Old 7th September 2008, 21:54   #981  |  Link
MasterNobody
kemuri-_9
Try to make 2pass encoding of small sample (500 frames is enough) with --threads 128 (128 because more threads more visible is quality degradation of few frames after 30-frame) without and with this patch. Probably than you will see the difference at frames 31 and few others.
MasterNobody is offline   Reply With Quote
Old 7th September 2008, 22:40   #982  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
and why would i realistically do that insane number of threads besides seeing at how many resources are being wasted by threads that can't be executed on my processors (being held in wait state)?
and not to mention all the processing time overhead from the thread swapping since the scheduler will probably swap them frequently with that large of a number of them.
custom x264 builds & patches | F@H | My Specs
kemuri-_9 is offline   Reply With Quote
Old 7th September 2008, 23:47   #983  |  Link
lexor
You are right, kemuri, most of us can't use that many threads. Still, I do know people who run their encodes on Sun's servers (when they are idling at their workplace), which do run 128 threads per box, so they would care about that.
Geforce GTX 260
Windows 7, 64bit, Core i7
MPC-HC, Foobar2000
lexor is offline   Reply With Quote
Old 8th September 2008, 00:37   #984  |  Link
Ranguvar
Ranguvar's Avatar
Oh yeah, and if you could explain x264_32x32samples_crash.r870.diff, forgot about that one. Thanks again.
Doing a few tests now...
Ranguvar is offline   Reply With Quote
Old 8th September 2008, 01:07   #985  |  Link
MasterNobody
This is only the example where you can see the difference easily. This bug (incorrect bitrate prediction) also exist with only 2-3 threads but it is not so visible.
It is simply fix the crash (division by zero) when width or height of the source is 32 (17-32) when you encode with B-frames (and don't use --no-b-adapt).
Old 8th September 2008, 01:32   #986  |  Link
Ranguvar
Ranguvar's Avatar
But this is very annoying... the patches are a mess of dependencies. Still trying to get it working, but jeez.
EDIT: Alright, I admit defeat. Every damn patch wants to bring in its friends, or it'll whine at me. komisar, if you read this, please help give me a way to test/use...
I only want:
x264_dll_alignment_fix.01.diff (no problem with your patches)
999.log_param.diff
x264_progress.indication_r957.diff
x264_multithreading_Nth_pass_ratecontrol.r870.diff (maybe)
bm_x264_thread_pool.r870.diff (maybe)
x264_hrd_pulldown.09_interlace.diff
x264_psy_rdo_0.6_r956.diff
x264_new_bframe_decision_04.7.diff
However, there are tons of dependencies... I really don't want to use the VAQ2mod, or fix_stats_file_work, or your version of the new b-frame decision patch...
Thanks
Old 8th September 2008, 04:25   #987  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
some of these, like the 32x32sample and Npass ratecontrol patches,
are fixes and I think the developers should look into implementing them into the repository.
(granted they work as intended still)
the logfile patch would be a feature they could add in if they whimmed it.
Old 8th September 2008, 04:51   #988  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Yes, I agree; such fixes should not be used in custom builds but rather should just be committed if useful or not committed if not useful.
Old 8th September 2008, 07:47   #989  |  Link
Gabriel_Bouvigne
L.A.M.E. developer
Gabriel_Bouvigne's Avatar
looked at it again and it's definitely complexing up the bitrate approximation/ratecontrol so it should be more accurate.
that is, bitrate aiming in multi-threading should be more accurate (though i don't usually have a problem with this in x264 as is)
Could someone please point me at this patch?
Gabriel_Bouvigne is offline   Reply With Quote
Old 8th September 2008, 07:51   #990  |  Link
Underground78
Underground78's Avatar
http://komisar.gin.by/x.patch/last.u...trol.r870.diff
Underground78 is offline   Reply With Quote
Old 8th September 2008, 11:04   #991  |  Link
komisar
komisar's Avatar
My used patches:
# Write to log encoding settings
999.log_param.diff (wo dep)
# Simply fix the crash (division by zero) when width or height of the source is 32 (17-32) when you encode with B-frames (and don't use --no-b-adapt)
x264_32x32samples_crash.r870.diff (wo dep)
# Fix incorrect Nth-pass ratecontrol work with multithreading
x264_multithreading_Nth_pass_ratecontrol.r870.diff (wo dep)
# More accurate calculation of i_frame, more correct workaround for VFW Nth-pass ratecontrol
k.20.x264_fix_stats_file_work.r877.diff (wo dep)
# Modified thread pool patch
bm_x264_thread_pool.r870.diff (dep: "fix_stats_file_work", "multithreading_Nth_pass_ratecontrol")
# Write encoder outputs to file
k.41.x264_log_file.01k.r928.diff (wo dep)
# Change precision of CRF-value in encoder settings
k.38.cosmetic.diff (wo dep)
# Add some addition task to profiling
999.profiled.01.diff (wo dep)
# Workaround of incorrect profiling of VFW (gcc 4.4)
k.vfw.01.dummy-log.diff (wo dep)
# Helper for make profiled build of VFW
k.vfw.02.profile.diff (wo dep)
# Add ability to call external gui for VFW
k.vfw.03.external_config.01.diff (wo dep)
Ranguvar
Some as posted in this thread. I only make this compatible with my patched build.
P.S. I add prefix "k.XX...." because this patches (in original) not clear apply and I make them more compatible. Or I make this patch by myself.
P.P.S. Original version of some patches "by MasterNobody/BugMaster" found here: [x264-devel] BugMaster's patches (fix various problems)
And mirror of MasterNobody/BugMaster patches (next message) found here: http://komisar.gin.by/x.patch/BugMaster/20080908/
..::[I am live here]..::..[My x264 CLI/VFW builds and tools]::..
komisar is offline   Reply With Quote
Old 8th September 2008, 12:25   #992  |  Link
MasterNobody
Here are updated versions of my patches (which I use to build x264vfw): http://stashbox.org/208351/bm_x264_p...ction.r965.zip
In this archive you will find independent versions of some patches (for example, x264_thread_pool.r965.diff)
List of patches in collection:
01_x264_32x32samples_crash.r965.diff
01_x264_cosmetic.r965.diff
01_x264_debug_defines.r965.diff
01_x264_fix_stats_file_work.r965.diff
01_x264_multithreading_bug_check.r965.diff
01_x264_multithreading_Nth_pass_ratecontrol.r965.diff
02_bm_x264_error_memoryleaks.02.r965.diff
03_bm_x264_thread_pool.r965.diff
04_bm_x264_vaqmod.01.r965.diff
05_bm_x264_psy_rdo_0.6.r965.diff
06_bm_x264_new_bframes_decision.04.7.r965.diff
Independent\
Old 8th September 2008, 12:55   #993  |  Link
Gabriel_Bouvigne
L.A.M.E. developer
The 32x32 fix seems really strange, especially the "pmb = -imb;" line. Did you intended to have a negative number of P MB ?
Old 8th September 2008, 16:11   #994  |  Link
Ranguvar
Ranguvar's Avatar
Thanks very much, BugMaster - that may be what I'm looking for. I'll test ASAP.
Will all your updated patches be here always? http://komisar.gin.by/x.patch/BugMaster/
Old 8th September 2008, 17:02   #995  |  Link
stanjr
Linux Encoder
I am compiling/encoding on a 64-bit Ubuntu quad-core machine.
Using x264_new_bframe_decision_04.7.diff causes the following error:
libx264.c: In function 'X264_init':
libx264.c: 165: error: X264_param_t has no member named 'b_bframe_adaptive'
(after compiling x264 and then when compiling mplayer to use x264 with mencoder)
Have I done something wrong?
stanjr is offline   Reply With Quote
Old 8th September 2008, 17:47   #996  |  Link
recover
recover's Avatar
I just wanted to let you know that there is an updated version of the progress indication patch here.
The difference is only that the code is now enclosed in #ifdef _WIN32 so that it can compile on other OS.
I guess you have to fix this updated version the same way you've done with the previous version as well.
recover is offline   Reply With Quote
Old 8th September 2008, 17:54   #997  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
it's useless for him since he's on ubuntu
Old 8th September 2008, 18:04   #998  |  Link
stanjr
Linux Encoder
What about the 'b_bframe_adaptive' error?
Old 8th September 2008, 18:07   #999  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
was the patching successfull?
Old 8th September 2008, 18:28   #1000  |  Link
stanjr
Linux Encoder
Yeah, patching x264 was successful and it compiled fine. It was only when I then got to compiling mplayer that I got the error. If you need more info, I can try to get what you need when I get home later.
h.264, x264, x264 builds, x264 patches, x264 unofficial builds
