31st December 2011, 17:29 | #11721 | Link | |
It's nothing to do with madVR. |
31st December 2011, 17:55 | #11722 | Link | |
Can you turn on hyperthreading to test ? Using my i970 (6+6 cores) I have < 10% load on decoding h264 1080p60 with software lav decoder. The benchmark says 360 fps average on same h264 1080p60.. This is all with hyperthreading on and put the number of threads on 12 in LAV-video. i970@3.6 / Rampage III extreme / 24GB DDR3@2000Mhz / GTX 570 (very similar as yours ) Last edited by Pat357; 31st December 2011 at 18:04. |
31st December 2011, 19:19 | #11723 | Link | |
suppose 2 frames from the 24fps movie : 1 2 for displaying on 60 Hz we need 5 frames for the 2 frames above. (60/24 *2 = 5) going like this : 1 1 2 2 is for 48 Hz monitor 1 1 X 2 2 where X is blending frame 1 en 2, for 60 Hz monitor. This should give fluent playback from 24 fps movie content on a 60 Hz monitor. I hope Madshi will find some time to implement this in MadVR. PS: for 23.976 and similar content one could use Reclock to speed up to 24 fps Last edited by Pat357; 31st December 2011 at 19:29. |
31st December 2011, 19:57 | #11724 | Link | |
31st December 2011, 20:26 | #11725 | Link |
MPC hard crashes on DVD menus...the cursor will show the spinning time-out animation, menu music stops and the program will crash shortly after. I don't know if this is an MPC or madvr problem or how I can help solve it. I'm using ffdshow as the mpeg2 decoder, a GT240 with 275.33 drivers and Windows 7 32-bit
This is so frustrating, I can't even tell you the unimaginable amount of times it happens...8 out of 10? Last edited by JarrettH; 1st January 2012 at 00:15. |
31st December 2011, 21:29 | #11726 | Link |
I think I've had this problem for a while now, but it seemed intermittent and I didn't really care that much. Just recently I decided to check it out, and narrowed it down to it happening the first skip after a refresh rate change. After it freezes and you close, it doesn't happen until after you play the next file with a different refresh rate. Using D3D11 fixes it completely, but it has its own problems.
MSI MAG X570 TOMAHAWK WIFI, Ryzen 5900x, RTX 3070, Win 10-64. Pioneer VSX-LX503, LG OLED65C9 |
1st January 2012, 12:35 | #11727 | Link | |
I tried clean install of everything but still happens from time to time. Win7 64bit Mpc,madVR,lav filters,ffdshow raw video filter(for svp) and ati card(catalyst 11.11 and 11.12 involved). Last edited by Damien147; 1st January 2012 at 12:37. |
1st January 2012, 15:05 | #11728 | Link | |
Therefore, there must be something that Microsoft's renderer does, which gives that smooth flow of the video, without micro-stutters. |
2nd January 2012, 00:42 | #11732 | Link |
You said ask a few months later back in April, so here we go
Any chance we could get a few additions to the keyboard shortcuts? Also you make mention of them becoming adjustable in a future version which would be nice to see, thanks. |
2nd January 2012, 04:24 | #11733 | Link | |
I was also thinking it would be nice to automatically switch deinterlacing on when switching to film mode (CTRL+ALT+SHIFT+T), fwiw.
Windows 7 x64 i7 870 16GB RAM AMD 6870 |
2nd January 2012, 07:28 | #11734 | Link | |
that is what i suggest to anyone who can't use madvr for some reason. Although, before you do that, you have tried bilinear chroma in madvr? Also, you can try overclocking the gpu a little. Last edited by mindbomb; 2nd January 2012 at 07:30. |
2nd January 2012, 17:36 | #11735 | Link | ||
facing a very unique problem.some time ago i posted this
now i am facing the exact same problem on same 2 videos on an asus laptop having core i5 2.4GHz,4gb ram,windows 7 x64 sp1 & nvidia GT540m 2gb card.madvr 0.80 windowed mode with all default settings & use separate device for presentation off.these 2 videos play fine full screen on laptop 1366*768 screen.however when connected to LG 32" 1080p TV these 2 videos show massive no. of delayed frames & continuous increase in dropped frames with render queue dropping sometimes to 5-6/16 & back buffer queue 0-3/3 while decoder queue & upload queue are full.this problem only happens on 32" 1080p LG TV watching in full screen but these same videos run fine on laptop screen in full screen mode & in a smaller video window on 32" TV.i am using only lav filters & pot player but also tried mpc-hc with its own filters with same result. Last edited by whitestar999; 2nd January 2012 at 17:39. |
2nd January 2012, 17:54 | #11736 | Link | |
Its also possible that the performance just isn't enough if it uses the iGPU instead of the dGPU (i assume its one of those hybrid things). Maybe try forcing the dGPU? Also try choosing faster algorithms, like bilinear, just to check if thats a cause.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 2nd January 2012 at 18:08. |
2nd January 2012, 18:07 | #11737 | Link | |
2nd January 2012, 18:17 | #11738 | Link |
@nevcairiel,i used gpu-z & even enabled logging option while video was playing in full screen just to make sure.gpu load never went above 45% & memory usage was ~330mb.i added pot player in nvidia control panel application settings to use nvidia max performance mode & confirmed it again by monitoring gpu usage in gpu-z.
@Pat357,the 2gb ram is dedicated along with 4gb system ram.it is ddr3 with 128bit bus width & 28.8GB/s bandwidth. http://in.asus.com/Notebooks/Versati...ormance/K53SV/ edt:tried bilinear too with same result.even turned subtitle animation off but still no change. these are the 2 videos: http://www.fileserve.com/file/jFc6PHQ http://www.fileserve.com/file/P9JkM84 Last edited by whitestar999; 2nd January 2012 at 18:40. |
2nd January 2012, 18:57 | #11739 | Link | |
Feature Request: CPU/GPU usage percentage in OSD instead of having to juggle between video and GPU-Z. Thank you! EDIT: I just tested both those files. Working flawlessly here even on low end system using the values mentioned. Hope it helps!
Motherboard: GIGABYTE GA-990FXA-D3 Processor: AMD FX 8150 Black Edition 8-core @3.6 Ghz. RAM: G-Skill Ares 16GB dual channel DDR3. GPU: 2X Crossfire AMD RADEON HD 6850. OS: Windows 7 Utlimate x64. Last edited by Paladin77; 2nd January 2012 at 19:05. |
2nd January 2012, 19:20 | #11740 | Link |
will try your suggestion paladin77 later as i don't have access to TV now.btw your msi notebook resolution is not full HD.i can run these videos fine on my laptop 1366*768 screen.i only face problem running these 2 particular videos on a 32" full HD TV in full screen mode & even there i can run these videos fine in a small video window.
