12th November 2007, 22:21 | #1642 | Link |
yeah..but i must correct me, the Remaining Time is still unstable
Example : 1080p x264 2pass takes 30h. But the Remaining Time after 5h encoding is only 3h , few hours later its 10h ...etc etc etc I can remember, in old Builds it was one static Value which was correct Remaining Time |
13th November 2007, 02:17 | #1643 | Link |
I find it hard to believe it ever gave an accurate prediction for the end of pass two while it was in pass one, but it could be more helpful than it currently is. ATM I assume it predicts based on percentage progress (treating each of n passes as 100/n percent) assuming a progress rate of the current average since start. Naturally with a fast first pass one gets low estimates during the first pass, which then steadily climb.
A better simple solution would be to assume a progress rate based on a moving window average - ie just use average speed for the last s seconds of encoding. As to a method that would give useful figures for final completion even during early stages, the only method I can conceive off would have to build up speed profiles for the various jobs. This could be done by logging average fps for each of the last j jobs, with these stats recorded for each pass (where applicable) of each defined profile (the stats might need to be wiped when a profile is edited). Initially when stats aren't available, it would have to fall back to the cruder method, but once you had a few runs in, it should give reasonable results. Edit: re wiping stats, a better automated heuristic might be: flag when a profile is edited & if measured fps deviates significantly from the logged average, wipe the stats log for that profile. Last edited by mroz; 13th November 2007 at 02:22. |
13th November 2007, 07:27 | #1644 | Link | |
Swallowed in the Sea
Maybe your CPU was busy by multiple tasks ? Last edited by Kurtnoise; 13th November 2007 at 07:29. |
13th November 2007, 17:33 | #1645 | Link |
I have a problem with megui: I installed and opened then i started to update megui with everything but when mencoder is completed I get and error also I reopened the program and tried to update another componet or external program I get the same error, I also have staxrip installed, this is the error:
13th November 2007, 18:06 | #1646 | Link |
I'm getting the same error message as you are with megui's auto updater. It just started yesterday with trying to update just the core. I'll just turn off auto updater till we get more feedback on this issue. |
13th November 2007, 18:26 | #1647 | Link |
Mr. Sandman
do a clean install AND before updating set the auto-update to development server.
it should fix things until the "stable" folder on the auto-update server will be updated.
15th November 2007, 00:14 | #1650 | Link |
I did that for one of the tools (the Avisynth analysis pass) and it was probably fine, but I since removed it when I simplified the code so that all the processors use the same time estimation code. I thought about a moving average, but I went for the current method because I'm lazy and the code without a moving window average looks nicer: no variables about the last update time. But that's just laziness. Please post this to the feature request tracker so that it doesn't get forgotten, and it will be seen to eventually.
15th November 2007, 10:05 | #1651 | Link | |
I'm getting this error when I try to open a D2V with the AVS Script Creator:
Any ideas what is wrong? MeGUI was working great until the new version came out. |
16th November 2007, 14:11 | #1655 | Link |
Mr. Sandman
i "closed" the report since doing a clean install fixes the problem.
ensure you remove everything related to megui (including the update_cache folder) and then install the latest version.
16th November 2007, 17:16 | #1656 | Link |
Dear Sharktooth, Clean install don't solve this problem, problem comes from the MediaInfoWrapper.dll in new version ,replacing it with old version solved this problem for me.
18th November 2007, 16:37 | #1658 | Link | ||
Hi
can you plz make MeGui doing 2-pass with Nero AAC because that what i have read in NeroAACEnc docs Quote:
18th November 2007, 16:42 | #1659 | Link |
clueless n00b
@knary: that has been brought up a long long time ago. If you look at how megui works, you'd realize why it wasn't possible then and it's not possible now.
19th November 2007, 10:09 | #1660 | Link | |
Mh... so far i can remember the Remaining Time was one static Value from encoding beginning on. And the Value was more or less correct In new Builds its sometimes 3h and later 30h again...it jumps around I use Threads=0 on my X2 Dual Core for x264 encoding But i dont think its a megui Problem I noticed the same on x264 cli |
megui |
