5th December 2005, 20:24 | #681 | Link |
Mr. Sandman
i cant.
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 5th December 2005 at 20:33. |
5th December 2005, 20:27 | #682 | Link |
clueless n00b
why would you want to do that anyway? It's nice to know how big your video will finally be like, no?
5th December 2005, 20:33 | #683 | Link |
Mr. Sandman
However, i fixed the style thing for .NET 2.0 only. with 1.1 styles are partially applied (only on tabs and menus).
any ideas? .NET2.0 with styles: ... looks much better
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 5th December 2005 at 20:45. |
5th December 2005, 20:49 | #684 | Link | |
@sharktooth: All I know is that there are quite a few .Forms Control properties that are only available in .NET 2.0, like UseVisualBackColor. Last edited by charleski; 5th December 2005 at 20:51. |
6th December 2005, 05:14 | #685 | Link |
Quick bug report using 0.2.3.1018
In the AVS Creator, upon clicking the IVTC option, the creator adds this line. Telecide(guide=1).Decimate() In actuallity, it should add this line. Telecide(order=1,guide=1).Decimate() FYI |
6th December 2005, 09:21 | #686 | Link | |
clueless n00b
6th December 2005, 10:19 | #687 | Link |
Angel of Night
Order is TFF/BFF and if it's not given it'll use whatever avisynth thinks it is, which mpeg2source will set correctly. So always using order=1 could actually get you into trouble with BFF sources.
6th December 2005, 12:11 | #688 | Link | |
It no longer uses the order parameter. [BTW, this is mentioned in the changelog, and I'll be ading some code to extract the correct TFF/BFF decision from the d2v.] Last edited by charleski; 6th December 2005 at 12:13. |
6th December 2005, 18:46 | #689 | Link |
BeHappy/MeGUI developer
@Doom9
Does You look @ internal class Encoder @ BeHappy source? Does You still need more? I believe - 30 minutes is enought to make it MeGUI.Encoder descendant
BeHappy - AviSynth-based audio transcoding tool Audio encoding via AviSynth On2 VP7 is great in quality but it is unusable for long-term video backup puposes! Sincerely Yours, MCPD/MCTS |
6th December 2005, 18:53 | #690 | Link |
Mr. Sandman
Dimzon: please do not push ppl doing something. everyone have it's own business and maybe he had no time to check it.
6th December 2005, 19:43 | #691 | Link |
clueless n00b
@Dimzon: unfortunately I'm both swamped at work, and at home. A codec comparison takes a great deal of time, especially if you have a considerable list of potential codecs that you need to put through a qualification phase. This year's comparison effectively started last week and there is little chance I get to write any line of MeGUI code until the end of the year. But here's one:
In Calculator.cs, find the method codec_CheckedChanged and add updateBitrateSize(); so that the bitrate gets updated when switching between XviD and other codecs (XviD considers bitrate = raw bitstream bitrate, for all other codecs bitrate = final size / length). And here's how I think the tri-state thing should finally look like (mind you the method may be incomplete and was never tested) Code:
private void x264TriStateAdjustment(x264Settings xs) { if (xs.EncodingMode != 2 || xs.EncodingMode != 5) xs.Turbo = false; if (xs.Turbo) { xs.NbRefFrames = 1; xs.SubPelRefinement = 0; xs.METype = 0; // diamond search xs.I4x4mv = false; xs.P4x4mv = false; xs.I8x8mv = false; xs.P8x8mv = false; xs.B8x8mv = false; xs.AdaptiveDCT = false; xs.MixedRefs = false; xs.BRDO = false; xs.Trellis = false; } if (!(xs.EncodingMode == 1 && xs.Profile == 2)) // lossless requires CQ mode xs.Lossless = false; else xs.BitrateQuantizer = 0; if (xs.NbRefFrames <= 1) // mixed references require at least two reference frames xs.MixedRefs = false; if (xs.NbBframes < 2) // pyramid requires at least two b-frames xs.BFramePyramid = false; if (xs.NbBframes == 0) xs.AdaptiveBFrames = false; if (!xs.Cabac) // trellis requires CABAC xs.Trellis = 0; if (xs.NbBframes == 0) xs.WeightedBPrediction = false; if (xs.NbBframes == 0 || xs.SubPelRefinement < 5) // BRDO requires RDO and b-frames xs.BRDO = false; if (!xs.P8x8mv) // p8x8 requires p4x4 xs.P4x4mv; }
6th December 2005, 21:08 | #692 | Link |
MeGUI 0.2.3.1019
Changelog: 0.3.2.1019 6 Dec 2005 Changes by doom9 to make show progress window context sensitive. Added resizing to the video preview window. (The resizing is not really as pretty as I'd have liked, but after trying several approaches I think it's impossible to get a smoother result without moving up to .NET 2.0 which has some important improvements in how it handles these events.) Changed Files .NET 1.1 bins This patch doesn't include the changes doom9 suggested above. I'll have to add those next time. |
6th December 2005, 21:53 | #693 | Link |
Mr. Sandman
... MeGUI-src.ChngdFls_0.3.2.1019.rar .... 0.2.3.1019...
6th December 2005, 22:16 | #695 | Link |
Mr. Sandman
merged sources and bins are a the usual place though.
however maybe it's time to switch to .NET 2.0?
6th December 2005, 22:44 | #696 | Link |
As a general note for coding: in MeGUI, you should use MeGUI.GetDirectoryName as opposed to Path.GetDirectoryName, as (at least in .NET 1.1) you Path.GetDirectoryName will have no trailing slashes, except if the passed parameter is a root directory. This means that generating a filename using this could have two consecutive slashes if the filename is a root directory.
MeGUI.GetDirectoryName (a static function) is simply a wrapper for this function, which removes the trailing slash if it exists. Also, there's a problem with running a One Click encode. The process will be interrupted, because of a MessageBox that pops up. Removing Code:
MessageBox.Show(Environment.GetEnvironmentVariable("PATH"), "Path", MessageBoxButtons.OK); |
6th December 2005, 22:51 | #697 | Link |
Mr. Sandman
new bins and merged sources are up @ http://files.x264.nl/Sharktooth/?dir=./megui
edit: adding Code:
Application.EnableVisualStyles();
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 6th December 2005 at 23:00. |
6th December 2005, 23:02 | #698 | Link |
Mr. Sandman
an unhandled exception is triggered when clicking on Avisynth script creator menu entry:
************** Exception Text ************** System.NullReferenceException: Object reference not set to an instance of an object. at MeGUI.AviSynthWindow.generateScript() at MeGUI.AviSynthWindow.showScript() at MeGUI.AviSynthWindow.resizeFilterType_SelectedIndexChanged(Object sender, EventArgs e) at System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e) at System.Windows.Forms.ComboBox.set_SelectedIndex(Int32 value) at MeGUI.AviSynthWindow.set_Settings(AviSynthSettings value) at MeGUI.AviSynthWindow.avsProfile_SelectedIndexChanged(Object sender, EventArgs e) at System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e) at System.Windows.Forms.ComboBox.set_SelectedIndex(Int32 value) at MeGUI.AviSynthWindow..ctor(MeGUI mainForm) at MeGUI.MeGUI.mnuToolsAviSynth_Click(Object sender, EventArgs e) at System.Windows.Forms.MenuItem.OnClick(EventArgs e) at System.Windows.Forms.MenuItemData.Execute() at System.Windows.Forms.Command.Invoke() at System.Windows.Forms.Control.WmCommand(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ContainerControl.WndProc(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll ---------------------------------------- megui Assembly Version: 0.2.3.1019 Win32 Version: 0.2.3.1019 CodeBase: file:///C:/Documents%20and%20Settings/Ebola/Desktop/meguisrc/megui.exe ---------------------------------------- System.Windows.Forms Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll ---------------------------------------- System Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll ---------------------------------------- System.Drawing Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll ---------------------------------------- System.Xml Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll ---------------------------------------- xuq2gagl Assembly Version: 0.0.0.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll ---------------------------------------- rg0wr9ln Assembly Version: 0.0.0.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll ----------------------------------------
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 6th December 2005 at 23:33. |
6th December 2005, 23:57 | #699 | Link | |
7th December 2005, 00:49 | #700 | Link | |
0.2.3.1020 6 Dec 2005 Altered Path.GetDirectoryName to MeGUI.GetDirectoryName Removed a redundant piece of debugging code from jobUtil.openvideo Fixed a bug caused by incorporating the progress window code in the wrong place [Should add this to the changelog: I also tried putting Application.EnableVisualStyles() in as Sharktooth suggested. It actually makes things look worse for me, but I have a custom theme applied to Windows. Anyway, see what you think.] 0.2.3.1020 changes Bins Last edited by charleski; 7th December 2005 at 00:55. |
development, megui, not a help thread |
