31st July 2015, 22:29 | #32321 | Link |
Did you do the recent upgrade or are you one of the ones that have been using Windows 10 for a few months already?
Intel i5 3470, EVGA GTX 1050Ti SC ACX 2.0, Windows 10 Pro 64 bit, 16 GB 1600 mhz DDR3 RAM |
31st July 2015, 22:40 | #32322 | Link | |
I notice that FSE/Windowed mode switch in madVR is faster, but in jRiver, it seems to switch a few times unnecessarily compared to MPC-HC, not sure really. I did use DDU to remove the old Win7 AMD driver and then installed 15.7.1 after the Win10 install was completed. No issues. Only thing so far is no NFS client for Windows... ;(
Win7Ult || RX560/4G || Ryzen 5 |
31st July 2015, 22:56 | #32323 | Link | |
so directx 9 <-> interop simply works under windows 10. i don't know why they removed it but windows 10 supports directx 9 <-> openCL interop if they like or not. |
1st August 2015, 08:34 | #32325 | Link | |
Original image @ 720p | No sharpen | SuperRes 1.0 | SuperRes 4.0 Look at the text. No sharpening looks best to me. SuperRes at 1.0 strength starts to alias. 4.0 looks downright comical. I'm using the latest version of madVR. |
1st August 2015, 08:58 | #32326 | Link | ||
1st August 2015, 11:12 | #32327 | Link |
So everyone posted on nvidia forum and nvidia bug site about the 353.50+ driver that doesn't work with NNEDI3 . and the 353.49 not working with CUVID ?
I hope next driver they will fix it. Last edited by x7007; 1st August 2015 at 11:15. |
1st August 2015, 15:22 | #32330 | Link | |
1st August 2015, 15:27 | #32331 | Link | |
Posts: n/a
Simply select DXVA2 (Copy-Back) in LAV Video decoder/filter and you'll get better performance and no artifacts. |
1st August 2015, 17:05 | #32333 | Link | |
Ye but stupid windows 10 always auto update the driver and it doesn't let me hide it. |
1st August 2015, 17:29 | #32334 | Link | |
This thread is really getting dominated by Windows 10 talk though. I think there's probably enough for madshi to work through already, so let's try to get back on track with upscaling refinement feedback.
Test patterns: Grayscale yuv444p16le perceptually spaced gradient v2.1 (8-bit version), Multicolor yuv444p16le perceptually spaced gradient v2.1 (8-bit version) |
1st August 2015, 18:05 | #32336 | Link |
Well that didn't change anything. Still getting inordinately long wait times for an image to show up. Still getting a brownish outline (almost like the emboss shader from MPC-HC) of everything in a video when in FS/FSE when image doubling with Nnedi3. When I take a screenshot using F5, the screenshot looks perfectly normal :shrugs: .
1st August 2015, 18:52 | #32337 | Link |
@madshi
Hi, I might have found a bug in madVR.I am using madVR v0.88.21 in combination with the 64-bit RC of MPC-HC+CCCP. Since some time (I first noticed it with v0.88.14) the video often pauses when you leave the fullscreen mode. I already checked the settings of madVR, as well as MPC but wasn't able to find a checkbox or anything similar (The option "delay playback start until render queue is full" is also inactive). The problem didn't occur with older versions of madVR (and the same version of MPC). It was already there in Windows 8.1 and now continues to occur since I upgraded to Windows 10. It also doesn't happen if you select a renderer other than madVR. This is my setup: MPC-HC (CCCP Build, 64-bit) --------------------------- Build information: Version: 1.7.8.162 (d12a1c4) (blitzkrieg) (master@46ce9d6) Compiler: MSVC 2013 Update 4 Build date: May 4 2015 00:21:53 LAV Filters: LAV Splitter: 0.65.0.8 LAV Video: 0.65.0.8 LAV Audio: 0.65.0.8 FFmpeg compiler: MinGW-w64 GCC 4.9.2 Operating system: Name: Windows NT 10.0 (build 10240) Version: 10.0 (64-bit) Hardware: CPU: Intel(R) Core(TM) i5-2430M CPU @ 2.40GHz GPU: NVIDIA GeForce GT 540M (driver version: 10.18.13.5362) EDIT: I turned on debug OSD and it's always printing "Resetting Direct3D device failed (8876086c)" when you leave the fullscreen mode and the video stops. There's also sometimes a "dxva proccessing failed" message (when you open up a file, etc.) Last edited by Pantara; 3rd August 2015 at 02:39. |
1st August 2015, 19:56 | #32338 | Link | ||
Although queues don’t get filled with 24p and 60p refresh rate, there are no reported or perceptible dropped frames. The queues fill properly in windowed mode or D3D9 output. |
1st August 2015, 21:32 | #32339 | Link |
For what it's worth, NNEDI3 is still working for me with Windows 10 Nvidia drivers and a GTS 450.
