25th October 2011, 20:45 | #841 | Link |
Programmer
Feature to blank by playlist for multiple main movie discs (i.e. Directors Cut and Original).
Blue Brothers movie has several m2ts files which make up the main movie. This movie is has 2 versions and are not setup as branching, so its difficult to determine what to blank out. I would like to do "movies and menu" backup but with the ability to choose only one of the main movie playlist versions. Or choose the playlist version to blank. |
2nd November 2011, 16:09 | #842 | Link |
Special SeeD
Long GOP for BD-5/BD-9 would by nice, BD-Rebuilder already uses "--vbv-bufsize" and "--vbv-maxrate" <= than 15000, but uses 1 second gop (24 frames), using Long GOP (2 seconds, 48 frames) should give a free 2-3% boost on video quality and is totally compliant, IMHO on BD-5 even a small gain is important.
2nd November 2011, 17:06 | #843 | Link | |
2nd November 2011, 21:56 | #845 | Link |
I have a feature request that could help me and mabe some others.
I'll use Cars2 as an example. I have a need for a BD25 and a BD5. In batch mode if I select BD25 first then save to batch then add the same movie as BD5 the completed batch mode output will only have a BD5 as it replaced the BD25 of the same name. Can BD Rebuilder apply a suffix to the file the same as it does to a DVD5 such as BD25, BD5 or even 1,2 or 3 as necessary. Thanks for an outstanding product, your time, patience and support!! |
2nd November 2011, 22:17 | #846 | Link | |
3rd November 2011, 00:24 | #848 | Link |
I have a small request too that hopefully shouldnt be too difficult to add (next to that 3rd destination path browse option), and that's to play a (user selectable or maybe the default imgburn) sound when the rebuild with imgburn is complete. With the new methods of blanking and dts-e i burn iso's first to see if they play ok. The thing is that imgburn only plays the sound if burning to a physical disc is completed. My request would be to play (imgburns?) sound when it tells BDRB iso creation has been completed.
3rd November 2011, 09:35 | #849 | Link |
Small request, not sure if it's feasible.
Could the copying of BD structure be done at the start of the process? This is mostly for backups directly from physical discs, I have to leave the disc in the drive all the way thru the encode process because it copies the structure at the end. If this were done at the beginning, I could remove the disc, insert a blank and turn on write to disc for an unattended backup. Having to leave the original disc in during the whole encode seems pointless once all tracks have been extracted. |
3rd November 2011, 15:20 | #850 | Link | |
28th November 2011, 20:08 | #858 | Link |
The ability to "FORCE_NOENCODE=" on a particular m2ts/playlist? Fairly often, I see BD's that are VERY close to single layer, but not quite. By not reencoding the main title, it would force rebuilder to compress the extras further perhaps.
Although ideally, specifying how much compression per clip would be exquisite. Because often, I see extras with very high bitrates, where they don't need it I believe 1080p extras, will look plenty agreeable at 5000 - 6000KB/s. But I see them pushing 10,000KB/s fairly often. I apologize if I asked this before. I've had the thought before, but I don't think I asked |
14th December 2011, 13:03 | #860 | Link |
I wonder what would happen if you converted a BD that has video @ 25fps to either 24fps or 30fps. would fps conversion of video kill the disc structure in some way like bookmarks etc?
If FPS conversion does no harm then i want that put in cos I have BDs that are 25, 50fps and i want to make them playable on my Japanese PS3 which doesn't take 25 or 50fps. |
