30th July 2017, 22:40 | #221 | Link |
I have exactly the same problem with Win10 CU x64. Doesn't mount and go directly to the prompt and the -d switch doesn't do anything.
Also, after a while I unsuccessfully try to mount an avs, I always get a APC_INDEX_MISMATCH BSOD (the more I try, the quicker it appear) |
30th July 2017, 22:55 | #222 | Link | |
Professional Code Monkey
3rd August 2017, 10:37 | #224 | Link | |
elevated prompt doesn't make a difference. I've been encoding with ffmpeg the last few videos, and I think I have most of the handbrakecli settings translated over, so this will have to be the workaround to the avfs fail. |
24th August 2017, 19:35 | #225 | Link |
Soul Architect
I confirm this doesn't work on Windows 10 x64. C:\volumes remains empty. I tried running as admin.
FrameRateConverter | AvisynthShader | AvsFilterNet | Natural Grounding Player with Yin Media Encoder, 432hz Player, Powerliminals Player and Audio Video Muxer Last edited by MysteryX; 25th August 2017 at 01:14. |
13th November 2017, 00:06 | #227 | Link |
lrn2bugreport kthxbye
20th December 2017, 00:00 | #230 | Link |
For avs+ x64 mt , I use avfs script.avs . The avfs.exe I use is bundled with vapoursynth x64. It's definitely working, and definitely x64 mt (prefetch working). (That avfs.exe also mounts vpy scripts)
For avisynth x86 (vanilla) I use pfm mount . I still need the x86 version to interface with things like debugmode frameserver / advanced frameserver |
24th December 2017, 12:28 | #231 | Link |
Ah ok Avisynth R274 + AVFS 1.0.0.7 + LSMashsource R921 in my Windows10-64bit now works.
But using AVFS.EXE 1.0.0.7, instead of the "PFM mount" I alwais need to keep open the commandline dos-window I'm in a batch processing and need to mount 50/100 video files... it's not the best solutions keeping open 50/100 dos windows, so I wonder if is there a way to have the 64bit version of AVFS (1.0.0.7) like the 32bit (1.0.0.5 using PFM.exe + avfs.DLL)? Or in there a way to get the AVFS.DLL 64bit to have the same usage? Thanks Last edited by marcorocco; 24th December 2017 at 12:30. |
24th December 2017, 14:25 | #232 | Link | |
24th December 2017, 18:40 | #233 | Link |
Oh, I understand however the usage of AVFS.exe in batch processing and with multiple files is uncomfortable, having to open a new window each time.
Nobody can create a .dll with the 64bit version of AVFS? I'm a Cat... I'm not able to write a wrapper o_o however AVFS works great |
6th April 2018, 15:49 | #235 | Link | |
What is the source? Did you use the correct matrix ? For most HD sources it would be 709 eg. Code:
ConvertToRGB24(matrix="rec709") |
7th April 2018, 11:26 | #236 | Link | |
Thnx |
13th April 2018, 07:27 | #238 | Link |
Thnx for the help...
So now I am using this "ConvertToRGB(matrix="rec709")" as the last line in my avs scripts so that I can use avfs w/o issues. My question is, does this alter the source quality -i.e. regular Blu-Ray- in any way? Also, using ConvertToRGB instead of ConvertToRGB24, does this lead to any differences at all?! Thnx |
13th April 2018, 15:45 | #239 | Link | ||
But some programs and codecs might handle RGB32 better than RGB24 in terms of performance. It has to do with memory layout and handling. Quality wise no difference if coming from a BD source |
14th April 2018, 10:40 | #240 | Link | |
Thnx *edit* I have to add that I am only using a script to transcode the Blu-Ray video to x264...In other words, this loss due to conversion, does it matter in my case since I am converting from lossless to lossy?! *edit2* I just made a test encode, and Media Info is showing this "Color space : YUV", what does this mean? Didn't we convert to something else?! Last edited by mtamimi; 14th April 2018 at 11:31. |
