Old 11th October 2004, 23:10   #41  |  Link
jggimi
Moderator Emeritus
jggimi's Avatar
Unfortunately, I must shut down this thread as well. VCD MASTER has been suspended for a month. I've left his links in here, as there may be some value in what he's trying to say, though he is apparently a poor communicator.
I hope he spends some time reading here, and gets to know this forum and its members, during his time off.
Additional comments on the capture guide must be posted in new threads.
"It is easier for a camel to pass through the eye of a needle if it is lightly greased."
Kehlog Albran, The Profit
jggimi is offline   Reply With Quote
Old 12th October 2004, 23:08   #42  |  Link
Wilbert
The thread is reopened on my request. Valuable comments, suggestions, etc. are welcome again!
@Windows XP Pro users,
Do other users of 'Windows XP Pro' have the same problem as emazur?
Old 13th October 2004, 05:31   #43  |  Link
emazur
If the .chm file issue is solved that would be nice, but as long as I'm here I have some criticisms of the guide
I'm following the "removal of chroma artifacts" section (using avisynth),
http://www.doom9.org/capture/chroma_artefacts.html
but find that it jumps around a bit, and doesn't "piece it all together" and provide a general example for eliminating the 3 main chroma artifacts as shown in the guide (12.1: chroma noise, 12.2: chroma shift, 12.3: rainbow/dotcrawls). And I'm unsure of the correct order of the usage.
In my case, I'm trying to convert near/lossloss avi to vcd mpg at the moment (also interested in high quality dvd mpg), using dvd2svcd. My thread in dvd2svcd forum is here:
http://forum.doom9.org/showthread.php?s=&threadid=83133
As mentioned in the thread I managed to piece together this script for avisynth. If it's good or flawed, I don't know:
0=Trim(2155,58642) ++ Trim(62784,74846) ++ Trim(78458,91135) ++ Trim(94732,115285) ++ Trim(118978,124282)
1=ChromaShift(C=-6)
2=GuavaComb(Mode = "NTSC", Recall = 75, MaxVariation = 25, Activation = 40)
3=PeachSmoother()
4=BicubicResize(^TargetWidth+^BorderLeft+^BorderRight,^TargetHeight+^BorderTop+^BorderBott
om,^b_value,^c_value)
^b_value=0.0
^c_value=0.6
Actually this was the original script I made, but for some reason the CNR2 function crashes CCE . Anyone know why and/or what I should do about it? If I open this avs in media player it plays OK
1=Cnr2("xxx", 4, 5, 255)
2=ChromaShift(C=-6)
3=GuavaComb(Mode = "NTSC", Recall = 75, MaxVariation = 25, Activation = 40)
4=PeachSmoother()
5=BicubicResize(^TargetWidth+^BorderLeft+^BorderRight,^TargetHeight+^BorderTop+^BorderBott
^b_value=0.0
^c_value=0.6
emazur is offline   Reply With Quote
Old 13th October 2004, 06:47   #44  |  Link
Boulder
Pig on the wing
Boulder's Avatar
What version of CNR2 do you have? v2.61 is the only one working properly.
Old 13th October 2004, 07:04   #45  |  Link
killingspree
Newbie Forum Mod
killingspree's Avatar
nope... just checked again, working perfectly fine... winXP SP1 (still) - so i can't say anything about SP2 jet
steVe
edit: ahm, of course WinXP Pro SP1
Search the forum, read the forum rules once more and use the search function on doom9.org before posting!
oh btw my amazon.de wishlist
killingspree is offline   Reply With Quote
Old 13th October 2004, 09:38   #46  |  Link
Arachnotron
Alias fragger
Arachnotron's Avatar
Not with the us version of XPpro SP2. It opens just fine.
Arachnotron is offline   Reply With Quote
Old 13th October 2004, 14:11   #47  |  Link
emazur
2.4, I got it from the author's page:
http://ziquash.chez.tiscali.fr/
I see avisynth.org has 2.61 linked on their external filters page, I'll try that later.
Also for anyone who's wondering my winxp is sp1. It's running quite nicely now, so I'm not looking to risk mucking it up with sp2.
Old 23rd December 2004, 13:59   #48  |  Link
Arachnotron
Alias fragger
Hi Wilbert,
I just noticed
http://www.doom9.org/capture/images/...ture_stats.jpg
Is missing from chapter 6.3
Old 23rd December 2004, 23:05   #49  |  Link
Wilbert
I know. It's there in 4.1
Old 26th December 2004, 14:57   #50  |  Link
killingspree
Newbie Forum Mod
i had to change the url of the guide i'm hosting... the new capture guide can now be downloaded under
http://www.stefanstrobl.at/doom9/ACG41.zip
cheers
steve
Old 3rd January 2005, 10:35   #51  |  Link
Wilbert
What the guide says doesn't hurt; it should produce the same results. Separating the fields is just an unnecessary step.
Furthermore, most people probably do some spatial filtering too.
I suppose it would be nice if the guide mentioned the unfold/fold method or scharfis_brain's method. It seems like these questions have been coming up a lot recently...
http://forum.doom9.org/showthread.ph...265#post588265
Old 11th July 2005, 00:53   #52  |  Link
Chainmax
Huh?
Chainmax's Avatar
Could ajordan's FixChromaBleeding function be included in the guide? It seems like a quick and easy way to automatically correct chroma shifts.
Chainmax is offline   Reply With Quote
Old 11th July 2005, 19:23   #53  |  Link
Chainmax
Huh?
Chainmax's Avatar
Also, SSIQ should be considered, it's a very good rainbow removal filter.
Old 11th July 2005, 20:31   #54  |  Link
Wilbert
Thanks! We will look at it. We are writing a new version atm, but i don't have much time for it.
Old 29th September 2005, 04:06   #55  |  Link
marine312
Thanks
marine312 is offline   Reply With Quote
Old 26th December 2006, 16:49   #56  |  Link
chipzoller
Mr. Woof
chipzoller's Avatar
In the next version, would it be possible for the authors to update broken links in the 'references' sections ending each page for those who would like to read more in-depth?
chipzoller is offline   Reply With Quote
Old 1st October 2007, 09:00   #57  |  Link
anubhavrocker
hurrra
anubhavrocker's Avatar
Probably the best guide i hv ever seen.
Thanks
anubhavrocker is offline   Reply With Quote
Old 2nd April 2008, 19:56   #58  |  Link
al4711
Linux
does such a description exists also for Linux?!
Cheers
Aleks
al4711 is offline   Reply With Quote
Old 27th October 2008, 08:02   #59  |  Link
video_magic
The link in the post from VCD MASTER (link removed) now only points to some sponsored-links page advertising 'nude clebrity pics' and the like...
Thankyou!, I am grateful for any help
video_magic is offline   Reply With Quote
Old 27th October 2008, 13:39   #60  |  Link
The links have been removed. Thank you.
guide
