2nd November 2007, 16:37 | #801 | Link |
New version (1.0, using Aften SVN R606) of WAV to AC3 Encoder is available for download and also updated Aften binaries (SVN R606) are available for download.
wisodev |
2nd November 2007, 20:21 | #802 | Link |
Good news!!
I wasn't able to produce any problems (hangs, crashes or strange command line outputs) with wisodev's latest R606 build, anymore! Cleaned up my source, much nicer looking now! Thanks to DarkAvenger (and wisodev). |
4th November 2007, 01:56 | #804 | Link | |
Chumbo |
7th November 2007, 22:26 | #805 | Link |
Posts: n/a
Newbie question:
I have six WAV files (FL, FR, C, SL, SR, LFE) which I intend to feed into aften or WAV to AC3 Encoder. Am I correct to assume that these two programs don't support 6 mono WAVs input? What would the sox commandline be to remux the mono file into a single 6-channel WAV with the correct channel order so that it can be encoded by WAV to AC3 Encoder? Or if sox can't do it, what would you suggest to use for muxing the mono files? Last edited by honai; 7th November 2007 at 22:50. |
8th November 2007, 02:14 | #806 | Link | |
sox -M 1_FL.wav 2_FR.wav 3_C.wav 4_LFE.wav 5_SL.wav 6_SR.wav -t wav - | Aften - out6.ac3 |
8th November 2007, 22:32 | #808 | Link |
Huh?
Is channel coupling planned to be added in the future?
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it. |
9th November 2007, 10:21 | #810 | Link | |
Doom9ing since 2001
10th November 2007, 02:39 | #811 | Link |
Here is a patch for multiple mono input support in Aften. Testing and comments are welcome. It still needs a good bit of testing and cleanup before making it into SVN.
http://sourceforge.net/mailarchive/m...05%40gmail.com |
10th November 2007, 10:49 | #813 | Link | |
Test machine: AMD Athlon 64 X2 Dual Core Processor 3600+ 2.4Ghz, 3GB RAM, Microsoft Windows XP SP2 Used input files: Code:
File: Name: C.wav File Size: 514866 Format: Type: Microsoft PCM Channels: 1 Sample Rate: 44100 Hz Avg bytes/sec: 88200 Block Align: 2 bytes Bit Width: 16 Channel Mask: 0x004 Data: Start: 44 Data Size: 514822 Samples: 257411 Playing Time: 5.84 sec File: Name: FL.wav File Size: 514866 Format: Type: Microsoft PCM Channels: 1 Sample Rate: 44100 Hz Avg bytes/sec: 88200 Block Align: 2 bytes Bit Width: 16 Channel Mask: 0x004 Data: Start: 44 Data Size: 514822 Samples: 257411 Playing Time: 5.84 sec File: Name: FR.wav File Size: 514866 Format: Type: Microsoft PCM Channels: 1 Sample Rate: 44100 Hz Avg bytes/sec: 88200 Block Align: 2 bytes Bit Width: 16 Channel Mask: 0x004 Data: Start: 44 Data Size: 514822 Samples: 257411 Playing Time: 5.84 sec File: Name: LFE.wav File Size: 514866 Format: Type: Microsoft PCM Channels: 1 Sample Rate: 44100 Hz Avg bytes/sec: 88200 Block Align: 2 bytes Bit Width: 16 Channel Mask: 0x004 Data: Start: 44 Data Size: 514822 Samples: 257411 Playing Time: 5.84 sec File: Name: S.wav File Size: 514866 Format: Type: Microsoft PCM Channels: 1 Sample Rate: 44100 Hz Avg bytes/sec: 88200 Block Align: 2 bytes Bit Width: 16 Channel Mask: 0x004 Data: Start: 44 Data Size: 514822 Samples: 257411 Playing Time: 5.84 sec File: Name: SL.wav File Size: 514866 Format: Type: Microsoft PCM Channels: 1 Sample Rate: 44100 Hz Avg bytes/sec: 88200 Block Align: 2 bytes Bit Width: 16 Channel Mask: 0x004 Data: Start: 44 Data Size: 514822 Samples: 257411 Playing Time: 5.84 sec File: Name: SR.wav File Size: 514866 Format: Type: Microsoft PCM Channels: 1 Sample Rate: 44100 Hz Avg bytes/sec: 88200 Block Align: 2 bytes Bit Width: 16 Channel Mask: 0x004 Data: Start: 44 Data Size: 514822 Samples: 257411 Playing Time: 5.84 sec Code:
@echo on rem TEST 3/2 aften FL.wav FR.wav C.wav LFE.wav SL.wav SR.wav -o t_32+LFE.ac3 aften -acmod 7 FL.wav FR.wav C.wav LFE.wav SL.wav SR.wav -o t_acmod7_32+LFE.ac3 aften -acmod 7 -lfe 0 FL.wav FR.wav C.wav SL.wav SR.wav -o t_acmod7_32.ac3 rem TEST 2/2 aften FL.wav FR.wav SL.wav SR.wav -o t_22.ac3 aften -acmod 6 FL.wav FR.wav SL.wav SR.wav -o t_acmod6_22.ac3 rem TEST 3/1 aften -acmod 5 -lfe 1 FL.wav FR.wav C.wav LFE.wav S.wav -o t_acmod5_31+LFE.ac3 aften -acmod 5 -lfe 0 FL.wav FR.wav C.wav S.wav -o t_acmod5_31.ac3 rem TEST 2/1 aften -acmod 4 -lfe 1 FL.wav FR.wav C.wav LFE.wav -o t_acmod4_21+LFE.ac3 aften -acmod 4 -lfe 0 FL.wav FR.wav C.wav -o t_acmod4_21.ac3 rem TEST 3/0 aften FL.wav FR.wav C.wav -o t_30.ac3 aften -acmod 3 FL.wav FR.wav C.wav -o t_acmod3_30.ac3 rem TEST 2/0 aften FL.wav FR.wav -o t_20.ac3 aften -acmod 2 FL.wav FR.wav -o t_acmod2_20.ac3 rem TEST 1/0 aften C.wav -o t_10.ac3 aften -acmod 1 C.wav -o t_acmod1_10.ac3 rem TEST 1+1 aften -acmod 0 FL.wav FR.wav -o t_acmod0_1+1.ac3 Code:
$ test-mono.cmd $ rem TEST 3/2 $ aften FL.wav FR.wav C.wav LFE.wav SL.wav SR.wav -o t_32+LFE.ac3 Aften: A/52 audio encoder Version SVN (c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al. input format (6 files): WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono output format: 44100 Hz 3/2 + LFE SIMD usage: MMX SSE SSE2 SSE3 Threads: 2 progress: 100% | q: 477.8 | bw: 38.8 | bitrate: 448.0 kbps $ aften -acmod 7 FL.wav FR.wav C.wav LFE.wav SL.wav SR.wav -o t_acmod7_32+LFE.ac3 Aften: A/52 audio encoder Version SVN (c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al. input format (6 files): WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono output format: 44100 Hz 3/2 + LFE SIMD usage: MMX SSE SSE2 SSE3 Threads: 2 progress: 100% | q: 477.8 | bw: 38.8 | bitrate: 448.0 kbps $ aften -acmod 7 -lfe 0 FL.wav FR.wav C.wav SL.wav SR.wav -o t_acmod7_32.ac3 Aften: A/52 audio encoder Version SVN (c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al. input format (5 files): WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono output format: 44100 Hz 3/2 SIMD usage: MMX SSE SSE2 SSE3 Threads: 2 progress: 100% | q: 480.2 | bw: 38.8 | bitrate: 448.0 kbps $ rem TEST 2/2 $ aften FL.wav FR.wav SL.wav SR.wav -o t_22.ac3 Aften: A/52 audio encoder Version SVN (c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al. input format (4 files): WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono output format: 44100 Hz 2/2 SIMD usage: MMX SSE SSE2 SSE3 Threads: 2 progress: 100% | q: 478.8 | bw: 43.7 | bitrate: 384.0 kbps $ aften -acmod 6 FL.wav FR.wav SL.wav SR.wav -o t_acmod6_22.ac3 Aften: A/52 audio encoder Version SVN (c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al. input format (4 files): WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono output format: 44100 Hz 2/2 SIMD usage: MMX SSE SSE2 SSE3 Threads: 2 progress: 100% | q: 478.8 | bw: 43.7 | bitrate: 384.0 kbps $ rem TEST 3/1 $ aften -acmod 5 -lfe 1 FL.wav FR.wav C.wav LFE.wav S.wav -o t_acmod5_31+LFE.ac3 Aften: A/52 audio encoder Version SVN (c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al. input format (5 files): WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono output format: 44100 Hz 3/1 + LFE SIMD usage: MMX SSE SSE2 SSE3 Threads: 2 progress: 100% | q: 484.3 | bw: 43.7 | bitrate: 384.0 kbps $ aften -acmod 5 -lfe 0 FL.wav FR.wav C.wav S.wav -o t_acmod5_31.ac3 Aften: A/52 audio encoder Version SVN (c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al. input format (4 files): WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono output format: 44100 Hz 3/1 SIMD usage: MMX SSE SSE2 SSE3 Threads: 2 progress: 100% | q: 479.1 | bw: 43.7 | bitrate: 384.0 kbps $ rem TEST 2/1 $ aften -acmod 4 -lfe 1 FL.wav FR.wav C.wav LFE.wav -o t_acmod4_21+LFE.ac3 Aften: A/52 audio encoder Version SVN (c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al. input format (4 files): WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono output format: 44100 Hz 2/1 + LFE SIMD usage: MMX SSE SSE2 SSE3 Threads: 2 progress: 100% | q: 457.9 | bw: 35.8 | bitrate: 256.0 kbps $ aften -acmod 4 -lfe 0 FL.wav FR.wav C.wav -o t_acmod4_21.ac3 Aften: A/52 audio encoder Version SVN (c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al. input format (3 files): WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono output format: 44100 Hz 2/1 SIMD usage: MMX SSE SSE2 SSE3 Threads: 2 progress: 100% | q: 461.0 | bw: 35.8 | bitrate: 256.0 kbps $ rem TEST 3/0 $ aften FL.wav FR.wav C.wav -o t_30.ac3 Aften: A/52 audio encoder Version SVN (c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al. input format (3 files): WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono output format: 44100 Hz 3/0 SIMD usage: MMX SSE SSE2 SSE3 Threads: 2 progress: 100% | q: 461.0 | bw: 35.8 | bitrate: 256.0 kbps $ aften -acmod 3 FL.wav FR.wav C.wav -o t_acmod3_30.ac3 Aften: A/52 audio encoder Version SVN (c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al. input format (3 files): WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono output format: 44100 Hz 3/0 SIMD usage: MMX SSE SSE2 SSE3 Threads: 2 progress: 100% | q: 461.0 | bw: 35.8 | bitrate: 256.0 kbps $ rem TEST 2/0 $ aften FL.wav FR.wav -o t_20.ac3 Aften: A/52 audio encoder Version SVN (c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al. input format (2 files): WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono output format: 44100 Hz stereo (2/0) SIMD usage: MMX SSE SSE2 SSE3 Threads: 2 progress: 100% | q: 447.7 | bw: 43.7 | bitrate: 192.0 kbps $ aften -acmod 2 FL.wav FR.wav -o t_acmod2_20.ac3 Aften: A/52 audio encoder Version SVN (c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al. input format (2 files): WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono output format: 44100 Hz stereo (2/0) SIMD usage: MMX SSE SSE2 SSE3 Threads: 2 progress: 100% | q: 447.7 | bw: 43.7 | bitrate: 192.0 kbps $ rem TEST 1/0 $ aften C.wav -o t_10.ac3 Aften: A/52 audio encoder Version SVN (c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al. input format: WAVE Signed 16-bit little-endian 44100 Hz mono output format: 44100 Hz mono (1/0) SIMD usage: MMX SSE SSE2 SSE3 Threads: 2 progress: 100% | q: 495.1 | bw: 43.7 | bitrate: 96.0 kbps $ aften -acmod 1 C.wav -o t_acmod1_10.ac3 Aften: A/52 audio encoder Version SVN (c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al. input format: WAVE Signed 16-bit little-endian 44100 Hz mono output format: 44100 Hz mono (1/0) SIMD usage: MMX SSE SSE2 SSE3 Threads: 2 progress: 100% | q: 495.1 | bw: 43.7 | bitrate: 96.0 kbps $ rem TEST 1+1 $ aften -acmod 0 FL.wav FR.wav -o t_acmod0_1+1.ac3 Aften: A/52 audio encoder Version SVN (c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al. input format (2 files): WAVE Signed 16-bit little-endian 44100 Hz mono WAVE Signed 16-bit little-endian 44100 Hz mono output format: 44100 Hz dual mono (1+1) SIMD usage: MMX SSE SSE2 SSE3 Threads: 2 progress: 100% | q: 466.2 | bw: 43.7 | bitrate: 192.0 kbps $ Download my test results. It looks like Aften with multi-mono input works without any problems on my machine. Thanks, wisodev |
10th November 2007, 18:39 | #815 | Link |
I added a new convenience parameter to the Aften commandline. You now have the option to use text to describe the channel configuration instead of -acmod and -lfe. The new parameter is -chconfig. Here is the help text for this option:
[-chconfig X] Specify channel configuration (overrides wav header) 1+1 = (Ch1,Ch2) 1/0 = (C) 2/0 = (L,R) 3/0 = (L,R,C) 2/1 = (L,R,S) 3/1 = (L,R,C,S) 2/2 = (L,R,SL,SR) 3/2 = (L,R,C,SL,SR) adding "+LFE" indicates use of the LFE channel aften -chconfig 3/2+LFE fivepointone.wav fivepointone.ac3 Last edited by jruggle; 10th November 2007 at 18:42. |
11th November 2007, 02:18 | #816 | Link |
Here is an updated multi-mono input patch against SVN-r614.
http://sourceforge.net/mailarchive/m...01%40gmail.com |
11th November 2007, 09:47 | #817 | Link |
hmm aften crash for me
i try to encode some mp3 with aften -q 240 -s 1 -w -2 %s %d(in foobar2k) it crashed in the middle of encoding, tried wisodev and my own compile also same. removing variable adaptive bandwidnth option avoided the crash, am i doing something stupid? |
13th November 2007, 16:54 | #819 | Link |
Svn Revision r618
Hi all!
SVN REVISION r618 http://kurtnoise.free.fr/index.php?dir=Aften/ not working with AftenGUI on my system. If I click encode button, immediately i get this message: "encoding finished succesfully!" Input file is 48Khz waw file. SVN REVISION 606 is OK (aften-svn-r606-icl10-win32-bin\aften_x86_SSE3) Latest WAV to AC3 Encoder too not working - EncWAVtoAC3-1.0-Win32U-bin.zip ex. I copy to dir libaftendll_x86_SSE3\libaften.dll, but application is say : "failed to load libaften". Last edited by totya; 13th November 2007 at 17:03. |
13th November 2007, 17:23 | #820 | Link | |
The EncWAVtoAC3.win32 config file contains paths to used libaften.dll dll's. You need to edit this file if you use different libaften.dll or use it from different path. |
