26th September 2017, 21:08 | #8423 | Link |
Priority Setting Issue - "Normal" vs "Above Normal"
In the settings, I have the "Default Priority" set to "Normal." However, when I run batches of files using One-Click and adding folders, the priority changes to "Above Normal" automatically at some point after several files have been processed. How do I get my setting of "Normal" to stick through all processing?
23rd October 2017, 22:29 | #8430 | Link | |
But need put the fps of video (unknow inside the chapter ogm file). Code:
Usage: ogm2cpf <int_fps> <OGM_file> fps 23 means 24000/1001, 29 30000/1001, ... ogm2cpf 23 ogm.txt
23rd October 2017, 22:42 | #8431 | Link |
Thanks for that!
I notice that compared to MeGUI's Chapter Creator, it writes the frame numbers followed by "I" instead of "K". But if I understand the docs correctly, this will be equivalent unless you're using Open-GOP in x264, which isn't enabled by default anyway. Is that correct? It also doesn't write a line for the zero frame, but that will necessarily be an I-frame anyway, so that doesn't matter. Assuming the I/K thing works either way as I suspect, this is perfect. Saves me the trouble of writing a perl script to parse the chapter file and do the frame arithmetic. Thanks! |
24th October 2017, 09:53 | #8433 | Link |
Damm! Yes, is a typo in the name than you can change, the file created is .qpf
About the I or K, I followed the format generated by BD3D2MK3D but is easy to change if you want K.
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 24th October 2017 at 09:57. |
12th November 2017, 22:37 | #8434 | Link |
This is a long thread but seems like the place to go for MEGUI questions.
I have been trying to learn it for a long time with various guides. How can I understand the Queue screen? I made what I thought was a good AVI Synth script. Then ran Auto Encode. On the Queue screen it says it's "waiting" for something. What is it waiting for? I should say that elsewhere I have made an AVI Synth script, loaded that and the video file into Virtual Dub. That involves an AVI conversion step which blows up into a huge file. For now, just say what the 'waiting' message is waiting for. Other note is I recently did the MeGui Update. |
16th November 2017, 19:31 | #8436 | Link |
Was the option to extract dts audio as ac3 removed from the HD Streams Extractor? Because if I switch back to the previous version of MeGUI (2715) it's there.
2715: 2774: I'm guessing those options were moved somewhere? Because the changelog says something about options being added, not removed. EDiT: Nevermind, lol, it took me to compare the two screenshots before I could spot the 'Settings' menu at the top. What an idiot. xD Last edited by iNViSiBiLiTY; 16th November 2017 at 19:36. |
18th November 2017, 23:59 | #8438 | Link |
avs4x26x.exe has stopped working
Lately I have been getting a number of errors encoding HEVC. The error is repeatable on certain files and reads "avs4x26x.exe has stopped working".
The Problem Signature is as follows: Problem signature: Problem Event Name: APPCRASH Application Name: avs4x26x.exe Application Version: 0.0.0.0 Application Timestamp: 02bbc7b0 Fault Module Name: LSMASHSource.dll Fault Module Version: 0.0.0.0 Fault Module Timestamp: 58af9c85 Exception Code: c0000005 Exception Offset: 000f1abd OS Version: 6.1.7601.2.1.0.256.48 Locale ID: 3081 Additional Information 1: 0a9e Additional Information 2: 0a9e372d3b4ad19135b953a78882e789 Additional Information 3: 0a9e Additional Information 4: 0a9e372d3b4ad19135b953a78882e789 Can anyone point me to a solution for this? TIA. |
megui |
