6th June 2012, 19:43 | #13261 | Link | |
The virtual display workaround works fine. |
7th June 2012, 02:47 | #13262 | Link |
I will make this one quick: The fix to my long post (regarding a problem with the new driver and sporadic stuttering) was to turn V-Sync off. I understand tearing issues - my old system (pre-MadVR) was terrible with tearing without D3D turned on. However, I have now watched a few movies since turning V-Sync off and I have yet to see any tearing. (I just need to make sure to set my refresh rate to a multiple of the source material and use ReClock.)
But I am a software engineer (lol who could not figure out a [code] tag and I like "correct" solutions. It seems to me that the new V-Sync is losing its lock on my file-stream. Does anyone know what I can try for a "real" fix of my issue? (Rather than giving up on V-Sync altogether?) Thanks again for bearing with me everyone! MikeY |
7th June 2012, 06:25 | #13263 | Link |
The virtual display workaround isn't convenient at all.
I'm used to quickly switching displays between LCD and projector via Win+P key, and I don't think it will position iGPU display correctly. The mouse will also tend to jump into another display - it' s annoying. Nevertheless, thanks for your suggestions - now I know that madVR is incompatible with VirtuMVP, and there still exists a (not perfect) workaround. |
7th June 2012, 12:45 | #13264 | Link | |
8th June 2012, 01:04 | #13266 | Link |
Right, but most of the time I leave IVTC on anyway and it just detects the cadence as 2:2 and no problems. The issue here was the option that only looked at the frame center; with that option enabled certain scenes would stutter. Unchecking that option and still leaving IVTC on would cause no problems.
What I do is just force Film Mode so I don't have to keep switching it, so it stays on for PAL content too and I usually have no problem since it can't get IVTC'd anyway. My last question was in regards to leaving IVTC on even when you don't need it and whether that is recommended or not. |
8th June 2012, 03:55 | #13267 | Link |
What kind of material is it? Ideally you shouldn't have to look on the center of the frame only, but TV stations put up logos in the borders that run at 60i, messing up IVTC.
MSI MAG X570 TOMAHAWK WIFI, Ryzen 5900x, RTX 3070, Win 10-64. Pioneer VSX-LX503, LG OLED65C9 |
8th June 2012, 05:21 | #13268 | Link |
Film material, retail PAL DVD. The confusing part is that having it look at the entire frame turned out fine, but when it looked at just the center it glitched. It's not like this was consistently happening, either, but there were around 4-5 times that this happened through-out the film. At first I didn't suspect that it was because of this new option, but I turned it off just to test and it turned out to be the culprit
8th June 2012, 06:49 | #13269 | Link |
What I meant is that that option to look in the center only is a workaround for the stupid animated logos and ads TV stations put on their shows. It is expected that for normal content without logos, looking at the whole screen would perform better, and in fact that's what madshi recommends for content like animation.
8th June 2012, 15:11 | #13270 | Link | |
No, but you need 2:2 cadence detection to determine whether content is 50i or 25p.
DGMPGDec will let you cut a section from the DVD.
Personally I just force film mode, because there's virtually nothing I have which is not 25p. Last edited by 6233638; 8th June 2012 at 15:15. |
8th June 2012, 18:24 | #13271 | Link | |
_
If you disable Vsync totally (you have to stop Aero for that), you will not have tearing if you use madVR D3D mode... |
9th June 2012, 12:32 | #13272 | Link | |
EDIT: I have just tested this with a 1.85:1 aspect ratio film, and there absolutely is screen tearing with Aero off and V-Sync disabled. It happens to be right near the top of the image though, so it's probably not visible with 2.37:1 films as it will be hidden in the black bars. Last edited by 6233638; 9th June 2012 at 12:43. |
9th June 2012, 16:24 | #13273 | Link |
Hello,
Guys i have "intel I5 480M" processor, when playing 10 bit video using MadVR the colors of the video will be bad, here is a picture : http://i.imgur.com/tdfOV.jpg http://i.imgur.com/eQhnh.jpg also i have the lastet driver & direct x version .. what's the solution ? |
10th June 2012, 10:27 | #13278 | Link |
@Qaq
http://i.imgur.com/eQhnh.jpg it's already using PO16 input, but like i said the colors are too bad .. |
10th June 2012, 11:16 | #13279 | Link |
/人 ◕ ‿‿ ◕ 人\
For that broken video disable evrything except RGB24/32 in "Ouput formats". Since LAV doesn't support YCgCo it would also produce "correct" result.
After watching - try writing trojan that will delete any file with name "x264" and send it to the person who encoded that video. He already posted screenshot with P010 decoder output! |
10th June 2012, 11:49 | #13280 | Link |
@vivan
I'm so stupid! i tried 4 "10 bit" videos all of them from the same person, after that i noticed the problem was from his videos! xD , so now i can watch "10 bit" videos with P016 input normally.. =) but another problem, there is dropped frames when i use madVR = ( |
