7th April 2008, 13:01 | #941 | Link | |
I have a PS3 and a Panasonic BD30. The disc is a AVCHD for both players. The Panasonic BD30 don`t acceppt Vc1 on DVD9 ( AVCHD ) PS3 can play is corect. Hollydoc |
7th April 2008, 13:15 | #942 | Link |
I just tried to play a Blu-ray Disk multiplexed/authored with tsMuxeR GUI 1.7.2 and burned as UDF 2.50 to a DVD5 containing 1x MPEG-2/AC3 and 2x H.264/AC3 video's, but the PS3 won't start playing it
Are mixed video formats not supported? Last edited by fico99; 7th April 2008 at 13:17. |
7th April 2008, 13:32 | #943 | Link | |
However, when I look at the BDMV File Structure generated by Nero Vision 5, I see that in the \BDMV\STREAM folder there are files called 00000.MTS, 00001.MTS, ... instead of M2TS files? The BDMV File Structure is a bit different too: \BDMV \BDMV\BACKUP (INDEX.BDM, MOVIEOBK.BDM) \BDMV\BACKUP\CLIPINF (00000.CPI, 00001.CPI, ...) \BDMV\CLIPINF\PLAYLIST (00000.MPL, 00001.MPL, ...) \BDMV\PLAYLIST (00000.MPL, 00001.MPL, ...) \BDMV\STREAM (00000.MTS, 00001.MTS, ...) INDEX.BDM MOVIEOBK.BDM To let the PS3 recognize & play this 'AVCHD DVD' BDMV File Structure directly from a FAT32 formatted Storage Card, USB Stick or Ext HDD, you need to put the complete BDMV File Structure under a root folder called 'AVCHD': e.g. I:\AVCHD\BDMV\... Last edited by fico99; 7th April 2008 at 13:34. |
7th April 2008, 13:38 | #944 | Link | |
Cheers, Beastie. |
7th April 2008, 13:51 | #946 | Link |
@roman76r, you seem to be doing a great job here!
My personal favourite container currently is Matroska. Mainly for the following two reasons: (1) FLAC support. (2) The ability to give audio tracks a name. Now I'm wondering: Do you think there's a chance to extend the TS specification somehow to allow muxing of FLAC tracks (without transcoding them to something else) and giving audio tracks a name? Is there a central place where such TS format extensions are discussed and agreed upon? Of course it would be bad if every programmer invented his own way of adding new things to the TS container... |
7th April 2008, 14:07 | #947 | Link |
UDF 2.5 vs UDF 2.6
What is the standard format for BD5 and BD9 disks ?
AVCHD should be on udf 2.5 ? (or 2.6 ?) What is the difference between the two formats ? p.s.: No one has issues with subtitles in blu-ray outputs ? (I get permananent subtitle on PS3 if I add a sup file in tsmuxer. (720p project) ) |
7th April 2008, 14:19 | #948 | Link | |
Hello Roman, I posted this earlier but didn't get a response...
Also, how is .srt subtitle import looking? This is a feature I am really looking forward to. |
7th April 2008, 16:26 | #950 | Link |
When I try to process blu-ray with TrueHD audio track, I noticed some differences between the output of tsremux 0.20 and tsmuxer 1.7.3.
This caused the TrueHD audio in tsremux output can be recognized by PS3, but tsmuxer output failed. I use hex editor to dump the PMT table of the output Here is the PMT of tsremux And here is the PMT of tsmuxer 1.7.3 |
7th April 2008, 17:10 | #951 | Link | |
I have a Sony AVCHD camcorder writing on Memory Stick. I can reproduce on the PS3 the AVCHD content directly on the memory stick (ac3 included)
I would be very much interested in transforming existing bluray backups (large files) into blurays with smaller files (FAT32 compatible), like fico99 describes, in order to play them in an external FAT32 hard disk. If it helps I can send Roman a sample of the AVCHD structure used in the memory sticks (I also noticed that it uses MTS files instead of m2ts...) Thanks for the good work J Quote:
7th April 2008, 17:19 | #952 | Link | |
7th April 2008, 17:33 | #953 | Link |
When moving the content from the memory stick to the computer hard disk it creates m2ts files (using Sony provided software). I did not check if they are identical files (binary identical). It does not move to the computer the remaining AVCHD files structure.
Apparently it is possible to move back the m2ts files to the memory stick in order to play them in the camcorder. I did not check this though. |
8th April 2008, 00:59 | #955 | Link | |
8th April 2008, 03:46 | #956 | Link | |
It's much better to have a unique stream_type, so that demuxers don't have to parse the audio stream to determine what it is. This is why xport doesn't work for non Blu-ray DTS. Ron
HD MPEG-2 Test Patterns http://www.w6rz.net |
8th April 2008, 08:16 | #957 | Link | ||
Thanks! |
8th April 2008, 09:22 | #958 | Link | |
i have a Problem at the End at 97% remuxing off an Evo to m2ts
This Problem is on this File every Time i will remux it here the Log from the Muxer and the Microsoft Konsole Quote:
8th April 2008, 11:52 | #960 | Link | |
There is a list of (maybe not all) descriptors here: http://www.coolstf.com/tsreader/descriptors.html |
tsmuxer |
