9th January 2013, 15:35 | #2901 | Link | |
Hi Folks.
Since i guess ive posted this in the Wrong Thread before now ill do it here again.. Well from Time to Time i got problems with MeGui encoding to XVID 2 Pass. Its performing Pass1 perfectly with approx 450 FPS encode speed and then it crashes starting Pass2. (Log below) That can this be ? Its most time only on Xvid with 640x272 Resolution. Edit: I tried it again with another DVD and got the Same problem.. Pass1 perfect, pass2 crash. All encodes to 640x272. If i have an encode 640x352..everything runs perfect. I dont know what else to test now... Mara Quote:
12th January 2013, 12:17 | #2903 | Link |
Why can't people get used to providing helpful details?
MeGUI creates a log with the verbose error message and directions to the reason. Furthermore, a MediaInfo analysis of the source file can't hurt. Never. |
12th January 2013, 20:42 | #2904 | Link |
Hi.
I have 2 systems, one is laptop (Core i5) and another is desktop with AMD A10-5800K. On desktop, when I encode DTS to AC-3 job step called "Preprocessing" takes huge amount of time (several minutes), on laptop it finishes in a few seconds. Same delay I have when demuxing mkv. Is this something related with MeGUI settings. Is there a way to reset them? Or where should I dig? |
13th January 2013, 01:12 | #2906 | Link |
Thanks. About audio encoding, delay was result of normalizing option enabled.
About mkv demux: if I select to extract video stream as .mkv (default option) extractor just freezes ("Analyzing ..."), if I set .h264 - process goes normally. Actually I would better set .h264 for video stream as default option if it is possible. Anyway, here is a log for the first case: Code:
-[Information] Versions --[Information] [13.01.2013 1:49:31] MeGUI: 2237 --[Information] [13.01.2013 1:49:31] Operating System: Windows 7 Enterprise Edition x64 SP1 (6.1.65536.7601) --[Information] [13.01.2013 1:49:31] .Net Framework: 4.0 (4.0.30319) --[Information] [13.01.2013 1:49:31] AviSynth: 2.5.8.5 (21.12.2008 21:46:54) --[Information] [13.01.2013 1:49:31] AvisynthWrapper: 02.01.2009 20:34:04 --[Information] [13.01.2013 1:49:31] Haali Matroska Splitter: 24.11.2005 21:24:30 --[Warning] [13.01.2013 1:49:31] Haali DSS2: not installed --[Information] [13.01.2013 1:49:31] ICSharpCode.SharpZipLib: 0.85.5.452 (07.08.2008 20:31:12) --[Information] [13.01.2013 1:49:31] LinqBridge: 1.0.0.0 (28.05.2009 1:24:34) --[Information] [13.01.2013 1:49:31] MediaInfo: 0.7.61.0 (21.10.2012 16:29:05) --[Information] [13.01.2013 1:49:31] MediaInfoWrapper: 0.7.53.0 (23.08.2012 14:33:43) --[Information] [13.01.2013 1:49:31] MessageBoxExLib: 1.0.2218.28317 (19.12.2008 20:53:04) --[Information] [13.01.2013 1:49:31] SevenZipSharp: 0.64.3890.29348 (02.01.2011 10:59:32) --[Information] [13.01.2013 1:49:31] 7z: 9.20 (18.11.2010 16:27:34) -[Information] Update detection --[Information] [13.01.2013 1:49:31] Connecting to server: http://megui.org/auto/stable/ --[Information] [13.01.2013 1:49:32] All files are up to date -[Information] HD Streams Extractor --[Information] [13.01.2013 1:50:04] Input: E:\222\video.mkv --[Information] [13.01.2013 1:50:04] Arguments: "E:\222\video.mkv" --[Warning] Unknown line: "v01 The video bitstream is encoded in a non-standard framerate." --[Information] [13.01.2013 1:50:05] Feature Retrieval Completed -[Information] Log for job9 (ext, video.mkv -> _txxx) --[Information] [13.01.2013 1:50:26] Started handling job --[Information] [13.01.2013 1:50:26] Preprocessing --[Information] [13.01.2013 1:50:26] Job commandline: "D:\app\MeGUI\tools\eac3to\eac3to.exe" "E:\222\video.mkv" 1:"L:\_t\T1_Video - .mkv" 2:"L:\_t\T2_Audio - English.dts" -core 3:"L:\_t\T3_Subtitle - English.srt" -progressnumbers --[Information] [13.01.2013 1:50:26] Extracting started -[Information] [13.01.2013 1:50:51] Delete aborted ouptut set: True -[Information] [13.01.2013 1:50:51] File to delete: L:\_txxx -[Information] [13.01.2013 1:50:51] File deleted --[Information] Deleting aborted output --[Information] [13.01.2013 1:50:51] Process exits with error: 0xFFFFFFFF (-1) -[NoImage] MKV, 1 video track, 1 audio track, 3 subtitle tracks, 1:44:44, 24p /1.001 -[NoImage] 1: h264/AVC, 1920x816 23.976p (40:17) -[NoImage] 2: DTS, English, 5.1 channels, 24 bits, 1510kbps, 48kHz -[NoImage] "DTS 5.1" -[NoImage] 3: Subtitle (SRT), English -[NoImage] 4: Subtitle (SRT), Dutch -[NoImage] 5: Subtitle (SRT), Portuguese -[NoImage] v01 The video bitstream is encoded in a non-standard framerate. -[NoImage] v01 Extracting video track number 1... -[NoImage] a02 Extracting audio track number 2... -[NoImage] v01 Muxing video to Matroska... -[NoImage] a02 Creating file "L:\_t\T2_Audio - English.dts"... --[Information] [13.01.2013 1:50:51] Standard output stream --[Information] [13.01.2013 1:50:51] Standard error stream --[Information] [13.01.2013 1:50:51] Job completed --[Information] [13.01.2013 1:50:51] Current job was aborted Last edited by Grossmeister; 13th January 2013 at 01:40. Reason: Update |
18th January 2013, 00:42 | #2907 | Link |
I'm encountering a minor problem, hopefully this is the right place to post it. I've encoded a couple bluray movies recently using Megui (2-pass x264 muxed to mkv), but when I play them afterwards using VLC I'm finding that it has somewhat of a seek time when I skip through the movie; in particular if I were to skip from 5 mins in to say 30 mins, the elapsed time counter on the bottom left side turns blue while it's seeking and takes about 5 seconds while it's navigating to the time position. I've encoded tons of bluray video over the last couple years (when I was on Win7) and none of them have this seek issue - when I click on a timestamp, it instantly jumps there and continues. I switched to Win8 recently, forgot to backup my x264 profiles , so I had to remake them all again, so I'm assuming I've just forgotten one of the settings that I used to use. My guess is that it has something to do with video buffering? Any help is appreciated, thanks. |
18th January 2013, 11:42 | #2909 | Link |
Maybe the problem is the new mkvmerge 5.9.0 and this:
https://trac.bunkus.org/wiki/FAQ%3APlaybackDoesNotWorkVLCCannotSeekMkvmerge590 Read also: https://trac.bunkus.org/wiki/FAQ%3AImprovingPlaybackCompatibilityWithPlayers
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 18th January 2013 at 12:27. Reason: Add info |
22nd January 2013, 02:04 | #2912 | Link |
Matroska find' ich toll
i think there is a small bug in the avs creator. (MeGUI2272 x64)
i use the AutoCrop button and the value of the right side is 2 (left:0 top:132 bottom: 134). If i select the resize filter mod16 i cant set the display resolution to 1920x???. 1880x800 is the maximum value i can set. in a previous version it was possible to do this. Last edited by hubblec4; 22nd January 2013 at 10:43. |
23rd January 2013, 12:27 | #2919 | Link | |
But maybe we need now: --engage no_cue_relative_position --engage no_cue_duration to preserve compatibility with some players.
24th January 2013, 10:31 | #2920 | Link | |
after cropping i loose 2Pixel from the rigth side. so could be the display dimension 1918x??? and where i can set the upscaling in AVISynth configuration? |
