long time now.
Your newest version however gives me a "System exception - Access Violation" error message whenever I add TDecimate() to the AviSynth script. I'm also wondering, is there any way to make the subtitles look better when decoding DVDs with ffdshow (libmpeg2.) As it is now they look terrible as the colour information is completely out of whack, for example: ffdshow/libmpeg2 (bad), nVidia decoder (good). Last edited by Piyoko; 29th April 2007 at 23:09. |
30th April 2007, 00:32 | #1110 | Link | |||
Same here... Quote:
EDIT: Hmmm... I just noticed a crash when I use one of AviSynth's resizing filters after TFM/TDecimate... that's strange. I'll investigate that further tomorrow; it's a bit late now... Quote:
np: Jimi Tenor & Kabu Kabu - Hermetic Man (Joystone)
now playing: [artist] - [track] ([album]) Last edited by Leak; 30th April 2007 at 00:45. |
30th April 2007, 07:14 | #1111 | Link | |
30th April 2007, 13:06 | #1112 | Link | |
Using your lastest version, I tried disabling buffering by unchecking "Apply pulldown" and seting ahead and back buffers to 0 but I get the same behavior as if buffering was on (slight stutter when the frame duration changes). I looked at the AviSynth OSD info and it still tells me I'm buffering ahead 1 (using the SeeSaw filter only). Should the AviSynth display look the same as if buffering were turned on when it is set to off? Thanks, jidelite |
30th April 2007, 15:01 | #1113 | Link | ||
LoadPlugin("C:\TIVTC\TIVTC.dll") TFM(order=1,mode=1,PP=0,chroma=false) TDecimate(mode=0,hybrid=0,chroma=false) |
30th April 2007, 15:31 | #1114 | Link | |
As far as the OSD is concerned - it only shows the values that would be neccessary for proper operation, but the filter itself will use the values you set in the config page. np: Pole - Like Rain (But Different) (Pole)
30th April 2007, 15:39 | #1115 | Link | |
I'll look into it. EDIT: Okay, I found the problem - TIVTC starts requesting frames in TFM or TDecimate (can't remember which) as soon as the filter is constructed, which I didn't really expect, so a few variables weren't initialized at that time that should have been. Of course, I really can't hand TFM/TDecimate a frame at that point (ffdshow didn't even produce one yet), but I guess simply handing it a blank frame is better than a crash... Oh yeah, Haruhiko - that most probably was where your green frames came from... I'm still hunting some other bug that messes up the last timestamp for static DVD menus if "Apply pulldown" is deactivated and causes the static image to not show up, but that should be it then. np: Burnt Friedman & Jaki Liebezeit - Wirklich (Secret Rhythms)
now playing: [artist] - [track] ([album]) Last edited by Leak; 30th April 2007 at 22:37. |
30th April 2007, 22:28 | #1116 | Link |
ffdshow user
Please test my new builds.
http://rapidshare.com/files/28939785...70430.rar.html I don't have a SSSE3 (Intel core2) cpu.I can't test if X264 is faster or not. Last edited by _xxl; 1st May 2007 at 18:55. |
1st May 2007, 08:10 | #1117 | Link | |
BTW when apply pulldown is deactivated in your patched version it behavies exactly the same as normal ffdshow, right? |
1st May 2007, 09:31 | #1118 | Link | ||
If the problem is that there's no highlights on static DVD menus, then that's something that needs to be fixed in the DVD subtitle part, probably by copying the last frame and overlaying the changed highlight on it - the problem is that during static DVD menus there's no new image being produced that a changed highlight could be overlaid on, which is what makes highlights work on animated menus. Quote:
1st May 2007, 12:09 | #1119 | Link |
When you mentioned it I tried and I have a lot of problems with dvd menus. First highlight doesn't show in animated menu, it shows after first button change. In static menus highlights don't show at all. And going back to menu from movie doesn't work, menu does not appear but works (I mean choosing button triggers correct action but it must be done blind).
I have ffdshow rev 1120 normal one. |
1st May 2007, 13:03 | #1120 | Link |
Otaku
@drevil_xxl
Used your rev1125 test build and GCC crashes as well on my Pentium D 930 and Windows XP. SSE3 does not get used on my system when selected on the options and cannot test SSSE3 because my system does not support it. EDIT SSE3 is working, MPC must be reopened for changes to take effect, reopening the video is not enough! EDIT/ Last edited by Kado; 1st May 2007 at 13:24. Reason: added some stuff |
