23rd February 2015, 22:49 | #21 | Link | |
Thanks for your comment, but I was not asking for this kind of "help": if you read my question, it is not mentioned that my workflow is for VHS only. And actually: even capturing video with 1bit is a waste of resources for a blind man that does not require post processing. Further, you should have a look at the recommended archiving methods of analog supports. Please, also think about the fact that the required "resources" today (in this precise case storage space) will seem low in 20 years (and I have no problem with storage space currently, but thanks for taking care about it for me). One last detail: I am working at Fraunhofer... |
24th February 2015, 00:12 | #22 | Link | |||
I recently deinterlaced a DV source (which I only had a DVD copy of :/). I got quite good results with Code:
-vf yadif=3:1,mcdeint=3:1:4 Since you're on Windows, you probably already have AviSynth set up. (I tried on my windows machine, but I grabbed 64bit avisynth+ so I could use the 64bit x264.exe I'd already cross-compiled, and then found out that some avisynth plugins are only available as 32bit code.) Anyway, apparently QTGMC is the best available free (but not open-source?) deinterlacer. And it's still stuck on 32bit only. Next time I have to deinterlace something, maybe I'll find a way to pipe data through it while still running 64bit encoders. |
24th February 2015, 03:57 | #24 | Link | |
Angel of Night
Heh, I didn't even realize this was about SD.
For 64-bit, it's also been ported to VapourSynth, a Python-based remake of AviSynth where everything is natively both 32- and 64-bit. Documentation on it hasn't really made it to the avisynth.nl yet. |
1st March 2015, 11:07 | #26 | Link | |
What 10bits is far is basically a more accurate 8 bits, since old 8bits adc's were never actually accurate to 8 bits (called integral non-linearity, you can look up this number on data sheets). In fact there's fully analog VHS tapes, and if you wanted to record a still frame for several frames you can extract more than 8 bits from it, by simple averaging. The same concept is used in astrophotography and is called stacking. This could be of use to bringing out hidden details in dark recordings for example. Not going to start an argument here, just some things to think about. |
