Old 18th April 2010, 11:46   #1281  |  Link
Marvel
Hey MrC ME again , I seem to be having trouble with audio after converting a .mkv to dvd.
If i have dvd compliant audio ticked the end result has no sound,
then if i untick compliant dvd audio and encode audio to ac3 448 the process just hangs until i close the cmd promt window, avstodvd carrys on after this and there is audio in the resulting dvd files but because of the errors i dont know if everything is ok :P (Thats with wavi + aften)
I tried changing to ffmeg+aften but this resulted in audio errors also. Sound went off after 5mins in
I'm now trying mp2 as output audio so hopefully that will work for me. Anyway after all that i was wanting to make a feature request, would it be possible to have a recover mode so avstodvd will just pick up from a certain point like video or audio encoding, because at the moment everytime i make a settings change i have to go through the whole process again. Which is annoying because the video is fine
M.
Marvel is offline   Reply With Quote
Old 18th April 2010, 18:04   #1282  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@Marvel
You may try with QuEnc as audio converter as well. BTW, to understand better what's the problem, can you copy&paste here the log files of your trials?
About recover mode, here you are a workaround: delete the log file (i.e. test_0.log) and the audio file with error (test_0.ac3) and leave the video file (test_0.m2v). Next time you start the project (test), you will be asked to keep the video file (test_0.m2v). Easy, isnt'n it?
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
MrC is offline   Reply With Quote
Old 20th April 2010, 13:23   #1283  |  Link
Rosetta
Hi MRC, I have a .sup tsMuxer extracted with a mt2s. When I add in the movie AVStoDVD I recognize the file and I can copy to perfection. But when playing the movie the subtitles are not displayed. You think I can be doing wrong. Thanks
Rosetta is offline   Reply With Quote
Old 20th April 2010, 20:28   #1284  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Hi Rosetta,
unfortunately BluRay sup are not 100% compliant with DVD sup. I may suggest you following (not so confortable) steps:
- convert BD sup to sub/idx using BDSup2Sup
- convert sub/idx to DVD sup using Sub2Sup or VSConv (the latter is included with A2D package)
- check the resulting sup with SubtitleCreator (with A2D package as well)
Any other suggestion is welcome
Bye
MrC
AVStoDVD Homepage
Old 22nd April 2010, 23:51   #1285  |  Link
qyot27
qyot27's Avatar
About three weeks ago I used AVStoDVD to author a showcase disc of stuff and it went great (worlds better than my struggling with dvdauthor-centric solutions for months), so I'm very grateful. In testing other files with it recently, I ran across a couple things that present some problems. I'm only using already-encoded MPEG-2/AC3 files, with the 'Keep DVD Compliant Video/Audio' options selected so no transcoding is supposed to be going on. I'm using the 2.3.0 alpha 100323 version.
*I was relieved to see that 352x240/352x288 resolution files are accepted and actually kept at their resolution, but even though I know they're compliant (all files are encoded with the newest HCenc 0.24 beta, and the VCD-resolution/CIF stuff uses the exact same features as the Full D1 files, except for the average and max bitrates being set to 2000kbps), they still get re-encoded instead of passed through.
*If the video and audio track order are switched, it fails to identify the audio correctly and aborts. mplex from MJPEGTools isn't affected by this because it always puts video first. But mplex1 (from here: http://members.aon.at/johann.langhofer/mplex1.htm) puts the audio track first. Even tcmplex (which I mention because its logging messages are very close to those of mplex1, although I'm unsure of what the connection between them is) puts the video track first. It has to do with the 'map' parameter passed during the audio demux step. I'm guessing that's for those cases where the file has more than one audio track? If that's the case, is there a way to specify use of it only when the file has more than one audio track?
The command used for mplex:
mplex -f8 -V in.m2v in.ac3 -o out.mpg
The command used for mplex1:
mplex1 in.m2v in.ac3 out.mpg
I've uploaded the logs from AVStoDVD and source .mpg samples (a Full D1 mplex-muxed file as a successful control example, a Full D1 mplex1-muxed file, and two VCD-resolution/CIF files, one muxed with mplex and the other with mplex1), just in case you need them.
http://www.mediafire.com/?yomwjc2jngn
Old 23rd April 2010, 13:52   #1286  |  Link
knopper09
Originally Posted by Adub View Post
Yes, but the author said that he will only support free software. Ergo, CCE support will not be added. Besides, HCenc is freakin' fantastic.
yes thats true! So it should not be included, but only supported for those who have CCE.
From my experience i can also tell that it is definitely faster than all other encoders, because its written in assembly!
And i also think nearly everyone here knows how to get it for free, its only one small dll file. No one would really ay 2000 bucks for an MPEG2 Encoder. That’s the point!
So support would in AVStoDVD would be fine!
knopper09 is offline   Reply With Quote
Old 24th April 2010, 21:05   #1287  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@qyot27
About the 1st issue, the A2D routine that check if a clip is dvd compliant reads the 'Video'/'Standard' MediaInfo tag. If that tag is PAL or NTSC, then the routine goes ahead to check width, height and fps, otherwise it stops deducing that the clip is not dvd compliant. Unfortunately, even if it is surely a NTSC dvd compliant clip, MediaInfo says that your 'test-vcd-mplex.mpg' is not following the NTSC standard. I can improve my routine, but it would be much much better if MediaInfo would recognize your clip properly.
About the 2nd issue, you are right, I have already found some containers in which the audio track is mapped as first track and video as second one. When using audio direct stream copy (keep compliant audio) there are some problem in passing to ffmpeg the correct tracks map. I can add a workaround to this occasional anomaly by promting the user to edit the ffmpeg command line, if the adv option 'edit command params at runtime' is on, of course. What do you think?
BTW, it is really weird that mplex1 swap the video/audio tracks order. I wonder is there is any rationale behind that.
Bye
MrC
AVStoDVD Homepage
Old 25th April 2010, 02:25   #1288  |  Link
qyot27
qyot27's Avatar
Originally Posted by MrC View Post
@qyot27
Ok, that makes sense. I've asked about it on the Mediainfo thread, so hopefully it'll be fixed.
What about basing the command on the # of audio tracks? I would assume that files with the audio track first usually have only 1 audio track, not multiple ones. Therefore, if it detects only one audio track, regardless of track position, to just leave the map parameter out.
Unless this would have other consequences to the rest of the authoring process, anyway. Files that have more than one audio track in the positions before the video, or other 'weird' configurations of audio (like track 1 and track 3 are audio, track 2 is video or something) would probably still be affected, though.
Old 25th April 2010, 17:24   #1289  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Good point. That should cover 99% of the cases.
for the suggestion
Bye
MrC
AVStoDVD Homepage
Old 1st May 2010, 18:44   #1290  |  Link
8ternity
8ternity's Avatar
HI Mrc.
Im having to audio on the exported project. I used Qenc audio decoding and also Qenc for video deconding. I have updated ffmpeg because the version stock with avstodvd is crashing on 2pass conversion. With the update of ffmpeg, it has been resolved and 2pass video conversion complete verry well. But my exported project contain no audio.
Source audio is DTS from an m2ts 720p movie.
<2010-05-01 00:41:14>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 1
DVD Size: 4450/4450 MB (100%)
DVD Output Setup: DVD Folder
DVD Label: IMAGINARIUM
DVD Menu: No Menu
Output Folder: E:\DVD
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
AVS Source Filter: DirectShowSource
AVS Resize Filter: Lanczos4Resize
Video Resolution: 0
Video BitRate Min: 2500
Video BitRate Level 1: 6000
Video Profile Level 2: 6000
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
DVD Audio Format: 0
DVD Audio BitRate: 448
Keep DVD Compliat Audio: 1
Normalize Audio: 0
DVD Audio Language: FR - French
DVD Subs Language: FR - French
Chapthers Interval: 5
Use Source Chapters: 1
DVD Burning Drive: G: SONY DVD RW DRU-V200S 1.60
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Save Log file: 1
Unload ActiveMovie library: 0
Adjust ffdshow mixer: 1
TITLE 1 SOURCE FILES
Video: E:\DVD\imaginarium.m2ts
Info: AVC - 6593 kbps - 1920x1080 - DAR 1,778 - 24 fps (CFR) - Progressive - 2:02:38 hours - 176606 frames
Audio: E:\DVD\imaginarium.m2ts
Info: DTS - 1536 kbps - CBR - 48000Hz - 6ch - 2:02:38 hours
Subs:
[MediaInfoLib - v0.7.26]
AVISYNTH SCRIPT
Video = DirectShowSource("E:\DVD\imaginarium.m2ts", convertfps=true, audio=false)
# Audio is frameserved by AviSynth just for Preview and Edit purposes.
Audio = DirectShowSource("E:\DVD\imaginarium.m2ts", video=false)
Video = Video.ConvertToYV12
#Using DGPulldown to upsize FPS
Video = Video.Lanczos4Resize(720,480)
AudioDub(Video, Audio)
START VIDEO ENCODING OPERATIONS
Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 2988,8 MB
HCenc Parameters: -ini "E:\DVD-TEMP\IMAGINARIUM_0_imaginarium.HCenc.ini"
HCenc ini file:
*INFILE E:\DVD-TEMP\IMAGINARIUM_0_imaginarium.avs
*AVSRELOAD
*OUTFILE E:\DVD\IMAGINARIUM_0_imaginarium.m2v
*LOGFILE E:\DVD-TEMP\IMAGINARIUM_0_imaginarium.HCenc.log
*MAXBITRATE 9000
*BITRATE 3407
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*BIAS 30
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 0
*SMP
*PRIORITY IDLE
*WAIT 2
<2010-05-01 03:38:36>
END VIDEO ENCODING OPERATIONS
Created File: E:\DVD\IMAGINARIUM_0_imaginarium.m2v (2989,8 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3429 kbps - 720x480 - DAR 1,778 - 24 fps (CFR) - Progressive - 2:02:38 hours - 176607 frames
START PULLDOWN OPERATIONS
DGPulldown Parameters: "E:\DVD\IMAGINARIUM_0_imaginarium.m2v" -srcfps 24.000 -destfps 29.97 -inplace -bff
<2010-05-01 03:50:43>
END PULLDOWN OPERATIONS
DGPulldown executed on File: E:\DVD\IMAGINARIUM_0_imaginarium.m2v (2989,8 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3429 kbps - 720x480 - DAR 1,778 - 23,976 fps (CFR) - Progressive (2:3 Pulldown) - 2:02:38 hours - 176427 frames
START AUDIO DEMUXING OPERATIONS
FFmpeg Parameters: -i "E:\DVD\imaginarium.m2ts" -acodec copy "E:\DVD\IMAGINARIUM_0_imaginarium.ToFix.dts"
<2010-05-01 09:04:43>
END AUDIO ENCODING OPERATIONS
Created File: E:\DVD\IMAGINARIUM_0_imaginarium.dts (656,3 MB)
OUTPUT AUDIO INFO: DTS - 1536 kbps - CBR - 48000Hz - 6ch - 1:00:46 hours
<2010-05-01 09:04:47>
PROCESS ABORTED DURING TITLE 1 AUDIO ENCODING OPERATIONS.
CHECK LOG FILE <E:\DVD\IMAGINARIUM_0.LOG> FOR MORE INFO.
Log file created by AVStoDVD Release 2.2.6
<2010-05-01 09:06:32>
START PROCESS
PROJECT SETTINGS
DVD Menu: No Menu
PREFERENCES
Video Resolution: 0
AC3 Audio Encoder: 2
DVD Audio Format: 0
Normalize Audio: 0
Save Log file: 1
Subs:
AVISYNTH SCRIPT
Encoding Profile: QuEnc CBR 1-pass
QuEnc Parameters: -i "E:\DVD-TEMP\IMAGINARIUM_1_imaginarium.avs" -o "E:\DVD\IMAGINARIUM_1_imaginarium.m2v" -b 3407 -1 -hq -novbr -scene -trell -aspectratio 16:9 -nointerlaced -mpeg2mux noaudio -dc 8 -priority 5 -auto -close
<2010-05-01 11:05:22>
Created File: E:\DVD\IMAGINARIUM_1_imaginarium.m2v (2988,6 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3407 kbps - 720x480 - DAR 1,778 - 24 fps (CFR) - Progressive - 2:02:38 hours - 176607 frames
DGPulldown Parameters: "E:\DVD\IMAGINARIUM_1_imaginarium.m2v" -srcfps 24.000 -destfps 29.97 -inplace -bff
<2010-05-01 11:34:37>
DGPulldown executed on File: E:\DVD\IMAGINARIUM_1_imaginarium.m2v (2988,6 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3407 kbps - 720x480 - DAR 1,778 - 23,976 fps (CFR) - Progressive (2:3 Pulldown) - 2:02:38 hours - 176429 frames
FFmpeg Parameters: -i "E:\DVD\imaginarium.m2ts" -acodec copy "E:\DVD\IMAGINARIUM_1_imaginarium.ToFix.dts"
<2010-05-01 11:39:42>
Created File: E:\DVD\IMAGINARIUM_1_imaginarium.dts (1323,7 MB)
OUTPUT AUDIO INFO: DTS - 1536 kbps - CBR - 48000Hz - 6ch - 2:02:35 hours
START DVD AUTHORING OPERATIONS
BatchMux Parameters: -arglist "E:\DVD-TEMP\IMAGINARIUM_1_BatchMux.ini"
BatchMux ini file:
-d "E:\DVD\IMAGINARIUM_1\VIDEO_TS"
-mxp "E:\DVD-TEMP\IMAGINARIUM_1_MuxMan.mxp"
-l "E:\DVD-TEMP\IMAGINARIUM_1_MuxMan.log"
-muxman "C:\Program Files (x86)\AVStoDVD\MuxMan"
-prio LOW
-v "E:\DVD\IMAGINARIUM_1_imaginarium.m2v"
-vidmode LB
-a1 "E:\DVD\IMAGINARIUM_1_imaginarium.dts"
-a1lang fr
-cellfr "E:\DVD-TEMP\IMAGINARIUM_1_imaginarium_MuxMan.txt"
-progfr "E:\DVD-TEMP\IMAGINARIUM_1_imaginarium_MuxMan.txt"
-chapfr "E:\DVD-TEMP\IMAGINARIUM_1_imaginarium_MuxMan.txt"
<2010-05-01 11:41:39>
END DVD AUTHORING OPERATIONS
Created Folder: E:\DVD\IMAGINARIUM_1 (3067,2 MB)
<2010-05-01 11:41:40>
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating.
8ternity is offline   Reply With Quote
Old 2nd May 2010, 15:25   #1291  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@8ternity
Some DTS tracks taken from BD are not DVD compliant (i.e. ES-DTS tracks @24bit, see this post). Today Alpha has a fix to handle that: no DTS-ES retaining, but conversion to AC3.
Let me know if that is your case.
What ffmpeg version have you found more stable and replaced the A2D one?
Bye
MrC
AVStoDVD Homepage
Old 2nd May 2010, 15:28   #1292  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
A new 2.3.0 Alpha is available to download.
Change log from previous Alpha:
- Added check on bitrate spikes causing DVD Authoring failure (from BatchMux log file)
- Added 'Resolution' as Audio Media Info
- Changed default Interlaced Encoding field order from BFF to TFF.
- Improved handling of input MPEG2 Video stream (ask for automatic indexing, ask for changing Video Standard at runtime)
- Improved support to DTS-ES audio track
- HCenc updated to 0.24 beta 04-04-2010
- MediaInfo updated to 0.7.30
Please, as usually, report any bug.
Bye
MrC
AVStoDVD Homepage
Old 2nd May 2010, 21:47   #1293  |  Link
Filbert
Thanks for new version. This might be a problem as AVStoDVD doesn't seem to recognize some DV-Sources. So in the "Auto Video Setup" DV-Source is unchecked and now Interlaced Encoding is Top Field although DV should always be Bottom Field.
(2.2.6. didn't recognize the DV too, but as there was BFF default for interlace encoding I didn't recognize it either).
Greets, Filbert
GENERAL INFO
PathName: H:\Test-Videos\[Source]\testrun.mov
FileName: testrun
FileExt: mov
FileSize: 69,8 MB
Container Format: QuickTime
Video Tracks: 1
Audio Tracks: 2
Text Tracks: 0
VIDEO INFO
Time: 19 seconds
Compression: DV
BitRate Mode: CBR
Avg BitRate: 24442 kbps
Min BitRate: 0 kbps
Max BitRate: 0 kbps
Resolution: 720x576
Display AspectRatio: 1.333
Pixel AspectRatio: 1.067
FrameRate Mode: CFR
FrameRate: 25 fps
Frame Count: 481
ScanType: Interlaced
Filbert is offline   Reply With Quote
Old 3rd May 2010, 17:51   #1294  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@Filbert
I would say 2 improvements:
- recognition of DV input file -> automatic selection of 'DV source', 'Interlaced encoding' and 'BFF'
- in 'Title Edit'/'Video', upon manual 'DV source', automatic selection of 'Interlaced encoding' and 'BFF'
Bye
MrC
AVStoDVD Homepage
Old 3rd May 2010, 19:59   #1295  |  Link
Filbert
That would be ideal...
Greets, Filbert
Old 5th May 2010, 15:11   #1296  |  Link
Flux
Flux's Avatar
Here is Avisynth script:
LoadPlugin("G:\AVStoDVD\Lib\ffms2.dll")
Audio = FFAudioSource("G:\testi\big_buck_bunny_720p_surround.avi", track = -1, cachefile = "F:\DVD\Temp\A2DFFA_" + String(Rand()) + ".cache")
Video = FFVideoSource("G:\testi\big_buck_bunny_720p_surround.avi", track = -1, cachefile = "F:\DVD\Temp\A2DFFV_" + String(Rand()) + ".cache", seekmode = 0)
Video = Video.Spline36Resize(720,576)
Audio = Audio.Normalize()
If I add "AssumeFPS(25,true).SSRC(48000)" as last line and remove "#Using DGPulldown to upsize FPS" line, Avisynth throws "FFAudioSource: The index does not match the source file" red line error in Preview and Edit mode.
How I should use PAL 4% speed-up with FFMpegSource?
Interlaced, 50 Hz and 60 Hz, 24 fps film. These are evil artifacts from the past which still possess modern video technology.
Flux is offline   Reply With Quote
Old 5th May 2010, 20:47   #1297  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@Flux
We already had a similar discussion here and I strongly suggested you avoid AssumeFPS.SSRC (out of sync issue) and use ResampleAudio instead.
You can solve the FFAudioSource error using DSS for audio. I mean:
Audio = DirectShowSource("clip.avi", video=false)
AssumeFPS("pal_film",true).ResampleAudio(48000)
Or use DSS for video as well.
Bye
MrC
AVStoDVD Homepage
Old 6th May 2010, 01:11   #1298  |  Link
qyot27
qyot27's Avatar
Using SSRC to resample the audio back to the proper frequency doesn't do speed adjustments to it - it remains at the speed that AssumeFPS took it to. I just tried it using a 23.976fps file and a copy of Pearl Jam's "Jeremy". I did AssumeFPS(29.97,sync_audio=true).SSRC(48000,fast=false), and the resultant 48000Hz Wave file was most definitely sped up, and still in sync with the video.
Old 9th May 2010, 02:21   #1299  |  Link
bagheera1
bagheera1's Avatar
Option Request
On the Encoding tab, could we have an "Import AVS" option along with avisource, directshowsource, a2dsource.
I mostly have scripts ready and don't need the automatic resizing and audio import that goes on in the avisynth edit tab.
(sometimes I forget to delete everything but a single import line)
Thanks for a very usefull program.
bagheera1 is offline   Reply With Quote
Old 9th May 2010, 17:46   #1300  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@qyot27
I made some trials with AssumeFPS and SSRC/ResampleAudio some time ago (23.976 to 25 fps conversion) and ResampleAudio kept the A/V synch. Anyway if SSRC works from your side, then go with it.
@bagheera1
have you tried to add your AVS file directly in main window as input title?
Bye
MrC
AVStoDVD Homepage
[IMG] code is Off
