30th August 2009, 03:31 | #1902 | Link |
One thing I'm not clear on with regard to the video encoding options.
Under X264 options, I select - Encode using: X264 in MP4 Encoding mode: 2 pass I select Extreme quality on the slider I enter 8000 in "Manually Set Bitrate:" Does entering a bitrate over-ride any of the other settings? Should I choose a higher bitrate, or is there some other way of achieving as high a quality as possible? |
30th August 2009, 04:26 | #1903 | Link |
Practising Schemer
After deleting all HDC folder and settings, I reinstalled HDC and updated and now it is working again . The audio detection still shows as ?? Ac3 though but it processes so its a bit so what just seems strange for a common format file. Quick question is there anyway to import chapters from vob to use in encode?
Full Audio List-> (*** mean selected) NONE *** 80: ??? (AC3 2ch, 0xBD 0x80) [0] -> End Full Audio List Full Subtitle List-> (*** mean selected) *** NONE ??? 0 (0xBD 0x20) [0] -> End Full Subtitle List Code:
General Complete name : C:\Rip\Source Video\QOTSA\FullDisc\QOTSA_PAL\VIDEO_TS\VIDEO_TS.IFO Format : DVD Video Format profile : Menu File size : 12.0 KiB Video ID : 0xE0 Format : MPEG Video Format version : Version 2 Bit rate mode : Variable Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate : 25.000 fps Standard : PAL Audio Format : AC-3 Format/Info : Audio Coding 3 Channel(s) : 2 channels Sampling rate : 48.0 KHz Text Format : RLE Format/Info : Run-length encoding Resolution : 2 bits Last edited by flebber; 30th August 2009 at 13:44. Reason: added |
30th August 2009, 15:56 | #1904 | Link |
The ??? means, I think, that its unable to determine what language the track is in.
Whipdancer: for 2 pass, I think you enter what file size you want the movie to be, then it determines the highest VBR to achieve that filesize. I think you want to leave the manual bit rate field blank. |
30th August 2009, 16:05 | #1905 | Link | |
30th August 2009, 16:49 | #1906 | Link | |
I mean HDC rar file. Code:
D:\My DVB\NEW\HDConvertToX_1.8.332.2935\job0>"D:\My DVB\NEW\HDConvertToX_1.8.332 .2935\applications\HDC_Deint.exe" -input "c:\dvb\smartdvb\records\viva polska200 90626-05_23_22.mpg" -workpath "D:\My DVB\NEW\HDConvertToX_1.8.332.2935\job0\" -u sedecoder dss -here "D:\My DVB\NEW\HDConvertToX_1.8.332.2935\" D:\My DVB\NEW\HDConvertToX_1.8.332.2935\job0>"D:\My DVB\NEW\HDConvertToX_1.8.332 .2935\applications\x264.exe" --threads 0 --bitrate 200 --thread-input --trellis 0 --no-cabac --merange 4 --subme 1 --no-chroma-me --partitions none --me dia --s ar 1:1 --progress --no-psnr --output "D:\My DVB\NEW\HDConvertToX_1.8.332.2935\jo b0\createautodeintmovie.h264" "D:\My DVB\NEW\HDConvertToX_1.8.332.2935\job0\crea teautodeintmovie.avs" avis [info]: 32x32 @ 25.00 fps (195 frames) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64 x264 [info]: cabac=0 ref=1 deblock=1:0:0 analyse=0x1:0 me=dia subme=1 psy_rd=0.0 :0.0 mixed_ref=0 me_range=4 chroma_me=0 trellis=0 8x8dct=0 cqm=0 deadzone=21,11 chroma_qp_offset=0 threads=6 thread_queue=6 nr=0 decimate=1 mbaff=0 bframes=0 ke yint=250 keyint_min=25 scenecut=40 rc=abr bitrate=200 ratetol=1.0 qcomp=0.60 qpm in=10 qpmax=51 qpstep=4 ip_ratio=1.40 aq=1:1.00 x264 [info]: profile Baseline, level 1.3 x264 [info]: encoded 195 frames, 120.00 fps, 7.01 kb/s x264 [info]: slice I:1 Avg QP:11.00 size: 110 x264 [info]: slice P:194 Avg QP:11.13 size: 32 x264 [info]: mb I I16..4: 75.0% 0.0% 25.0% x264 [info]: mb P I16..4: 15.9% 0.0% 0.0% P16..4: 28.9% 0.0% 0.0% 0.0% 0 .0% skip:55.3% x264 [info]: final ratefactor: -12.81 x264 [info]: coded y,uvDC,uvAC intra:30.5% 71.7% 49.6% inter:10.6% 27.4% 8.6% x264 [info]: SSIM Mean Y:0.9979311 x264 [info]: kb/s:6.5 encoded 195 frames, 120.00 fps, 7.01 kb/s D:\My DVB\NEW\HDConvertToX_1.8.332.2935\job0>"D:\My DVB\NEW\HDConvertToX_1.8.332 .2935\applications\x264.exe" --threads 0 --bitrate 200 --thread-input --trellis 0 --no-cabac --merange 4 --subme 1 --no-chroma-me --partitions none --me dia --s ar 1:1 --progress --no-psnr --output "D:\My DVB\NEW\HDConvertToX_1.8.332.2935\jo b0\autodeint_ff_movie.h264" "D:\My DVB\NEW\HDConvertToX_1.8.332.2935\job0\autode int_ff_movie.avs" avis [info]: 32x32 @ 25.00 fps (135 frames) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64 x264 [info]: cabac=0 ref=1 deblock=1:0:0 analyse=0x1:0 me=dia subme=1 psy_rd=0.0 :0.0 mixed_ref=0 me_range=4 chroma_me=0 trellis=0 8x8dct=0 cqm=0 deadzone=21,11 chroma_qp_offset=0 threads=6 thread_queue=6 nr=0 decimate=1 mbaff=0 bframes=0 ke yint=250 keyint_min=25 scenecut=40 rc=abr bitrate=200 ratetol=1.0 qcomp=0.60 qpm in=10 qpmax=51 qpstep=4 ip_ratio=1.40 aq=1:1.00 x264 [info]: profile Baseline, level 1.3 x264 [info]: encoded 135 frames, 67.50 fps, 7.74 kb/s x264 [info]: slice I:1 Avg QP:11.00 size: 110 x264 [info]: slice P:134 Avg QP:11.36 size: 34 x264 [info]: mb I I16..4: 75.0% 0.0% 25.0% x264 [info]: mb P I16..4: 20.3% 0.0% 0.0% P16..4: 36.4% 0.0% 0.0% 0.0% 0 .0% skip:43.3% x264 [info]: final ratefactor: -11.55 x264 [info]: coded y,uvDC,uvAC intra:26.3% 77.9% 52.2% inter:10.0% 34.4% 8.2% x264 [info]: SSIM Mean Y:0.9979154 x264 [info]: kb/s:6.9 encoded 135 frames, 67.50 fps, 7.74 kb/s D:\My DVB\NEW\HDConvertToX_1.8.332.2935\job0>"D:\My DVB\NEW\HDConvertToX_1.8.332 .2935\applications\x264.exe" --crf 20 --keyint 250 --bframes 4 --mixed-refs --t rellis 0 --ref 4 --deblock -1,-1 --subme 9 --direct auto --vbv-bufsize 14000 --v bv-maxrate 25000 --me umh --no-ssim --weightb --b-adapt 2 --no-chroma-me --8x8dc t --aud --aq-strength 1 --sar 1:1 --output "D:\My DVB\NEW\HDConvertToX_1.8.332 .2935\job0\hdconverttox_viva polska20090626-05_23_22.h264" "D:\My DVB\NEW\HDConv ertToX_1.8.332.2935\job0\hdconverttox_viva polska20090626-05_23_22.avs" avis [info]: 512x528 @ 25.00 fps (6148 frames) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64 x264 [info]: cabac=1 ref=4 deblock=1:-1:-1 analyse=0x3:0x113 me=umh subme=9 psy_ rd=1.0:0.0 mixed_ref=1 me_range=16 chroma_me=0 trellis=0 8x8dct=1 cqm=0 deadzone =21,11 chroma_qp_offset=-2 threads=1 thread_queue=1 nr=0 decimate=1 mbaff=0 bfra mes=4 b_pyramid=0 b_adapt=2 b_bias=0 direct=3 wpredb=1 keyint=250 keyint_min=25 scenecut=40 rc=crf crf=20.0000 qcomp=0.60 qpmin=10 qpmax=51 qpstep=4 vbv_maxrate =25000 vbv_bufsize=14000 ip_ratio=1.40 pb_ratio=1.30 aq=1:1.00 x264 [info]: profile High, level 3.2 |
30th August 2009, 22:41 | #1907 | Link | |
30th August 2009, 23:41 | #1908 | Link |
Practising Schemer
Yeah it must be language on that audio, just curiosity as it encodes fine.
Does anyone know where the hidden options txt file went? I am want to have HDC automatically import chapters from DVD. Since I reinstalled I can't seem to find it. Edit forget it I am livin in the past, hidden options were removed in favour of editing the ini file. #Muxing Options AutoChapter=0 AutoChapter Minutes=5 NO Subs Always On=1 Last edited by flebber; 30th August 2009 at 23:47. |
31st August 2009, 08:09 | #1909 | Link | ||||
HDConvertToX author
Assorted answer
thanks rickatnight11 for your guide! linked in first post Quote:
@flebber don't use dss2 with vob source. it's near useless, better to stick with dgindex and... yes, ??? mean unable to determine language Quote:
i will need the full make report @Frozen-Figo try to use shorter file name/path BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
31st August 2009, 18:24 | #1911 | Link | |
D:\My DVB\NEW\HDConvertToX_1.8.332.2935\job0>"D:\My DVB\NEW\HDConvertToX_1.8.332 .2935\applications\dgindex.exe" -FO=0 -OM=0 -YR=2 -AIF=[c:\documents and setting s\frozen\desktop\a.mpg] -OF=[D:\My DVB\NEW\HDConvertToX_1.8.332.2935\job0\movie] -exit -minimize D:\My DVB\NEW\HDConvertToX_1.8.332.2935\job0>"D:\My DVB\NEW\HDConvertToX_1.8.332 .2935\applications\eac3to.exe" "c:\documents and settings\frozen\desktop\a.mpg" 2: stdout.wav | "D:\My DVB\NEW\HDConvertToX_1.8.332.2935\applications\neroaac enc.exe" -if - -br 64000 -ignorelength -of "D:\My DVB\NEW\HDConvertToX_1.8.332.2 935\job0\hdencodertox-pid2.mp4" ************************************************************* * * * Nero AAC Encoder * * Copyright 2008 Nero AG * * All Rights Reserved Worldwide * * * * Package build date: Sep 17 2008 * * Package version: 1.3.3.0 * * * * See -help for a complete list of available parameters. * * * ************************************************************* Processed 128 seconds... D:\My DVB\NEW\HDConvertToX_1.8.332.2935\job0>"D:\My DVB\NEW\HDConvertToX_1.8.332 .2935\applications\x264.exe" --crf 20 --keyint 250 --bframes 4 --mixed-refs --t rellis 0 --ref 4 --deblock -1,-1 --subme 9 --direct auto --vbv-bufsize 14000 --v bv-maxrate 25000 --me umh --no-ssim --weightb --b-adapt 2 --no-chroma-me --8x8dc t --aud --aq-strength 1 --sar 1:1 --output "D:\My DVB\NEW\HDConvertToX_1.8.332 .2935\job0\hdconverttox_a.h264" "D:\My DVB\NEW\HDConvertToX_1.8.332.2935\job0\hd converttox_a.avs" avis [info]: 640x464 @ 25.00 fps (3218 frames) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64 x264 [info]: cabac=1 ref=4 deblock=1:-1:-1 analyse=0x3:0x113 me=umh subme=9 psy_ rd=1.0:0.0 mixed_ref=1 me_range=16 chroma_me=0 trellis=0 8x8dct=1 cqm=0 deadzone =21,11 chroma_qp_offset=-2 threads=1 thread_queue=1 nr=0 decimate=1 mbaff=0 bfra mes=4 b_pyramid=0 b_adapt=2 b_bias=0 direct=3 wpredb=1 keyint=250 keyint_min=25 scenecut=40 rc=crf crf=20.0000 qcomp=0.60 qpmin=10 qpmax=51 qpstep=4 vbv_maxrate =25000 vbv_bufsize=14000 ip_ratio=1.40 pb_ratio=1.30 aq=1:1.00 x264 [info]: profile High, level 3.2 |
31st August 2009, 19:11 | #1912 | Link |
HDConvertToX author
@Sharc
i'll check it @Frozen-Figo please post the make report AND update to latest full package/latest exe! thanks BHH
1st September 2009, 00:07 | #1914 | Link | ||
Practising Schemer
Buzzqw I was trying to make sure the profiles enabled fast first pass in 2 pass mode for new profiles as it seems that the pass I am getting in first pass is slow.
from http://mewiki.project357.com/wiki/X2...#fast_1st_pass I was trying to set pass settings. So that my first pass runs with these settings Quote:
1st September 2009, 04:17 | #1915 | Link |
I Would like to know in future, if you will add "addborders" preset automatic for 720p (1280x720) and 1080p (1920x1080) and will respect aspect ratio? It's an suggestion
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. |
1st September 2009, 05:18 | #1917 | Link |
Ok, so that the clueless people like myself can play along as well, my next movie that I'm doing the "The Game Plan".
This BD comes with a bunch of little m2ts files, unfortunately. I did some searching and came across a recommendation for TSmuxer to combine the m2ts files into a single. I did that and am using HDC to analyze and convert that single m2ts file. We'll see how it goes. |
1st September 2009, 05:20 | #1918 | Link | |
1st September 2009, 07:06 | #1919 | Link |
I experienced a number of crashes of xvid_encraw for certain sources. I am on Vista. I tried various settings, at the end I found that the crashes seem to be caused by the function -qpel. With -qpel disabled the crashes disappeared. Anyone having similar experience?
1st September 2009, 07:35 | #1920 | Link | |||
HDConvertToX author
It's disabled by specifing "--slow-first-pass" HDC will use turbo in first pass. Quote:
better to post it than attach BHH
bluray, hdc, hdconverttox, m2ts, network media tank, playstation, x264 gui |
