Old 28th May 2009, 18:16   #961  |  Link
pdanpdan
Can you please explain what "Multi Episodes DVD" does?
I have some Aeon Flux DVD's - 1PGC with all 5 episodes, 1PGC with only the episodes with audio comment(4), and 5PGC's with individual episodes.
How would I use "Multi Episodes DVD"?
Thank you
pdanpdan is offline   Reply With Quote
Old 28th May 2009, 18:43   #962  |  Link
Acid-Burn
Posts: n/a
Old 28th May 2009, 19:30   #963  |  Link
Sharc
@noee
my test agrees with yours, is is better off
That's a matter of individual preference, but visual comparison should be done at equal bitrates (equal file size) for a fair comparison. Means when using psy you might have to increase crf slightly for obtaining the same file size. I often use psy 0.7:0.2.
Old 28th May 2009, 19:33   #964  |  Link
buzzqw
HDConvertToX author
@pdanpdan
mean more pgc per ifo
if your first pgc is an episodes, check it
if your first pgc is main movie, don't check it
if your pgc X is main movie, don't check it
if your pgc X is episodes, check it
basically : whenever you have to deal with more then one pgc AND no one is the "main" but each one is an episodes, check multi episodes
@Acid-Burn
check the crop AND the Movie AR, even if your dvd should be 2.35 it could be a little more wide
@Sharc
that's a another beauty of HDC, every one could edit the profiles
(and share with others)
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 28th May 2009, 19:54   #965  |  Link
Acid-Burn
Posts: n/a
Old 28th May 2009, 20:32   #966  |  Link
buzzqw
HDConvertToX author
you are misreading the gui value
maybe you are posting the AR ERROR...
i mean movie ar, top part of gui
BHH
Old 28th May 2009, 20:41   #967  |  Link
Acid-Burn
Posts: n/a
Old 28th May 2009, 21:29   #968  |  Link
Sharc
With the latest version the problems seems to be back that Shutdown= and Multitemp= are reset with each save.
Old 28th May 2009, 21:33   #969  |  Link
Elpichu
hi !
the "keep only core" option is not funtionning : cheking it or not checking it for this BR movie, the command lines for eac3to do not have the -core option, and name is still thd+ac3
HDConvertToX v.1.7.323.2869 report
Input File: e:\dvdfab\mainmovie\the_6th_day\bdmv\stream\00011.m2ts ( E:\dvdfab\MainMovie\THE_6TH_DAY\BDMV\STREAM\00011.m2ts )
Codec Video: avc
Width / Heigh : 1920 / 1080
Framerate / Framecount: 23.976 / 177768
Duration(hh:mm:ss): 2:3:35
Aspect Ratio: 1.7778
Resized resolution: 1920 / 1080
Crop Values : 0:140:0:140
No Resize & Crop: On
Start Video Configuration ->
Encoding Settings: X264 in MKV
NMT Compatibility: On
Encoding Preset: 7
Final Size: 20
Priority: idle
Denoise Level: Super Light
Video Handling: Use Best Decoder
-> End Video Configuration
Start Audio Configuration ->
Audio Codec: Copy Audio
Audio Bitrate/Quality: 128
Audio Channels: 2
MP3 Mode: abr
Normalize: On
Audio handling: Use Eac3to as demuxer
-> End Audio Configuration
Full Audio List-> (*** mean selected)
NONE
*** 3: truehd/ac3, english, 5.1 channels, 48khz
*** 4: truehd/ac3, french, 5.1 channels, 48khz
5: ac3, spanish, 5.1 channels, 640kbps, 48khz
6: truehd/ac3, portuguese, 5.1 channels, 48khz
7: ac3, thai, 5.1 channels, 640kbps, 48khz
-> End Full Audio List
Full Subtitle List-> (*** mean selected)
*** NONE
8: subtitle (pgs), english
9: subtitle (pgs), english
10: subtitle (pgs), french
11: subtitle (pgs), spanish
12: subtitle (pgs), arabic
13: subtitle (pgs), chinese
14: subtitle (pgs), chinese
15: subtitle (pgs), korean
16: subtitle (pgs), portuguese
-> End Full Subtitle List
Mux Subtitle in MP4/MKV file: On
Start Advanced AviSynth ->
Basic Filter: RemoveGrain(mode=2)
ColorMatrix: On
-> End Advanced AviSynth
Start Queue ->
"C:\Program Files (x86)\HDConverToX\applications\eac3to.exe" "e:\dvdfab\mainmovie\the_6th_day\bdmv\stream\00011.m2ts" 2:"E:\dvdfab\MainMovie\THE_6TH_DAY\BDMV\STREAM\temp\hdconverttox.h264"
"C:\Program Files (x86)\HDConverToX\applications\DGAVCIndex.exe" -i "E:\dvdfab\MainMovie\THE_6TH_DAY\BDMV\STREAM\temp\hdconverttox.h264" -o "E:\dvdfab\MainMovie\THE_6TH_DAY\BDMV\STREAM\temp\movie.dga" -f 0 -e
"C:\Program Files (x86)\HDConverToX\applications\eac3to.exe" "e:\dvdfab\mainmovie\the_6th_day\bdmv\stream\00011.m2ts" 3: "E:\dvdfab\MainMovie\THE_6TH_DAY\BDMV\STREAM\temp\hdencodertox-pid3.thd+ac3"
"C:\Program Files (x86)\HDConverToX\applications\eac3to.exe" "e:\dvdfab\mainmovie\the_6th_day\bdmv\stream\00011.m2ts" 4: "E:\dvdfab\MainMovie\THE_6TH_DAY\BDMV\STREAM\temp\hdencodertox-pid4.thd+ac3"
"C:\Program Files (x86)\HDConverToX\applications\x264.exe" --crf 20 --threads auto --thread-input --no-psnr --progress --keyint 250 --bframes 3 --mixed-refs --trellis 0 --ref 3 --deblock -1,-1 --subme 9 --direct auto --vbv-bufsize 14000 --vbv-maxrate 25000 --me umh --no-ssim --weightb --b-adapt 1 --no-chroma-me --8x8dct --aud --nal-hrd --aq-strength 1 --psy-rd 1.0:0.3 --sar 1:1  --output "E:\dvdfab\MainMovie\THE_6TH_DAY\BDMV\STREAM\temp\hdconverttox_00011.h264" "E:\dvdfab\MainMovie\THE_6TH_DAY\BDMV\STREAM\temp\hdconverttox_00011.avs" --level 4.0
"C:\Program Files (x86)\HDConverToX\applications\eac3to.exe" "e:\dvdfab\mainmovie\the_6th_day\bdmv\stream\00011.m2ts" 1:"E:\dvdfab\MainMovie\THE_6TH_DAY\BDMV\STREAM\temp\chapters.txt"
"C:\Program Files (x86)\HDConverToX\applications\mkvmerge.exe" -o "C:\Program Files (x86)\HDConverToX\hdconverttox_full_00011.mkv" --default-duration 0:23.976fps  --aspect-ratio -1:1.7778 "E:\dvdfab\MainMovie\THE_6TH_DAY\BDMV\STREAM\temp\hdconverttox_00011.h264"   --language -1:eng "E:\dvdfab\MainMovie\THE_6TH_DAY\BDMV\STREAM\temp\hdencodertox-pid3.thd+ac3"  --language -1:fre "E:\dvdfab\MainMovie\THE_6TH_DAY\BDMV\STREAM\temp\hdencodertox-pid4.thd+ac3" --chapters "E:\dvdfab\MainMovie\THE_6TH_DAY\BDMV\STREAM\temp\chapters.txt"  --title "Done with HDConvertToX v.1.7.317.2832"
-> End Queue
AviSynth Script ->
Working with files: E:\dvdfab\MainMovie\THE_6TH_DAY\BDMV\STREAM\temp\hdconverttox_00011.avs
try {
AVCSource("E:\dvdfab\MainMovie\THE_6TH_DAY\BDMV\STREAM\temp\movie.dga")
hqdn3d(1)
RemoveGrain(mode=2)
return last
catch (err) {
last=BlankClip()
converttoyv12()
subtitle(err)
trim(0,1500)
-> End AviSynth Script
i already noticed this with dts hi res tracks too ! but it used to work some versions ago
Elpichu is offline   Reply With Quote
Old 28th May 2009, 21:56   #970  |  Link
Sharc
Is there an easy way to enable shutdown when an encode is already running?
Will it be ok when I add to the queue manually
shutdown -s -t 2 -f ?
Old 28th May 2009, 22:43   #971  |  Link
Mrsash
With the new version AR and Xvid processing works fine. As per your suggestion to keep best quality chose NeroAAC, 0.4, Audio channels original, vbr - hope got this right. Source was 5.1 but it still came out with stereo?
thanks
Mrsash is offline   Reply With Quote
Old 29th May 2009, 03:01   #972  |  Link
Mrsash
if even selecting directshowsource don't handle your file... there is a problem
here is a sample mate
http://www.sendspace.com/file/5cg2ie
Old 29th May 2009, 04:27   #973  |  Link
rickhtoo
Hey Buzz, really like the operation of HDC now, and really want to use it, but it keeps letting me down..
Most of the time when I use it to encode a DVD, the results are nice video with out of sync audio.. Seems it just can't wait to start the soundtrack and therefore the sync is way off. Is it something I'm doing wrong? When this happens, I redo it with AutoMKV and it works perfect. I always copy the audio whenever possible.
On a positive note, I sometimes run across a DVD with Mpeg1 audio, and AutoMKV refuses to work with it. HDC however will, using Coding Tech AAC to reencode the audio track.
Puzzling why I'm getting such mixed results trying to encode with HDC, I appreciate any help you can offer.
Thanks
Rick
rickhtoo is offline   Reply With Quote
Old 29th May 2009, 05:08   #974  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
Small bug report. When changing the Audio encode settings for a Nero AAC encode, and I have modified the bitrate to, say, 256, if i change the channels from 2 to original the bitrate jumps back to 64.
Oh, and I am working on a tutorial for converting bluray's with HDC. Hope to have it out by Friday night.
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Old 29th May 2009, 07:10   #975  |  Link
Sharc
@buzzqw
The overhead for .m2ts is still too low which may result in oversize.
I had 2 cases now with 8% overhead (1 video+2 ac3 audio copy+2 subs). I suggest you should change it accordingly.
m2ts is not very efficient in this respect.
Old 29th May 2009, 07:48   #976  |  Link
buzzqw
HDConvertToX author
fixed , download the update
Originally Posted by Elpichu View Post
hi !
the "keep only core" option is not funtionning : cheking it or not checking it for this BR movie, the command lines for eac3to do not have the -core option, and name is still thd+ac3[/CODE]
just try...
thanks
make sure in ffdshow audio decoder you set the audio out to not downmixing
Originally Posted by rickhtoo View Post
Most of the time when I use it to encode a DVD, the results are nice video with out of sync audio.. Seems it just can't wait to start the soundtrack and therefore the sync is way off. Is it something I'm doing wrong? When this happens, I redo it with AutoMKV and it works perfect. I always copy the audio whenever possible. Rick
i need more info..
how do you rip the dvd ?
@buzzqw
fixed , download the update (8.5%)
audio bit change when you change "Bitrate Management" or "Audio codec" , it' don't change on channels
And thanks for the guide!
BHH
Old 29th May 2009, 15:13   #977  |  Link
Mrsash
This avi has Ac3 audio for this movie which I think is decoded by Ac3 filter. I changed ffdshow settings to change default codec to be liba52 and it worked. Which one is better liba52 or libavcodec?
thanks
Old 29th May 2009, 15:20   #978  |  Link
buzzqw
HDConvertToX author
should give the same quality (but usually i prefer libavcodec.. usually is faster)
BHH
Old 29th May 2009, 22:33   #979  |  Link
alter4
I try to encode DVD to x264 in mp4 with version 1.7 and want to share my impressions.
1. AutoResize doesn't correlate with selected video size
2. Status of AVS scripts is not checked (see p.3)
3. I used FFT3DFilter and got: FFT3DFilter: Can not load FFTW3.dll! E:\temp\hdconverttox_vts_01_1.avs, line 86
4. There are no ability to auto shutdown PC via GUI after encoding finished
#HDConvertToX Avisynth Script
#Input File = e:\video\concerts\kipelov -2005\video_ts\vts_01_1.vob
#Original Resolution = 720x576
#Aspect Ratio = 1.3334
#Frame rate =25.000
#Number of Frames = 114475
#Lenght (hour:minutes:seconds) = 1:16:20
#Display Aspect Ratio = 1.4385
#Aspect Error = 0.2070
#Resized resolution = 712 / 496
#Crop Left = 6
#Crop Top = 24
#Crop Right = 2
#Crop Bottom = 24
LoadPlugin("D:\tools\HDC\filters\AddGrain.dll")
Import("D:\tools\HDC\filters\Srestore.avsi")
try {
#Source File
mpeg2source("E:\temp\movie.d2v")
#Insert Deinterlacer
exist("E:\temp\interlaced") ? TDeint(mode=0,order=-1) : nop()
exist("E:\temp\telecine") ? tfm(last,d2v="E:\temp\movie.d2v").tdecimate() : nop()
#Applying Resizing
LanczosResize(712,496,6,24,-2,-24)
#Insert Filters As Requested
ColorMatrix(d2v="E:\temp\movie.d2v")
FFT3DFilter(sigma=2.5, sharpen=0.3)
catch (err) {
last=BlankClip()
converttoyv12()
subtitle(err)
trim(0,1500)
alter4 is offline   Reply With Quote
Old 29th May 2009, 22:58   #980  |  Link
Adub
Adub's Avatar
You see that "try...catch" block right in your script? That's the checking mechanism. In order to properly use FFT3DFilter, Libfftw3.dll ( think is what it's called) has to be placed in you system32 folder. That should fix your error.
What exactly do you mean by this? Can you reiterate?
Site:Adubvideo
bluray, hdc, hdconverttox, m2ts, network media tank, playstation, x264 gui
