Old 23rd February 2013, 09:01   #17681  |  Link
Qaq
AV heretic
With 0.86.0 I'm still have a blank screen with DXVA (decoding and image scaling) after changing from window to FSE modes. The workaround is: start playback - pause (fast) - switching to FSE - unpause.
Windows7, ATI 7750, CCC 12.8.
Qaq is offline   Reply With Quote
Old 23rd February 2013, 09:44   #17682  |  Link
madshi
Originally Posted by THX-UltraII View Post
1. How do I fix the BTB (grey desktop) problem that the Intel intergrated Graphics 2000 has?
2. How can I make a 23,976Hz custom profile? The default 23Hz profile is 23,972 and I want to aim for 23,976XXX. When I choose Custom Resolutions I can only fill in round number and no numbers like 23,976, only 23/24/25 etc.
I don't know.
Originally Posted by Niyawa View Post
Also, could you take a look at this little fellow post. He seems to be having problems with exclusive mode off (windowed I believe) and when you see the youtube video he posted, it kinda reminds me of tearing but I'm not sure. Apparently he changed his monitor refresh rate to 24 hz to match the 24p video to eliminate judder but got that problem instead.
Yes, this is tearing. It can happen in windowed mode if you have Aero / Desktop Composition turned off. Sometimes it even happens with it turned on, in that case a reboot often helps. This is one of the advantages of FSE mode: There tearing should never ever occur, unless the hardware or drivers are broken.
Originally Posted by aufkrawall View Post
Sample 1 still looks very unsmooth with FRC. I can't say for sure if maybe this has to be since I can't watch it in native 24Hz atm.
Download:
http://www22.zippyshare.com/v/7254850/file.html
Yes, it's not smooth, but it looks the same way with native 24Hz. Fast horizontal camera pans *CAN'T* look totally smooth with 24fps, unless you film them with a lot of blur. For a long time fast horizontal camera pans have been avoided in movie filming for this reason. But lately it seems film makers don't care as much about this, anymore.
FRC does not reduce judder that is in the source. It "only" simulates a display which can display 24Hz natively. If a proper 24Hz display shows judder with a specific 24fps movie, then so will madVR's FRC.
With sample 2, watch for the dust between the trees. It looks very nervous/flickering with FRC. Without not. imho clearly an unwanted side effect.
Download:
http://www67.zippyshare.com/v/94753150/file.html
Hmmmm... I'm not sure I'm seeing what you're seeing here. Which "dust between the trees" do you mean? I'm not even sure where to look. Can you clarify?
Originally Posted by bugmen0t View Post
The rendering times increased a lot with v0.86.1 for me. Is this intended, better quality etc?
Originally Posted by JarrettH View Post
Noticed this too. About 8-10 ms increase on an Intel HD 2000 (not my main computer)
The render times *measurements* increased because I had to add a forced flush for the FRC rendering steps to make the occasional artifacts go away. But the *actual* rendering times shouldn't have increased much. Or do you get stuttering / dropped frames now which you didn't get before?
Thanks. I can confirm that all of these logs should have resulted in FRC being turned off. I've found a very simple and stupid bug which caused this problem.
I don't see this bug in the madVR bug tracker. Do you?
Old 23rd February 2013, 10:01   #17683  |  Link
bugmen0t
Banned
Need to do more testing first.
With your general FRC approach the blended frames are generated at irregular points in time, right? Wouldn't it be beneficial to have a fixed pattern like e.g. repetition, blend, repetition, blend, ... at least when using ReClock?
bugmen0t is offline   Reply With Quote
Old 23rd February 2013, 11:05   #17684  |  Link
aufkrawall
Ok, thanks for explaining.
Maybe I was a little oversensitive. Now in a non darkened room I don't really notice it anymore. I guess it's again a "broken source", maybe the effect just naturally increases a little with FRC.
I noticed that display mode changer still changes to 59.94Hz for 23.976fps videos even though FRC is set to be always enabled.
Wouldn't it make sense to change its logic that it doesn't change resolution with FRC?
Uhm, what about FRC for e.g. 60fps@60Hz? Is there much blur to be expected?
Otherwise it'd like to get rid of Reclock.
Edit: Ah, found the answer in your first post of 0.86.
Btw: I've tested a 3 minutes 60fps video, no frame drops.
Old 23rd February 2013, 11:39   #17685  |  Link
TheElix
To my best knowledge madVR is now the only way to playback Blu-Ray/DVD movies without 3:2 pulldown judder on displays which don't support 23.976Hz playback properly. I don't think any hardware Blu-Ray player can do that, or even any of the expensive video processors. (Correct me if I'm wrong).
You, sir, are a wizard and a messiah of HTPC world!
TheElix is offline   Reply With Quote
Old 23rd February 2013, 12:33   #17686  |  Link
squall12
Hi madshi,
If i am using 23hz refresh rate at my samsung lcd tv with the tv smooth motion function mean i dont get any advantage using the madvr frc?
Thanks
squall12 is offline   Reply With Quote
Old 23rd February 2013, 15:05   #17687  |  Link
Niyawa
Niyawa's Avatar
I see, thanks. But if rebooting doesn't solve the problem (without FSE) isn't there anything more we could do? Just in case.
madVR scaling algorithms chart - based on performance x quality | KCP - A (cute) quality-oriented codec pack
Niyawa is offline   Reply With Quote
Old 23rd February 2013, 15:16   #17688  |  Link
druneau
Is it possible to run the SmoothMotion madTestPatternSource at a user specified fps?
I tried just renaming one to SmoothMotion120.ytp as a test and it defaulted to 23p.
The other thing I was wondering, I ran 24p side by side with 60p in another player because I wanted to explain to someone the difference between having more source images vs smoothness etc...
But to my surprise the bars were not scrolling at the same speed. I'm guessing this was intentional/side effect of the implementation. It's probably not an easy switch, especially if you would have to generate different source material. But I might be helpful to have the different SmoothMotion test patterns moving at the same overall speed?
And thank you for such a great piece of software. I'm slowly converting people around me to madVR. The FRC option will make it even easier for people to have smooth playback with minimal effort.
druneau is offline   Reply With Quote
Old 23rd February 2013, 15:53   #17689  |  Link
oddball
Madshi is xy-vsfilter work still in progress for high def subs? Also is some form of motion compensation on the cards for the future? I'd like to see motion compensation with some form of control element to it (My TV's is one setting only and it's horrid).
oddball is offline   Reply With Quote
Old 23rd February 2013, 17:45   #17690  |  Link
shimaflarex
I don't know.
I do get more dropped frames with 0.86.1, smooth motion turned on, new exclusive mode.
Using "use a separate device for presentation", my render queue seems to get stuck on 0-3/8, and I get dropped frames all the time. If I pause the video, it goes to 0-8 / 8, but it quickly drops to 0-3 / 8 on playback.
Now, without "use a separate device for presentation", something very weird happens. The render queue stays on 5-6/8 on playback, but if I pause the video, click on Edit Settings on madVR preferences, click Ok without changing anything, and unpause the video...the render queue gets stuck on 0-3 / 8. If I just open the madVR preferences dialog and close it without clicking on Edit Settings, I don't have this issue.
Edit: Hm, the render queue does seem to get stuck on 0-3 after a while, even if I don't open the Edit Settings dialog. Opening it is however a sure way to trigger this.
On madVR 0.86, I don't have this issues, just out of order frames with "use a separate device for presentation" turned on and the present queue randomly going to zero when it is off.
Edit 2: Setting my flush settings to Flush/Don't/Don't/Don't and disabling "use separated device for presentation" seems to solve my issue on 0.86.1.
shimaflarex is offline   Reply With Quote
Old 23rd February 2013, 18:14   #17691  |  Link
joe42
I noticed that with 0.86.1 I get continuous dropped frames on the SmoothMotion50 test file (60Hz monitor), but no dropped frames on the other SmoothMotion files.
With 0.86.0 I did not get any dropped frames, not even with the 50Hz test file.
So something changed for the worse with 0.86.1
joe42 is offline   Reply With Quote
Old 23rd February 2013, 18:26   #17692  |  Link
Q-the-STORM
Originally Posted by squall12 View Post
Hi madshi,
Thanks
the point of FRC is to remove judder... 23.976fps content on 23.976Hz refresh rate doesn't have judder... so FRC will essentially do nothing....
btw. thanks madshi... I usually use reclock to clock to 24fps and then set my VT50 to 24Hz... but the VT50 sometimes has a bit of flicker at 24Hz and I always hated the few seconds the panel needed to change the refesh rate... especially if I just want to open a video to check something... It got really annoying... now I simply leave it at 60Hz and turn on FRC...
Old 23rd February 2013, 19:55   #17693  |  Link
glc650
@glc650
ReClock is fully compatible with FRC.
The settings you suggest will turn off ReClock's audio clock corrections. Why would you want that? (The only benefit then over other audio renderers would be having WASAPI.)
I thought that's the desired setup when using FRC? Turn off ReClock's manipulation of the audio and just use ReClock for its audio clock? So what settings do I need then?
glc650 is offline   Reply With Quote
Old 23rd February 2013, 20:08   #17694  |  Link
oddball
Been testing a few things. 23.976fps with smooth motion forced on at 24Hz causes a ghosting effect kind of like interlacing. 23.976fps at 60Hz causes flickering. You can especially notice it on scrolling end credits. Looks like it's no good for me and I may as well stick with 24Hz smooth motion off for now.
Old 23rd February 2013, 20:33   #17695  |  Link
dansrfe
If I rapidly seek through the file with the right arrow button then madVR still freezes in exclusive mode but when it goes back to windowed mode it plays like normal. At that point if I try to fullscreen it back to exclusive mode I get a black screen and have to restart the file in order to use exclusive mode. This is with v0.86.1.
Old 23rd February 2013, 20:38   #17696  |  Link
iSunrise
Yes, I can confirm that. I was only able to trigger it with FRC on though, FRC off still seems to behave like 0.85.8. Sometimes if it happens, it looks like an endless loop of 2 frames that are shown at the same time (endless flickering).
iSunrise is offline   Reply With Quote
Old 23rd February 2013, 20:43   #17697  |  Link
kasper93
MPC-HC Developer
I need to ask about one thing.
If I use reclock should I check "slave reference clock to audio"? Or leave it unchecked. For best compatibility with madVR.
kasper93 is offline   Reply With Quote
Old 23rd February 2013, 20:55   #17698  |  Link
Qaq
AV heretic
Originally Posted by Q-the-STORM View Post
I usually use reclock to clock to 24fps and then set my VT50 to 24Hz... but the VT50 sometimes has a bit of flicker at 24Hz...
AFAIK, VT50 supports 96Hz.
Old 23rd February 2013, 21:18   #17699  |  Link
ikarad
madVR v0.86.0 released
http://madshi.net/madVR.zip
* added smooth motion frame rate conversion algorithm
* added settings page for smooth motion frc configuration
* added "trade quality for performance" option for smooth motion frc
* added test patterns to madTestPatternSource to test smooth motion frc
* fixed: RGB input with odd width/height is now accepted untouched
* fixed: IVideoWindow::put_Owner() failed when pins were not connected yet
* fixed: madHcCtrl.exe autostart registry entry was incorrect / not working
* fixed: occasional crash when using DXVA scaling with high-bitdepth content
* fixed: green line at the left image border when using DXVA scaling
* file "settings.bin" is not written into win7/8 "VirtualStore", anymore
* slightly improved multi monitor behaviour (when using DXVA or MPC-BE)
* filter enumeration timer is now only active during DVD playback
* extended logging for fullscreen exclusive presentation queue
* internal software video decoders are now disabled by default (again)
Introducing the new "smooth motion" frame rate changer (FRC) with the following main features / benefits:
(1) Can convert any source frame rate to any display refresh rate, while maintaining smooth motion.
(2) Endless playback without frame drops/repeats (if your PC is fast enough) without needing Reclock.
There are disadvantages, too, of course:
(1) Slightly higher GPU usage (not too much) with default settings.
(2) Some sharpness loss (almost invisible with 23-25fps -> 60Hz conversion).
23-25fps -> 60Hz: minimal sharpness loss, nearly invisible
24fps -> 24Hz: visible sharpness loss
60fps -> 24Hz: very noticeable sharpness loss
Basically the higher the refresh rate, the better. And the lower the source framerate, the better.
There's a new version of the madTestPatternSource filter available. It's now a separate download because it increased in file size quite a lot, due to the new test patterns for smooth motion.
Technically the FRC algorithm simulates a display with infinite refresh rate. Which means that every video frame is displayed exactly when the timestamps ask for it. Consequently the motion smoothness depends on proper timestamps. If the timestamps (or audio clock) contain jitter, the playback will contain jitter, too. So even if Reclock might not be needed to avoid frame drops/repeats, anymore, when using madVR's new FRC algorithm, you might still want to use Reclock, because it provides a stable and reliable audio clock with very low jitter, and it supports WSAPI exclusive mode, too. You can however slave Reclock to the audio hardware clock, if you want. Having Reclock fully enabled with audio resampling is still possible, though, it shouldn't harm madVR's FRC algorithm.
One last hint: There's a new "trade quality for performance" option in the madVR settings which affects the quality of the FRC frame blending. By default frame blending is done in gamma corrected light, which is fast, but not mathematically correct. If your GPU is fast enough, it's highly recommended that you disable the "trade quality" option for highest image quality. There are no negative side effects to blending frames in linear light - except for higher GPU usage, of course.
P.S: Just to avoid confusion: madVR's smooth motion FRC does *NOT* modify audio in any way. Playback speed is not affected at all. The only thing that changes is that motion looks much smoother, if the display refresh rate isn't an even multiple of the source framerate.
1) Have I need "smooth motion" frame rate changer (FRC) if I have 23.976fps movie with a 120hz display monitor?
What are the best options in smooth motion?
2) If I have reclock, is it still necessary with smooth motion to avoid frame drops/repeats?
3) what is the best option with 120hz and 23.976fps movie?
............. a) only if there would be motion judder without it
........... b) or if the display ..... the movie frame rate
.......... c) always
4) in trade quality for performance, I have "don't use linear light for smooth motion frame blending" turn on by default, Must I turn off or not? (I have 570)
5) If I use 3:2 inverse telecine filter like decomb, smooth motion is it compatible or not?
6) If I turn on smooth motion, in windows mode I have 48fps instead of 24 fps in movie (using fraps), is it normal? Smooth motion would double framerate? Why?
edit: I try and with movie, I have some glitch with smooth motion option.
ikarad is offline   Reply With Quote
Old 23rd February 2013, 21:49   #17700  |  Link
rahzel
It does. But I think he means that he switched his HTPC to 24Hz and had his VT50 set to 96Hz, but now he just uses 60Hz with FRC on. Even though my ST50 doesn't have a 96Hz option, it does accept 24p... I also used to switch to 24Hz, but now I just leave it at 60Hz with FRC on.
Outputting 24Hz with FRC on isn't the best setup for film... it's better to leave it at 60Hz. If your set can properly handle 24p (96Hz, 120Hz, 240Hz etc.,) it may be better to output 24Hz without FRC on. Outputting 60Hz from your PC and playing film with FRC on shouldn't cause any flickering vs having it off.
rahzel is offline   Reply With Quote
