Old 1st April 2002, 15:28   #41  |  Link
int 21h
Still Laughing
int 21h's Avatar
Re: heres an example of an 800Mb 80minCD
Originally posted by SonicFRAG
This is by far the most interesting topic I've seen with the most potential!
Indeed it seems that there HAS to be a way to burn multimedia files (in this case DivX) in mode 2 form 2 (or to fit 800Mb on an 80min CD)
as most logic and reason seems to point to a way of doing so.
How many people are familar with the Dreamcast scene?
Dreamcast games come on 1GB GD-ROMS and so to copy a game to a normal CD things would need to be ripped out.
Enter Shenmue II.
I looked at my copy (80min CD-R) and looked at the contents of the CD. In my computer it came up as 647Mb CD.
Further inspecion with Neros session selector indicated 2 seesions, the first one being 100Mb and the second session being 700Mb. (total, just over 800Mb)
Interesting?
Furthermore, I could look and copy at the contents of the CD to my HD as if they were burnt in mode 1!
Also note, The original .CDI image file was over 800MB!
Looking at the Discjuggler setting (of the .CDI file) it was burnt as mode 2 AUDIO.
But how to master a CD in this way?? Certaintly I can't select mode2/XA form2 in the mastering/burning options in Discjuggler.....
All we need is a program that can burn mode2 form2, or at least make it think its an audio or video CD when instead it has a DivX video on it.....
comments?
Shenmue II was 3 or 4 cds when it was copied from the original GD-ROM.
int 21h is offline   Reply With Quote
Old 1st April 2002, 17:45   #42  |  Link
MaTTeR
AC3 5.1 Addict
MaTTeR's Avatar
Tronic and Ingo, coders of the upcoming MCF file format have been looking into this as well. It seems a problem comes up when trying to extract the MCF data from the CDROM XA. Windows and Linux are unable to see the CDROM in a filesystem sort of way.
Anyone aware of some sort of driver hack or driver project that would allow the CDROM to be seen as a filesystem? It seems were close but some nasty obstacles keep jumping in the way.
Need AC3 & SPDIF setup info?
MaTTeR is offline   Reply With Quote
Old 1st April 2002, 19:46   #43  |  Link
movmasty
you are missing somethin,
that is to know if a given file format can work w/o error correction.
mpg format works like a plain text file, if there is an error,you'll lose just one character or few characters, all the rest will be ok,
unless you loose a part of the header.
avis work like a program, if you loose one bit,you loose all.
and it isnt just about the header, but along all the file.
now,dunno exactly about SVCD,but VCD,that is 172kB/s(140video+28 audio)can last at max 64 minutes on a 650mb-74minutes CD,
then its written in mode 1.
The fact is that when there is audio mpeg files lose their magic,
due to audio/video sync issues mpeg files too are easy to get corrupted.
Es: virtual dub never fails to load a video only mpg,but very often fails to load mpgs with audio.
thus you could have pcm audio or mpg video only in mode 2,
dont think video+audio streams.....unless someone makes a better audiovideo syncronization.....and then some other writes a new burning option....
movmasty is offline   Reply With Quote
Old 1st April 2002, 20:01   #44  |  Link
MaTTeR
AC3 5.1 Addict
MaTTeR's Avatar
@movmasty
The error correction is understood by everyone in this thread. We can get around that issue just using the MCF file format or by other means.
At issue is how to extract the data from a M2F2 CDROM type? According to Tronic, ISObuster is format specific.
Old 1st April 2002, 22:06   #45  |  Link
int 21h
Still Laughing
int 21h's Avatar
You would have to either formulate a new driver for Windows for the CDRom, or more likely, formulate an emulation program that can read the CD (similar to Daemon tools, etc)
Old 1st April 2002, 23:22   #46  |  Link
avih
Capture, Deinterlace
avih's Avatar
assumming we're willing to live without error correction, isn't there any way to use vcd/svcd format to store arbitrary files??? it's easily read by standard pc-cdrom.....
avih is offline   Reply With Quote
Old 2nd April 2002, 04:21   #47  |  Link
movmasty
>The error correction is understood by everyone in this thread...
....oh
Old 2nd April 2002, 07:37   #48  |  Link
avih
avih's Avatar
i didn't miss that post movmasty and i used the word assumption..., anyway, i wanna try for myself what does it mean "without error correction" i.e. will it still be playable after 1 playback? 2 playbacks? 50/100/1000 whatever.
i wanna experiment, but i (as others afaik) haven't yet managed to put an arbitrary file on a svcd file format.
avi
Old 2nd April 2002, 11:14   #49  |  Link
hyc
You'll probably find that you will need to use the highest quality gold-colored CD-Rs if you try this, certainly your error rates will go up as the disc ages.
hyc is offline   Reply With Quote
Old 2nd April 2002, 15:27   #50  |  Link
ppera2
ppera2's Avatar
I thinked about this way of recording AVI's about one year ago.
But now, looking to my CD collection I must say that it is not worth.
Many CD is hard to read, and without error correction it will be disaster after couple years...
ppera2 is offline   Reply With Quote
Old 2nd April 2002, 15:53   #51  |  Link
ChristianHJW
Posts: n/a
Sorry for being late guys ... this happens if you dont check the 'General Section' in regular periods ... shame on me !
You may read these threads here http://www.powerdivx.com/phpbb2/viewtopic.php?t=367 and here http://forum.doom9.org/showthread.php?s=&threadid=18969 also, the subject was raised before a few times already.
About 1300 MB CDs or even DVDs : using mode 2 form 2 will always give you more storage capacity, even if your CD is bigger !! A 1300 MB CD should well be able to give you up to 1500 MB then, so all your nice 2 CD rips will fit on 1 CD then ...
So, here is some more input :
1. AVI : This subject was discussed really more than one time and as a matter of fact it seems that good old AVI format is not at all prepared for this ! I was told not only the header will be problematic in case of reading errors, the whole file can be messed with a few bits missing or being wrong on some place ... so it seems you had to do a complete hack for this, and with respect to Ogg and MCF standing outside the front door this is really not worth it IMHO.
2. Ogg : We havent got any clear response on this from Ogg dev team, but it seems even Ogg has some neat CRC in the format that would allow using it for mode 2 form 2 discs. It should be, always bare in mind it was designed for stremaing also.
3. MCF : MCF was defined with Adler32 error correction and is extremely forgiving if any bytes or even blocks are missing. It will be a wise thing though to write the header itself ( although there is a safety copy of the header at the end of each file ) in normal mode and only the data itself in mode 2 form 2 ... but we are implementing this in the basic specs, as well as the possibility to split the whole file into several portions ( like 2 - 4 CDs, whatever ). Please check the MCF specs, technical section, on http://mcf.sourceforge.net for more info.
How to implement this :
Well there is a very good working implementation for S-VCDs we could use. A few things have to be done though :
- Create a program that can do CUE/BIN from a MCF file on HDD, so its ready to be burned with Nero/CDRDAO/EZ etc. ; this should respect the header specific mode burning, being well possible i was informed.
- Implement reading support into the MCF parser or another DirectShowFilter, so MCF files can be played directly from disc ! Please note that reading S-VCDs is not a basic feature of any Windows OS ( not sure about 98SE/ME ) !!! A virgin Win2k installation can not read S-VCDs directly, only after installing WinDVD ( or whatever ) the OS gets these capabilities ! This is not true for VCDs it seems, at least on my box it is working to copy/read the data directly from the CD to HDD, maybe because i have old version of PowerDVD installed, dont know.
- Create an extraction tool similar to VCDimager/VCDgear to be able to copy/read the data from disc to HDD.
It is well possible it seems, but requires some work to be done. If anybody is interested in joining the MCF dev team for this purpose, please PM me here.
Old 2nd April 2002, 23:56   #52  |  Link
Tronic
What we're currently going to do with MCF:
All our sectors are Mode 2 sectors with 2336 octets of user-data.
Mode 2 sector structure: (total size 2352 o)
-Sync (00 FF FF FF FF FF FF FF FF FF FF 00) (12 octets)
-Minute/Second/Frame (3 octets)
-Mode (02) (1 octet)
-User data (2336 o)
In our track,
-Sector 0: MCF-CD Header (contains X1 and X2 + some other data).
-Sectors 1 - X1: MCF (headers), with some kind of error _correction_.
-Sectors X1 - X2: MCF (data), no error correction, just detection (per-sector + per-cluster).
-Sectors X2 - END: MCF (headers), with ECC.
This would give us even more storage space than SVCD has. It seems that there is no reason to include any filesystem on the disc.
Writing stuff to a BIN-image is pretty easy. The only tricky part is calculating the ECC.
Reading stuff from CD or image, without ECC, is REALLY easy. Reading with ECC is somewhat tricky.
Todo:
-Figure out how TOC works: how to instruct players on how to read our track.
-Decide how to do that ECC.
Matroska's father and companion: http://mcf.sf.net/Docs/MCF/
Tronic is offline   Reply With Quote
Old 3rd April 2002, 02:25   #53  |  Link
movmasty
this cause windows comes with a built in mpg1 driver,
old mpg1 is free,while you have to pay for mpg2.
Would be easy to make one driver for both mpg1 and 2,
but isnt done for commercial reasons.
as avi mpg could contain almost every codec(and in fact the mpg1 format is very less simple than many think,old mpg1 drivers cant read many new mpg1)
only you cant just add a dll with the new codec,but have to rewrite all the driver,
so would be possible,i think,also to implement any mpg4 codec in a mpg1+2+4 or mpg1+4 driver,
with the advantage that it will be supported immediately from existing players and editors.
Old 3rd April 2002, 12:52   #54  |  Link
ChristianHJW
Posts: n/a
Originally posted by movmasty this cause windows comes with a built in mpg1 driver, old mpg1 is free,while you have to pay for mpg2.
... yes, maybe, but pls. be aware that the MPEG1 decoder itself isnt necessarily capable of reading the data from the disc directly also ... but its likely M$ built in such support, as it will allow all M$ OS to view VCDs with Mediaplayer ( does it ? ), bein main purpose for MPEG1 ..
I'd be interested to leanr if the elecard MPEG2 decoder has the ability to read/parse S-VCDs also ... time to ask Blacksun about that i guess ...
Old 3rd April 2002, 17:47   #55  |  Link
theReal
Piper at theGates of Dawn
theReal's Avatar
Windows is able to read VCD movies as normal files, Windows has also been able to read Audio CD's as normal files for a short while - but then the audio industry pressured MS to remove the direct Audio-CD reading (and now that they have done so, noone can copy audio CD's anymore, LOL)
I guess if it was only up to MS, Windows would be able to read & copy everything directly.
theReal is offline   Reply With Quote
Old 4th April 2002, 20:02   #56  |  Link
DeXT
I see a potential problem... when Windows reads a DAT file linked to the Mode2/XA area, it appends a RIFF header at the start of the file. This header is not present in the Mode2 video track (I've tested it). Also, the file is being read in RAW mode, i.e. it contains a sector header (sync,addr, mode) as well as subheader and EDC, every 2352 bytes.
So if you burn, say, an AVI file in the second track and link it from the first ISO track, you'll end with a AVI file with an additional RIFF header attached to it and lots ot sector headers to play with.
So any software reading this should bypass this extra data. This seems OS dependent (I don't know if Linux does the same when reading such files). Perhaps this is only related to "M" flag files...
Any thoughts?
DeXT is offline   Reply With Quote
Old 4th April 2002, 20:20   #57  |  Link
int 21h
Still Laughing
int 21h's Avatar
The biggest point you guys are missing is that Windows reads those file systems because they are declared standards (Whitebook, Greenbook, Yellowbook, etc) with Philips for Compact Discs.
Putting anything besides Mpeg2 in the Data area of a SVCD disc violates the standard, and its very likely it won't work correctly.
Old 5th April 2002, 09:01   #58  |  Link
movmasty
burning mpg in mode 2
Old 7th April 2002, 03:52   #59  |  Link
oddball
Elecard reads S-VCD fine. Just have to open the MPG file from the folder on the S-VCD and it reads it as normal.
oddball is offline   Reply With Quote
Old 7th April 2002, 15:48   #60  |  Link
ChristianHJW
Posts: n/a
@oddball,
thanks mate, this is very helpful info .... by chance BlackSun has very good contact with the elecard guys ... so i know wht he has to ask them tomorrow !!
BTW : TRonic could create first 800 MB MCF CDs recetnly ( test only ) and updated the MCF CD specs accordingly.
Now its time to fix the header specs ...
