10th November 2011, 22:00 | #262 | Link | |
QuickSync Decoder author
If you've verified that it works in your system (in FSE), please send the me the device creation code starting from hWnd creation up to the call to CreateDevice. Thanks!
Eric Gur, Processor Application Engineer for Overclocking and CPU technologies Intel QuickSync Decoder author Intel Corp. |
11th November 2011, 11:16 | #263 | Link | |
/人 ◕ ‿‿ ◕ 人\
1) There are a lot of people who are not using such... filters. For them it makes things only worse - e.g. 712x400 is 16:9, if you add 8pix border it would be 720x400 and you will have to enjoy top, right and bottom black borders on 16:9 display. 2) ffdshow already has such feature - resize & aspect filter - "expand to next multiple of 16". |
11th November 2011, 13:54 | #264 | Link | |
What I plan to do is enable/disable this feature via config. This way the DS filter can control what's going on. I hope this will make everyone happy. I personally use vobsub and it's quite common - that's why I implemented it in the first place. The default will be to enable mod16 width because stability overrides quality. BTW, ffdshow will copy the image with a significant performance penalty so it's not a good option.
13th November 2011, 16:59 | #265 | Link |
Egur this is really cool http://www.mediafire.com/download.php?d0bg6khk2lk8bjl due to the vsync background noise completely gone you can immediately see what the Broadcast Encoder did wrong (without needing to look @ the bitstream) it happens @ every keyframe
I tried to get the same resolution with ffdshow-quicksync but it shows strange peakings and get a lock sometimes @ 25 fps the nicetest scene shows extreme jitter also 16ms Peaking wrong lock issue (telecine mpeg-2): http://www.mediafire.com/?gauc931m49hya51 Heavy jitter issue (H.264 Interlaced): http://www.mediafire.com/?x2crc2tuoq9il29 Interesting disabling Deinterlace auto flag output in ffdshow-quicksync fixes both of these issues but obviously no Deinterlacing anymore (which though is only really problematic for the Interlaced H.264 stream) Though there is still strange peaking periodically going on for the telecined stream and jitter changes from 0.4xxms upto 2ms very strange, ahhh it loses the lock on the next keyframe again Lock Lost issue (telecine mpeg-2): http://www.mediafire.com/?tii7ytnm7di6ck4
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 13th November 2011 at 18:42. |
13th November 2011, 22:25 | #266 | Link | |
14th November 2011, 16:52 | #267 | Link | |
I hope you'll enjoy your trip, and hear from you later on.
development folder, containing MPC-HC experimental tester builds, pixel shaders and more: http://www.mediafire.com/?xwsoo403c53hv |
20th November 2011, 04:43 | #268 | Link |
I used to use LAV for splitting, audio and video. Recently I rebuilt my HTPC with a Sandybridge processor so I thought I'd give this build a try for video.
For a renderer, what are people generally using EVR, EVR CP or madVR? |
22nd November 2011, 13:03 | #269 | Link | |
I'm a newbie here, and testing about limitation issue... Quote:
The maximun number is 6, the 7th graphstudio will fail. I have tested on both nVidia GT430 and AMD Radeon 6900 series... Is that the limitation of ffdshow? and will the limitation same as this intel project ? Thanks! |
22nd November 2011, 22:34 | #270 | Link | |
22nd November 2011, 22:46 | #271 | Link |
Intel QuickSync Decoder was integrated into ffdshow!
The first official build of ffdshow with Intel QuickSync decoder can be downloaded from the ffdshow's download page at:
http://ffdshow-tryout.sourceforge.net/download.php Same QuickSync decoder as v0.18, ffdshow itself contains changes mostly for subtitles. This thread will continue to supply ffdshow builds for continuous testing of my decoder's versions.
23rd November 2011, 01:52 | #272 | Link | |
If I test ffdshow by DXVA2, even by smaller h264 video files, the graph studio limitation is still 6, no idea why My purpose is for TV wall... |
24th November 2011, 04:47 | #273 | Link |
Hi, A programming issue about progressive frame flag,
In QuickSync.cpp mfxU32 CQuickSync::PicStructToDsFlags(mfxU32 picStruct) if (picStruct == MFX_PICSTRUCT_PROGRESSIVE) { return AM_VIDEO_FLAG_WEAVE; --> Is it better to use "AM_VIDEO_FLAG_INTERLEAVED_FRAME" ? } |
24th November 2011, 07:29 | #274 | Link |
This is done to insure that a deinterlacer will not run on this frame. AM_VIDEO_FLAG_INTERLEAVED_FRAME means that both fields exist. Do you see any issues with this?
24th November 2011, 07:45 | #275 | Link |
AM_VIDEO_FLAG_WEAVE is the right flag for progressive. AM_VIDEO_FLAG_INTERLEAVED_FRAME actually has the value 0, and is therefor always set. Most images we deal with here always have two interleaved fields - singe fields are rather uncommon.
24th November 2011, 08:06 | #276 | Link | |
test sample files) http://msdn.microsoft.com/en-us/libr...(v=vs.85).aspx AM_VIDEO_FLAG_WEAVE "This flag applies only when there are two fields per sample. " As MSDN explains.. Maybe someone can help to explain more.. |
24th November 2011, 08:14 | #277 | Link |
A progressive frame contains two "fields", you're just not supposed to handle them separately.
24th November 2011, 08:58 | #278 | Link |
a video frame can basically come from two sources - interlaced or progressive.
In the former, the 2 fields (called top/bottom or odd/even) are from different times. Each field has half the lines of the original frame. Due to the different time stamps, they should be interpolated (several methods exist) to a full frame (e.g. deinterlaced). In a progressive frame, there's no notion of fields, the image has all the lines and no deinterlacing is needed. A special case is what's called "film". A video that was shot in progressive and later artificially split into fields (mostly TV broadcast and DVDs). In "film" content, the fields share the same time stamps and need to processed as progressive frames. A deinterlacer and/or a decoder will usually have a film detector mechanism of some sort as a standard deinterlacer will produce horrible artifacts for some content. There's also the matter of how CbCr is stored (4:2:0 only). If the frame is progressive, CbCr values are stored for two consecutive lines. For interlaced content, it's stored for two consecutive lines of a specific field. Simply weaving the lines will produces color artifacts even if there's no motion.
7th December 2011, 21:51 | #279 | Link |
New version released 0.19
Version 0.19 is out with the following changes:
* Added limited support for WMC full screen exclusive mode: - Renderer must be connected to the decoder directly - no intermediate filters. - Screen is connected to the Intel GPU (decoder shares device with renderer). - Might only work on single monitor setups. * Decoder has exposed its configuration options GetConfig/SetConfig - must be called before initialized. * Padding the image to mod16 width is now off by default. Works with vobsub. * Decoder can be tested for compatibly with media types via the TestMediaType method * FFDShow rev4126 Download from SourceForge home page: http://sourceforge.net/p/qsdecoder
9th December 2011, 11:20 | #280 | Link | ||
Thanks a lot for the update.
Can I ask several questions and requests? Please excuse me for not reading all of this thread. I read several pages. I do not have sandy bridge and can not test your decoder. I would like to ask you to add an entry to our wiki and answer these questions. I think most of my questions are FAQ. Quote:
Can ffdshow resize? If screen is not connected to the Intel GPU, and the renderer is not the WMC full screen, does your decoder work? Quote:
Additional FAQ for the wiki: How fast is this? For what kind of video is this useful? Which profiles of H.264 does this support? Can this output 10/12-bit formats? |
ffdshow, h264, intel, mpeg2, quicksync, vc1, zoom player |
