Old 1st October 2008, 21:56   #3061  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Originally Posted by ultratoto14 View Post
Yes, this works with DGAVCIndex
I said DGAVCDecode.dll not DGAVCIndex...
what are the checks done between the enqueue button push and the real add in the job queue ? Is there some plugins added in the avs script or others ?
nope...
Old 1st October 2008, 22:01   #3062  |  Link
Nightshiver
Quality Freak
Will the next update fix my problem? I'm doing another encode now, but I'm not getting my hopes up.
Nightshiver is offline   Reply With Quote
Old 1st October 2008, 22:13   #3063  |  Link
ultratoto14
Sorry, my mistake, this is DGAVCDecode.dll that i tested. It worked with it. When i add it to the queue, meGui tells me that the avs is not mod16, this is why i think there is checks. (1920x1080)
ultratoto14 is offline   Reply With Quote
Old 1st October 2008, 22:14   #3064  |  Link
rica
Originally Posted by rica View Post
Problem is going on for me.
I've just downloaded 0.3.0.215 again from SourceForge.net.
Opened UAC. (I still have admin rights.)
Everything went fine this time: thanks guys.
rica is offline   Reply With Quote
Old 2nd October 2008, 00:17   #3065  |  Link
XxOsurfer3xX
XxOsurfer3xX's Avatar
Originally Posted by Kurtnoise13 View Post
@XxOsurfer3xX:
Megui is not even capable of making a log file, the folder is empty. Should i post the windows error report?
XxOsurfer3xX is offline   Reply With Quote
Old 2nd October 2008, 02:39   #3066  |  Link
Nightshiver
Quality Freak
Nope, the update Kurtnoise provided didn't work (as expected). :/
Stopped at the same frame number and crashed.
Old 2nd October 2008, 03:18   #3067  |  Link
xenonsniper
hi guys.
i was running MeGUI just like i normally do and i kept getting this acisynth error: "script error: there is no function named dgdecode_mpeg2source"
i googled it and i found this thread:
http://forum.doom9.org/archive/index.php/t-118803.html
problem is that i'm running a 32bitOS. i checked my reg entry in regedit and it turns out that my plugins directory was set to "F:avisynth/plugins" i changed it to C:/ but it didn't fix it, so what should i do?
ah i fixed my problem; after carefully rereading the thread, i saw the user said that he couldn't change the directory where dgdecode.dll was located. i gave it a shot and it worked.
xenonsniper is offline   Reply With Quote
Old 2nd October 2008, 07:13   #3068  |  Link
Kurtnoise
Kurtnoise's Avatar
oo right...forgot this.
mmmh, what can I say...while I don't have a NV card, I can't debug this. You know does it mean ?
Old 2nd October 2008, 07:14   #3069  |  Link
Kurtnoise
Kurtnoise's Avatar
mmh, yeah...
Old 2nd October 2008, 10:05   #3070  |  Link
XxOsurfer3xX
AppName: megui.exe      AppVer: 0.3.0.2015     AppStamp:48d2b6e3
ModName: kernel32.dll      ModVer: 5.1.2600.5512      ModStamp:4802a12c
fDebug: 0       Offset: 00012aeb
It wont let me copy the error report ...
Old 2nd October 2008, 12:24   #3071  |  Link
Nightshiver
Quality Freak
I might have found the culprit. It seems that mencoder itself is broken. I found this thread to be helpful: http://forum.doom9.org/showthread.php?t=124374
Although I haven't tried my script out yet using an earlier version of mencoder.
Old 2nd October 2008, 13:05   #3072  |  Link
saint-francis
too much lurking
saint-francis's Avatar
@Kurtnoise13 Does MeGUI automatically re run the eac3to command if there are gaps/overlaps detected?
saint-francis is offline   Reply With Quote
Old 2nd October 2008, 13:09   #3073  |  Link
Kurtnoise
Kurtnoise's Avatar
isn't already automatic ?
Old 2nd October 2008, 13:48   #3074  |  Link
hajj_3
some crashes i experienced in a recent megui and x264 build, these were when i had opened a .avs file in avs script creator as i was wanting to determine how much to crop top and bottom on a bluray movie. I was scrolling through the video and experienced this crash message, the application worked fine though, kept functioning:
same with the below screenshot:
The bluray movie had VC-1 video and truehd audio, i used graphstudio, avsp, megui, x264, haali, ffdshow. The source was a single .m2ts file.
Old 2nd October 2008, 17:25   #3075  |  Link
saint-francis
too much lurking
I don't think so.
Old 2nd October 2008, 18:09   #3076  |  Link
Kurtnoise
Kurtnoise's Avatar
well...it's not my plan to run eac3to twice to apply gaps/delays. I'll add these values in the filename probably. The goal here is to extract only streams like DGindex.
btw, more than 30 commits today in the trunk. *sigh*
Old 2nd October 2008, 18:10   #3077  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
@Nightshiver: megui auto-update has already a newer mencoder build...
@kurtnoise: wow. thanks.
Old 2nd October 2008, 18:19   #3078  |  Link
saint-francis
too much lurking
The catch is that the extracted streams won't be particularly useful if the gaps aren't corrected. It's not delays, it's places in the audio tracks which don't match up with the video after joining multiple .m2ts files. So streams might be extracted but in order to use them the command will need to be run again. At least the audio part of the command. I think Atak_Snajpera made a request for madshi to make a switch that will automatically re run the command in the case of gaps/overlaps being detected.
I'm planning to automate the gap removal for audio in a future build.
Old 2nd October 2008, 18:33   #3079  |  Link
Kurtnoise
Kurtnoise's Avatar
did you have some discs where a gap is detected by eac3to ? If yes, could you post a log here please...
and could you post a command line to fix a such gap...
Old 2nd October 2008, 20:38   #3080  |  Link
Nightshiver
Quality Freak
Yes, that's the point. I think the problem is with the new mencoder, or do you have any better ideas as to why MeGUI consistently crashes?
megui
