Old 17th April 2013, 12:53   #2961  |  Link
AGKnotUser
Originally Posted by Zathor View Post
Sorry, currently not possible. Which command do you want to add?
Thanks, I found a way to add the options. I used mkvmerge GUI to add command line options and saved them as default for new jobs. MKV Muxer runs the commands. The commands were: --engage no_cue_duration --engage no_cue_relative_position. TMT 6 works with these.
AGKnotUser is offline
Old 17th April 2013, 23:00   #2962  |  Link
Zathor
MeGUI is also applying those two options since a few builds automatically.
Zathor is offline
Old 18th April 2013, 00:47   #2963  |  Link
AGKnotUser
Oh, didn't see it in the log window. I thought I added it. Oh well.
Old 25th April 2013, 14:36   #2964  |  Link
cybersharky
I'm busy encoding Star Trek Voyager, it's 4:3, but after encoding mediainfo is reporting it as 3:2. d2v file says it's 4:3. x264 SAR is set to default.
SetMemoryMax(1024)
SetMTMode(2,0)
Import("B:\Gary\MeGUI_2308_x86\tools\avisynth_plugin\McDegrainSharp.avsi")
LoadPlugin("B:\Gary\MeGUI_2308_x86\tools\avisynth_plugin\avstp.dll")
LoadPlugin("B:\Gary\MeGUI_2308_x86\tools\avisynth_plugin\SmoothAdjust.dll")
LoadPlugin("B:\Gary\MeGUI_2308_x86\tools\avisynth_plugin\mvtools2.dll")
LoadPlugin("B:\Gary\MeGUI_2308_x86\tools\dgindex\DGDecode.dll")
DGDecode_mpeg2source("B:\Gary\Dvdrips\MainMovie\VOYAGER_S1D1_E3\VIDEO_TS\VTS_01_1.d2v", info=3)
LoadPlugin("B:\Gary\MeGUI_2308_x86\tools\avisynth_plugin\ColorMatrix.dll")
ColorMatrix(hints=true, interlaced=true, threads=0)
LoadPlugin("B:\Gary\MeGUI_2308_x86\tools\avisynth_plugin\TIVTC.dll")
tfm(mode=0, PP=2, cthresh=2, mi=25, mChroma=false, blockx=16, blocky=16).tdecimate()
crop(8, 0, -4, 0)
#resize
#denoise
Smoothlevels(preset="tv2pc",TVrange=false)
McDegrainSharp()
cybersharky is offline
Old 25th April 2013, 14:50   #2965  |  Link
Poutnik
Useless idea generator
Poutnik's Avatar
Is there way for MeGUI to use QTGMC("some of very fast settings") instead of YADIF for Automatic deinterlacing of OneClick ?
For explicit deinterlacing there is no problem to write SC and AVS profiles.
But for automatic de-interlacing I do not see the way - at least I did not when searching for it in MeGUI.
Vista64 Premium SP2 / C2D E4700 2.6GHz/ 6GB RAM/ Intel GMA 3100 / DTV Leadtek DONGLE GOLD USB2 /
focused to DVB-T MPEG2 PS capture -> ProjectX -> M2V/MP2 -> MeGUI/AVS -> MP4[AVC/AAC]
Poutnik is offline
Old 26th April 2013, 17:37   #2966  |  Link
Zathor
Please post the complete log.
Originally Posted by Poutnik View Post
Is there way for MeGUI to use QTGMC("some of very fast settings") instead of YADIF for Automatic deinterlacing of OneClick?
Currently there is no such option.
Zathor is offline
Old 27th April 2013, 00:17   #2967  |  Link
invy
Quick question: Will y'all ever the tabbing order? I like to use keyboard a lot, especially in the script creator window. Much faster for me.
invy is offline
Old 27th April 2013, 23:35   #2968  |  Link
jq963152
Hello,
why doesn't MeGUI update to AviSynth 2.6.0 when using the development update server?
With the development update server it's still at version 2.5.8.
Or will MeGUI change from AviSynth to VapourSynth or something like that?
jq963152 is offline
Old 28th April 2013, 11:57   #2969  |  Link
cybersharky
https://dl.dropboxusercontent.com/u/...4_15-09-06.log
Old 29th April 2013, 17:49   #2970  |  Link
Zathor
Maybe - I do not use it myself and this may be the reason that I forget to check the order after a GUI change. Where do you want to have it changed? And how?
As soon as we have a stable AviSynth 2.6 build I will update it. Currently it is still in alpha. But you can install any AviSynth build you like.
Zathor is offline
Old 29th April 2013, 18:01   #2971  |  Link
Zathor
You have some errors during opening the file "VideoFile.avs"
Avisynth: access violation at 0x0000C878 in C:\Program Files (x86)\AviSynth 2.5\plugins\DGDecode.dll
Maybe it is related to your AviSynth build:
AviSynth: 2.6.0.3 (3/9/2013 9:28:48 AM)
Also you have to either enable resize (+ suggest resolution) or anamorphic encoding in the AVS Script Creator - otherwise you will end with a plain 720x480 encoding which is 3:2.
Zathor is offline
Old 29th April 2013, 18:07   #2972  |  Link
jq963152
But what about this (see highlighted part):
Originally Posted by SEt View Post
Here is my builds of Avisynth 2.6 with several (mostly MT) fixes. MT mode stability is way better than Avisynth 2.5.8, general stability - the same as official Avisynth 2.6 (which is again better than 2.5.8 due to many bugfixes since then).
jq963152 is offline
Old 29th April 2013, 20:44   #2973  |  Link
Zathor
Install it yourself if you like.
Zathor is offline
Old 30th April 2013, 16:33   #2974  |  Link
Morku
Today I got x264 version 2309-1. I can't find this version on http://x264.nl/ (still 2309). Whats the difference and where can I get 10bit version of 2309-1?
Morku is offline
Old 30th April 2013, 16:58   #2975  |  Link
Zathor
I had to republish 2309 - with a new name out of technical reasons - as the x64 bit file was missing.
Zathor is offline
Old 30th April 2013, 22:29   #2976  |  Link
panark
Using megui 2341 and the latest version from x264.nl "x264 core 132 r2309 3b1f1f7"
with --opencl in the custom command line i get this in the log:
x264 [warning]: OpenCL: not compiled with OpenCL support, disabling
with --disable-opencl
--[Error] [30/4/2013 11:59:24 μμ] An error occurred: avs [error]: Error occurred while writing frame 0
--[Error] [30/4/2013 11:59:24 μμ] Process exits with error: 0xFFFFFFFF (-1)
---[NoImage] x264_64: unknown option -- disable-opencl
---[NoImage] avs [error]: Error occurred while writing frame 0
---[NoImage] (Maybe x264 closed)
windows 7 x64 - nvidia geforce gt430 (latest driver 314.22)
I have opencl.dll on both system32 and syswow64 folders
also opencl64 on program files/nvidia corporation/opencl
According to x264 changelog
Output quality when OpenCL lookahead is enabled is often
very slightly worse in quality than the CPU quality (because of the same data dependencies).
It seems i can't make opencl work but in any case if i want to disable it, because encoding time isn't an issue, how do i do it?
panark is offline
Old 1st May 2013, 00:13   #2977  |  Link
detmek
OpenCL is disabled by default. You don't have to disable it manualy.
detmek is offline
Old 2nd May 2013, 12:15   #2978  |  Link
panark
Thanx for the info.
Assuming i want to enable opencl, how do i do it?
panark is offline
Old 2nd May 2013, 12:30   #2979  |  Link
detmek
With --opencl, if your hardware supports it. If not, you'll get a warning message and encoding will continue without using OpenCL.
detmek is offline
Old 3rd May 2013, 16:52   #2980  |  Link
luke83
luke83's Avatar
can you add chapter box in the onclick encoder presets?
What is the best Avisynth build? is there a list so i can study about them? Im'using this one: http://code.google.com/p/avisynth-mt/
luke83 is offline
