8th June 2007, 00:31 | #21 | Link | |
8th June 2007, 12:59 | #22 | Link |
So I guess my computer is not powerful enough to stream the HD DVD. I just tested for like ten seconds earlier on Thursday, and then tonight I went to actually watch the whole show and nothing but garbage. It seems that my Core 2 Duo E6600, 2 GB of Ram, 7900 GS 256MB Nvidia card, and two 500GB 7200rpm Raid 0 hard drives EXT3 portioning, just doesn't cut it. Is there some option I did not include when I compiled Mplayer? I configured it with xvmc (doesn't matter for this), ssse3, and everything else autodetected.
Here is the error I get from mplayer ************************************************ **** Your system is too SLOW to play this! **** ************************************************ Too many video packets in the buffer: (4096 in 8279842 bytes). Maybe you are playing a non-interleaved stream/file or the codec failed? For AVI files, try to force non-interleaved mode with the -ni option. Last edited by jackelmatador; 8th June 2007 at 19:28. |
9th June 2007, 11:27 | #23 | Link | |
I get the same output, but only on some movies. I have a "AMD Sempron 3400+, 2GB ram, nvidia 6200 128mb TC card. Under windows XP, I got only some sync problems. regards qub |
9th June 2007, 12:33 | #24 | Link |
I've seen it aswell on a rare occasion, however I haven't been able to put my finger on it. The too many video packets only happens when I play the 2nd part of a movie (e.g. feature_2.evo). So far I've assumed this has something to do with mplayer's demuxing stuff or how the movie was cut in half during authoring. Also noticed that switching demuxer can solve it, but introduces it for the evo that played well with the other demuxer.
One thing I do know for sure is that decrypthd only outputs 2048 at a time, which is exactly 1 packet. Seeing VC-1 playback is relatively new and streaming it like this is apparently the first time ever attempted, these could very well be 'glitches' in mplayer. It's certainly not the first Try playing with '-demuxer lavf' and see what happens. qubic, does this mean you've got the openssl part working now? Last edited by Zotty; 9th June 2007 at 12:37. |
9th June 2007, 13:01 | #25 | Link | |
On a HD DVD disc there are a lot of different parts that need to be processed/parsed. Key files, advanced elements such as images, animations, fonts, music, etc.. And these are all protected. Then you'd also need to parse XML files, make an ECMA script interpreter and put this all together. Now only the raw material is available and needs to be put to good use. Building menu's and be able to display them with user interaction, the selection of different languages and so on, all integrated with the underlying mplayer code. And there's probably more, which I haven't even thought of. In any case this would require months of coding if not longer. And don't forget this will be done in spare time since most of us have/need jobs to feed themselves. All in all a very cool idea, but at this time far from being reality. It would be very nice if there ca be some sort of cooperation between various programmers to realise this. This wouldn't be a simple patch, so this can't be simply dumped into mplayer's dev tree. Probably a seperate source repository would be needed where various people could work on a combined sourcetree. At least to begin with. Last edited by Zotty; 9th June 2007 at 13:11. |
10th June 2007, 02:20 | #27 | Link |
Zotty no worries on the mplayer plugin, that is why I was very surprised.
Hey Qub, From what I have read the drivers NVIDIA supplies for windows is much better. They supposedly do fun stuff like actually sending VC-1 frames to the video card to be processed. I know in Linux only MPEG1/2 is done this way through XvMC. I think once I figure out how to make the video play acceptably (-lavf is a little better) I might write a little script that just plays the biggest EVO files available. The only tough part would be to make sure they play in the right order, for now it seems all movies have some sort of numerical suffix. |
10th June 2007, 07:02 | #28 | Link |
Perhaps a way to implement it without requiring root permissions would be to make a daemon "backend" that runs as root and reads the files, only to pass them (without preprocessing, so that the userpriv part can be reniced individually) to a "client" running with user privileges, which does the actual decryption? In theory, this could also enable:
Multiple users accessing the disc No need to be root Individual config files (default drive location, fallback VUK's if implemented) Maybe, eventually, we can wrangle someone who understands FUSE to implement a sort of "pseudo-filesystem", like eCryptFS, which acesses the mountpoint, and creates a sort of "translated" filesystem in a directory that decrypts files dynamically on access - this is essentially what eCryptFS does, so it's feasible, and it might even be possible with existing code since AACS uses AES and there are already several programs, including this one, which can handle subset-diference. In theory, this could make that menus and extras concept possible. Whap me over the head if I'm being too blue-sky, but does anyone know a filesystems person? Also, I found a post on vger.kernel.org talking about adding a uid=ignore/gid=ignore option to mount for UDF, dated to March 4 2006. Try it and see if it helps. Last edited by XAvAX; 10th June 2007 at 07:14. |
10th June 2007, 11:22 | #29 | Link |
I didn't test this software because I don't have a drive, anyway I have a couple of hints and requests:
- adding -demuxer mpegps isn't necessary (it will only detect the mux format faster) and as already observed by others it isn't even the best option available - -demuxer lavf -correct-pts may playback smoother - hddvd:// would require a stream reader module in mplayer (look at stream/ directory) which in turn would require a reader library that all other softwares may use, such as libdvdread that provides access to single titles without bothering with menus, stills and so on - playing single files _will_ break multi-angle movies, just like playing single VOB of multi-angle dvds _does_ break today, thus a library is the only way to go for the future. Now the requests, solicited by you: may you release the source code, please? Possibly to some plain ftp/http server (e.g. not rapidshare and co). Thanks very much for your work! |
11th June 2007, 20:00 | #30 | Link |
A little later than planned (was busier than expected), but here it is;
The source: decrypthd_src_20070611.rar And the binary: decrypthd_bin_20070611.rar Changelog: - Simultanious save to file while watching (use <output dir> -o) - CMAC AES (for Volume ID verification) - Code cleanup - Resets AGIDs so it's no longer needed to manually reset the drive Last edited by Zotty; 11th June 2007 at 20:16. |
11th June 2007, 20:14 | #31 | Link | ||||
11th June 2007, 23:42 | #32 | Link | |||
This is great. But I get this fare: Quote:
12th June 2007, 07:44 | #33 | Link |
The typedef in file.hpp is no longer needed, due to stdint being used now.
Try replacing: Code:
#include <string> typedef unsigned long long uint64_t; class File Code:
#include <string> #include <stdint.h> class File |
16th July 2007, 17:39 | #34 | Link |
Hi there
I've got a problem using decrypthd. I'm always getting the following message in the log: Code:
*** Starting decryption of PEVOB_1.EVO *** Dumping to stdout Getting key number from /media/CONSTANTINE_HD/HVDVD_TS/PEVOB_1.EVO Needed key is No keynumber. Aborting! ### Exception: HDDecrypter: No keynumber. Aborting! ### Is there anything I do wrong? Am I supposed to put a Key somewhere? My System is 32bit Debian SID, external xbox drive Thanks Ben PS: dumphd worked flawlessly with all my HD DVDs using exactly this drive |
30th July 2007, 10:55 | #35 | Link |
Hi
I "solved" my problem by replacing Code:
ifEvobFile.read((char*)u8Header, sizeof(u8Header)); return u8Header[0x3E] - 1; // note: we start at 0, while keynumber starts at 1 Code:
ifEvobFile.read((char*)u8Header, sizeof(u8Header)); return u8Header[0x3E]; // note: we start at 0, while keynumber starts at 1 Regards Ben |
6th September 2007, 21:03 | #36 | Link |
hi
did I miss something or is there really no improved decrypdhd version? like watching blu-rays on the fly. I'm not happy ripping every disk and watching it this way. It's very time and disk space intensive. Unfortunately I'm not a (good) coder, so I can't improve it by myself. Best Regards Ben |
31st October 2007, 15:01 | #37 | Link | |
3rd November 2007, 16:59 | #39 | Link |
for the permissions problem you could try the umask= option.
If I remember correctly if you set it to umask=000 all files will have full permisions (rwxrwxrwx). I think this only works if the FS has no specific permsions, not sure how UDF is structured so it may or may not work. |
