Old 7th March 2017, 13:18   #1  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
New advanced Benchmark
Here the source:
http://jfl1974.free.fr/Benchmark/Benchmark.zip
1) x264 1080p 8 bits bt.709 with BD FHD H264 source
2) x265 2160p 10 bits HDR bt.2020 with ~BD UHD HEVC HDR source
3) decoding benchmark with libavcodec and ~BD UHD HEVC HDR source
4) Advanced x265 test for complete SIMD MMX, SSE, SSE2, SSE3, SSE4, AVX, FMA3, AVX2, FMA4, XOP
Update:
-14/04/2017: new automatic benchmark
try and report your result:
|  CPU (Ghz)     |   x264  |   x265  |   LAVC  |   auto  |   MMX2  |    SSE  |   SSE2  |   SSE3  |   SSE4  |    AVX  |   AVX2  |    All  |
| i5-3550@3.50   |   7.12  |   1.04  |   48.0  |   0.84  |   0.35  |   0.35  |   0.54  |   0.58  |   0.86  |   0.86  |   N/A   |   N/A   |
| i7-5960X@4.40  |  24.03  |   4.38  |  150.0  |   3.50  |   1.01  |   1.01  |   1.64  |   1.78  |   2.78  |   2.80  |   3.43  |   N/A   |
| R7 1700@3.75   |  21.66  |   3.45  |  110.0  |   2.74  |   1.00  |   1.01  |   1.67  |   1.87  |   2.61  |   2.60  |   2.67  |   N/A   |
| x5670@4.00     |  11.33  |   1.58  |   69.0  |   1.32  |   0.56  |   0.56  |   0.88  |   0.94  |   N/A   |    N/A  |   N/A   |   N/A   |
| i7-4770K@4.50  |  10.89  |   2.11  |   72.0  |   1.75  |   0.49  |   0.49  |   0.80  |   0.86  |   1.34  |   1.37  |   1.62  |   N/A   |
| i7-2600K@4.20  |   9.27  |   1.33  |   58.0  |   1.10  |   0.44  |   0.44  |   0.70  |   0.75  |   1.10  |   1.11  |   N/A   |   N/A   |
| i5-2500K@4.50  |   6.95  |   1.15  |   52.0  |   0.98  |   0.41  |   0.41  |   0.61  |   0.66  |   0.96  |   0.95  |   N/A   |   N/A   |
| R7 1700@stock  |  18.51  |   2.98  |  103.0  |   2.32  |   0.96  |   0.95  |   1.41  |   1.54  |   2.11  |   2.05  |   2.08  |   N/A   |
| R7 1700X@stock |  20.61  |         |         |         |         |         |         |         |         |         |         |         |
| R7 1800X@stock |  21.28  |   3.42  |  118.0  |   2.72  |   1.13  |   1.13  |   1.71  |   1.83  |   2.52  |   2.53  |   2.65  |   N/A   |
| i7-6700K@stock |  11.95  |   2.28  |   82.0  |   1.89  |   0.56  |   0.55  |   0.88  |   0.97  |   1.47  |   1.50  |   1.85  |   N/A   |
| i7-7700K@stock |  14.02  |         |         |         |         |         |         |         |         |         |         |         |
| i7-5960X@stock |  18.18  |   3.30  |  116.0  |   2.66  |   0.76  |   0.76  |   1.23  |   1.33  |   2.09  |   2.09  |   2.58  |   N/A   |
| i7-6900K@stock |  19.83  |         |         |         |         |         |         |         |         |         |         |         |
| i7-6950K@stock |  22.10  |         |         |         |         |         |         |         |         |         |         |         |
| i7-4770@stock  |  10.30  |   1.89  |   67.0  |   1.55  |   0.43  |   0.44  |   0.71  |   0.76  |   1.21  |   1.21  |   1.51  |   N/A   |
| E5-2670@stock  |  12.64  |   1.80  |   79.0  |   1.50  |   0.62  |   0.62  |   0.94  |   1.02  |   1.46  |   1.50  |    N/A  |   N/A   |
x265 is new benchmark; You can find result for x264 here:
Le Sagittaire ... ;-)
1- Ateme AVC or x264
2- VP7 or RV10 only for anime
3- XviD, DivX or WMV9
Old 2nd April 2017, 23:30   #2  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
update
Old 3rd April 2017, 10:15   #3  |  Link
Brazil2
The archive is broken.
Benchmark.zip.007 is only 20 MB and with 7-zip the archive test fails at 225 files 88%: Data error: Benchmark\Sample\Sample1080p.ts
And once extracted Sample1080p.ts is only 22 882 817 bytes large (199 159 304 expected).
Brazil2 is offline   Reply With Quote
Old 3rd April 2017, 21:02   #4  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
I see that ... I (re)upload next weekend.
Old 8th April 2017, 16:26   #5  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
Update ...
Try and report your result please ...
Old 12th April 2017, 12:44   #6  |  Link
Danielcz
some error did not complete:
Danielcz is offline   Reply With Quote
Old 12th April 2017, 21:07   #7  |  Link
Motenai Yoda
Motenai Yoda's Avatar
Can you capture fps values and put them into a txt file?
also maybe adding -v quite to ffmpeg cli can help.
powered by Google Translator
Motenai Yoda is offline   Reply With Quote
Old 14th April 2017, 11:35   #8  |  Link
Selur
Selur's Avatar
using a R7 1800X@stock I got the same problem as Danilecz -> https://pastebin.com/xEd81pxZ
ffmpeg\ffmpeg.exe -i Sample\Exodus_UHD_HDR_Exodus_draft.mp4 -an -f rawvideo -   | x265\x265.exe --input-res 3840x2160 --fps 23.976 - -o Output\x265_2160p.265 --input-depth 10 --output-depth 10 --crf 24 --preset medium --tune grain --ssim --psnr --asm AVX,FMA3,FMA4,LZCNT,BMI1,BMI2,AVX2 --frames 100
aborts with:
frame=  105 fps=3.3 q=-0.0 size= 2551500kB time=00:00:04.37 bitrate=4777574.4kbiError writing trailer of pipe:: Broken pipe
frame=  105 fps=2.5 q=-0.0 Lsize= 2551500kB time=00:00:04.37 bitrate=4777574.4kbits/s speed=0.104x
video:2551500kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.000000%
Conversion failed!
Cu Selur
Old 14th April 2017, 13:41   #9  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
broken pipe with ffmpeg is normal because i use --frames 100 for SIMD test with x265.
benchmark work well with R7 1700@stock and R7 1700@3.75 ghz for 2 samples here in France.
I make new automatised benchmark: downlaod, retry and report your result. Thanks.
Old 14th April 2017, 15:41   #10  |  Link
Selur
Selur's Avatar
I'm still getting the:
av_interleaved_write_frame(): Invalid argument
Error writing trailer of pipe:: Invalid argument
but this time a results.log was created:
|     CPU             |   x264  |   x265  |   LAVC  |   auto  |   MMX2  |    SSE  |   SSE2  |   SSE3  |   SSE4  |    AVX  |   AVX2  |    All  |
|  Ryzen 7 1800X Eight-Core Processor          |  21.28  |   3.42  |   118  |   2.72  |   1.13  |    1.13  |   1.71  |   1.83  |   2.52  |    2.53  |   2.65  |    N/A  |
(I ran the Benchmark_auto.bat)
also ran Bechmark.bat an it runs through without a problem now
Old 14th April 2017, 17:46   #11  |  Link
Danielcz
i7 4770 stock (non-K), R9 290X, 32GB RAM, Win 7 utimate x64
|  Core i7-4770       |  10.30  |   1.89  |    67   |   1.55  |   0.43  |   0.44  |   0.71  |   0.76  |   1.21  |    1.21 |   1.51  |    N/A  |
Old 14th April 2017, 20:22   #12  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
yes ... really powerfull CPU this Rysen 7.
Old 14th April 2017, 23:03   #13  |  Link
Ma
On my i5 3450S (with enhanced turbo) x265 4K encoding speed was 1.06.
For curiosity I changed x265 to VS 2017 AVX version and the speed was 1.11. Then I used VS 2017 AVX PGO version and the speed was 1.15 (I added only '-v warning' to ffmpeg part to cleaner output).
Then I go to the decoding -- with included in benchmark ffmpeg the speed was 48 to 49, with Zeranoe ffmpeg 2017-04-11 it was 64, with compiled by GCC 7 today snapshot the speed was 66.
The speed difference in x265 encoding is normal, but it is surprising big difference in decoding speed.
Ma is offline   Reply With Quote
Old 15th April 2017, 08:07   #14  |  Link
RanmaCanada
| Xeon E5-2670 0 | 12.64 | 1.80 | 79 | 1.50 | 0.62 | 0.62 | 0.94 | 1.02 | 1.46 | 1.50 | N/A | N/A |
Old 15th April 2017, 12:29   #15  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
Yes i know for x265, I will try to introduce script to use best x265 compilation for each CPU ... ;-)
Anyway your ffmpeg result is really big surprise. You have link for ffmpeg 64 bit with GCC7 compilation?
Old 15th April 2017, 15:31   #16  |  Link
Ma
ffmpeg (without any libs) compiled by GCC 7 from snapshot 2017-04-14:
www.msystem.waw.pl/x265/ffmpeg-2017-04-14.7z
The ffmpeg2.exe is the same with '-O2' optimize option instead of default '-O3 -fno-tree-vectorize'. For my i5 3450S this ffmpeg2.exe is slightly faster.
It looks like ffmpeg is faster in decoding HEVC than one month before.
Old 16th April 2017, 16:31   #17  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
yes ... really higher speed.
THX for the ffmpeg build.
Old 16th April 2017, 16:43   #18  |  Link
shinchiro
Yeah..lots of hevc asm landed in ffmpeg's upstream recently, like:
http://git.videolan.org/?p=ffmpeg.gi...4dad7abaf9a93f
shinchiro is offline   Reply With Quote
Old 18th April 2017, 10:31   #19  |  Link
NikosD
Hey,
I have made a few corrections to your "run.sh" file in order to be more consistent to what is running and what is being displayed.
For example, there is no "SSE3" instruction set tested, it's "SSSE3" and so on.
Also, the "All" setting is actually like "auto" so we don't need that.
I added also --no-asm option and I named it "No SIMD" in the final text, in order to see better the speedups of various SIMD sets compared to "No SIMD" setting
All of my changes are here:
http://txt.do/drlqm
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
Old 18th April 2017, 19:00   #20  |  Link
SquallMX
Special SeeD
6700K Stock 4.0 Ghz
|  Core i7-6700K      |  11.95  |   2.28  |    82  |   1.89  |   0.56  |    0.55  |   0.88  |   0.97  |   1.47  |   1.50  |   1.85  |    N/A  |
SquallMX is offline   Reply With Quote
