Old 15th January 2019, 14:37   #6641  |  Link
jd17
Originally Posted by asarian View Post
With bitrates around 10x higher as regular DTS, the superiority of HD audio is a no-brainer, far as I'm concerned.
Nobody questions that lossless - in theory, or better measurably - is always better.
However, this is a forum that pretty much evolves around compression efficiency, i.e. saving bits where we don't see or hear it.
This is why I (and plenty others here too) take these lossless audio streams and compress them to 200-600kbit/s AAC or opus.
And while these codecs are obviously far superior to the ancient AC-3, you'd be surprised how good 640kbit/s Dolby Digital really is.
Accordingly, if the same master (and volume) is used, you would most likely fail in telling TrueHD apart from Dolby Digital, if you don't know which is playing.
jd17 is offline   Reply With Quote
Old 15th January 2019, 15:31   #6642  |  Link
asarian
'CD Quality' is 44.1 KHz/16 bit audio, generally considered 'very good' for music. Movies are a different thing, though. AC3 (aka DD 5.1) yields reasonable results at (almost always) 640kbps. But the difference between DTS-MA/TrueHD vs. AC3 is, well, unimaginably high. Believe me, I was in the same camp as you, one day, thinking you wouldn't be able to tell the difference... until I got an actual HD Amp. The fullness of the track when you switch to HD audio is staggering -- to the point where I can barely bear to listen to AC3 any more. In fact, for every Blu-ray I order (unless it's some sort of vintage deal), I first check to see whether it comes with HD Audio. If not, I simply don't buy it.
I'm not familiar with compressing audio 'to 200-600kbit/s AAC or opus' myself, so I'll take your word on those codecs.
Gorgeous, delicious, deculture!
asarian is offline   Reply With Quote
Old 15th January 2019, 15:46   #6643  |  Link
nevcairiel
Except on a technical level it really is not.
At least DTS has a "core" you can use for a direct comparison, since it has to be from the same master. If you were to decode both the core and the full HD stream to PCM and send that PCM to your "HD Amp", I'm positive that in most cases you wouldn't even be able to tell the difference. What these devices do is cheat you by playing with volume and EQ settings that play towards how people perceive audio. Just a slight bit more volume for HD, and most people already perceive it as "better", and there is more such tricks.
Or take a HD track and re-encode it as AC3, just to ensure its the same master, and then decode both back to PCM and send that to the Amp so the Amp does not know what the original format was.
There is a lot of trickery to try to sell you on "HD" stuff, because they had to sell you something, and in fact the audio quality difference have been minimal for years. If one really goes deep into it on a technical level, you'll eventually find that out. If you just blindly trust the Amp, then sure, HD probably sounds better to you, but not because its HD audio, but because the Amp cheats you.
Old 15th January 2019, 16:28   #6644  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
That whole TrueHD/Lossless audio topic reminds of 192KHz 24bit bullshit promoted by some well known companies. (Super Audio-CD , DVD-Audio and others). Facts are simple. 48Khz 16bit is more than enough for humans. Adults have hearing range up to ~18KHz ,so it still below 24Khz. The same story with bit depth.
TrueHD can sounds better than AC3 640kbps only if was encoded from better source or your amp is doing some tricks boosting artificially volume for some frequencies. (bass/trebles). If 128kbps OPUS/AAC is transparent for 2.0 then I see no reason why 320kbps wouldn't be enough for 5.1.
Old 15th January 2019, 17:10   #6645  |  Link
jd17
I get the feeling that you do not really understand where we are coming from...
We don't doubt you hear a difference!
But that difference is not based on codec superiority, but mastering, volume, dynamic compression and so forth.
However, we are turning in circles here, it's all been said already. You either do some legwork yourself and compare apples with apples, or you keep believing.
BTW, lossless-capable AVRs have been around for at least 10 years... Do you really think you are the only person here who owns one?
Sorry for the off-topic loop, let's get back to x265.
Old 15th January 2019, 22:57   #6646  |  Link
benwaggoner
Originally Posted by LigH View Post
No. I believe because GPU features would not speed x265 up. At least not without risking a loss of quality or losing the independence from hardware and software platforms (portability).
GPU features are not magical general speed-ups for every case of use, sometimes they just don't match the requirements.
I could see a 20-25% speedup for high quality encoding using GPU and fixed-function encoder features with the new, deeper Intel encoder/decoder APIs for preanalysis and such. Not because it would natively produce high quality output, but because it could help determine some optimal encoding parameters.
Ben Waggoner
My Compression Book
Old 15th January 2019, 23:07   #6647  |  Link
benwaggoner
I'll exactly argue against that. Information is a difference that makes a difference. A difference people can't discriminate in a proper double-blind test isn't a difference that matters.
Lossless or near lossless for sources makes sense, to the degree the extra information can eventually result in a detectable difference in derived content. Lossless, if used at all, is only used for archiving deep in studios.
Ben Waggoner
My Compression Book
Old 15th January 2019, 23:21   #6648  |  Link
jd17
I agree with you. That's why I inserted "in theory".
Old 17th January 2019, 16:37   #6649  |  Link
Selur
Selur's Avatar
Question regarding:
--qp-adaptation-range
is this a suboption of '-aq-mode 1+', '--hevc-aq', both, or is it independent of both?
Cu Selur
Old 17th January 2019, 19:46   #6650  |  Link
benwaggoner
Originally Posted by Selur View Post
Question regarding:
I believe it only applies to --hevc-aq.
Ben Waggoner
My Compression Book
Old 22nd January 2019, 18:27   #6651  |  Link
kosta1000
hi guys. Where can I find changelog for x265 3.0 ???
on official site, changelog exists only for version 2.9
another question : When Ryzen 2 get out around this June, would this processor have much better performance in x265 encoding, while AMD put 256-bit AVX2 now, along with many other notable improvments.
kosta1000 is offline   Reply With Quote
Old 22nd January 2019, 19:30   #6652  |  Link
Selur
Selur's Avatar
Probably hasn't been written yet,... iirc there hasn't been a 3.0 final/stable flag last tag was '3.0_RC'.
Old 22nd January 2019, 19:49   #6653  |  Link
benwaggoner
The best bet for the moment is to read the documentation that got added to —fullhelp in the checking.
https://bitbucket.org/multicoreware/.../branch/stable
Ben Waggoner
My Compression Book
Old 23rd January 2019, 17:13   #6654  |  Link
agressiv
Registered Loser
agressiv's Avatar
x265 3.0 Release is out!
Looks like 3.0 is finally released! Congrats to the team! Here are the release notes:
New features
1. option:: '--dolby-vision-profile <integer|float>' generates bitstreams confirming to the specified Dolby Vision profile. Currently profile 5, profile 8.1 and profile 8.2 enabled, Default 0 (disabled)
2. option:: '--dolby-vision-rpu' File containing Dolby Vision RPU metadata. If given, x265's Dolby Vision metadata parser will fill the RPU field of input pictures with the metadata
read from the file. The library will interleave access units with RPUs in the bitstream. Default NULL (disabled).
3. option:: '--zonefile <filename>' specifies a text file which contains the boundaries of the zones where each of zones are configurable.
4. option:: '--qp-adaptation-range' Delta-QP range by QP adaptation based on a psycho-visual model. Default 1.0.
5. option:: '--refine-ctu-distortion <0/1>' store/normalize ctu distortion in analysis-save/load. Default 0.
6. Experimental feature option:: '--hevc-aq' enables adaptive quantization
It scales the quantization step size according to the spatial activity of one coding unit relative to frame average spatial activity. This AQ method utilizes
the minimum variance of sub-unit in each coding unit to represent the coding unit’s spatial complexity.
Encoder enhancements
1. Preset: change param defaults for veryslow and slower preset. Replace slower preset with defaults used in veryslow preset and change param defaults in veryslow preset as per experimental results.
2. AQ: change default AQ mode to auto-variance
3. Cutree offset reuse: restricted to analysis reuse-level 10 for analysis-save -> analysis-load
4. Tune: introduce --tune animation option which improves encode quality for animated content
5. Reuse CU depth for B frame and allow I, P frame to follow x265 depth decision
Bug fixes
1. RC: fix rowStat computation in const-vbv
2. Dynamic-refine: fix memory reset size.
3. Fix Issue #442: linking issue on non x86 platform
4. Encoder: Do not include CLL SEI message if empty
5. Fix issue #441 build error in VMAF lib
agressiv is offline   Reply With Quote
Old 23rd January 2019, 17:35   #6655  |  Link
Selur
Selur's Avatar
Sadly still unkown how they are related to the normal aq-modes,..
Old 23rd January 2019, 21:21   #6656  |  Link
benwaggoner
--hevc-aq overrides whatever --aq-mode is set to. I suspect that --aq-strength may get overridden itself, with --aq-adaption-range being the equivalent. Or both parameters could be used together, ala the interaction of CRF with maxrate/bufsize.
Ben Waggoner
My Compression Book
Old 24th January 2019, 04:57   #6657  |  Link
brumsky
@excellentswordfight
I've come to the same conclusion as well. merange should be based off of the CTU. If you leave CTU at 64 then merange should also be reduced. It'll be searching outside of it's original block. Not to say that is bad necessarily though. I've seen certain "high quality" encodes that use meranges larger than the CTU. I'm not 100% sold that it provides tangible differences thoughs.
I personally drop merange to 26 when using CTU 32. Since I never plan on using hex search I should probably change merange to 58 when using CTU64...
Best way to find out is to try it for yourself.
brumsky is offline   Reply With Quote
Old 24th January 2019, 05:28   #6658  |  Link
brumsky
I hope it does. I also hope AMD allows them to be fused like they current do with two 128-bit AVX FPUs that can run one 256-bit AVX2. If they do this then they will have the lead in AVX512!
Intel's top of the line 18 core CPU only has 2 AVX512 units on it. Imagine a Zen 2 CPU with up to 8 AVX512 fused units!!! I know there is an extra cycle or two when doing a fused operation but still up to 8 AVX512 operations will be nice!
Old 24th January 2019, 05:31   #6659  |  Link
Selur
Selur's Avatar
okay
And here it get's confusing to me.
Questions are:
a. is '--aq-strength' an option for both '--aq-mode' and '--hevc-aq' or just '--aq-mode'?
b. is '--aq-adaption-range' an option for both '--aq-mode' and '--hevc-aq' or just '--hevc-aq'?
Cu Selur
Old 24th January 2019, 09:04   #6660  |  Link
nevcairiel
Other then compatibility, that really doesn't offer anything. AVX/AVX2 instructions making use of those 256-bit units would be about the same speed.
256-bit AVX on current Ryzen isn't that much faster then 128-bit SSE due to that.
In any case, there have been zero hints about AVX512 support.
