25th August 2013, 16:24 | #221 | Link |
Well, uncompressed YUV was required by the encoder too, as long as it has no AviSynth or pipe support. At least the input in Y4M format is a little advantage, saving a few CLI parameters.
I will tell you if the reference decoder restored correct or bugged frames, as soon as RawSource got updated to support AviSynth 2.60 MT alpha 4 (same CACHE_MODE interface failure as MaskTools 2). This decoder, unfortunately, appears to output plain YUV only, not Y4M; or did I miss the required parameter? Last edited by LigH; 25th August 2013 at 16:26. |
25th August 2013, 21:19 | #222 | Link |
Chikuzen released a new build of RawSource.
Result: HM 11 decodes with the same error. So it may be the proof for an encoder issue. — frame 44 Raw HEVC file (~10 MB), x265 r3512, current command line options: -q 20 -b 3 --weightp --weightbp --no-early-skip --no-fast-cbf --rdpenalty 1 Last edited by LigH; 25th August 2013 at 21:36. |
26th August 2013, 01:14 | #224 | Link |
TEncoder, TX264, TAC
I've been writing a small GUI for x265.exe. You can download it from here. It's not much but beats command line IMHO if you wan to run tests. It'll first convert source to yuv then feed this to x265.exe and later will mux this h265 stream with audio into mp4. Also, you can save created command lines to make things easier. Feedbacks are welcome, as always.
26th August 2013, 10:45 | #225 | Link |
Version 0.3+504 by Vid01 appears to be less stable. It crashes early (<50 frames). Due to a recommendation, I will discuss this also directly in the VideoHelp forum thread.
27th August 2013, 06:04 | #226 | Link | |
28th August 2013, 23:19 | #228 | Link |
I updated GUI to build 92. Now disabling audio should work. Downloads are here: https://bitbucket.org/ozok/x265gui/downloads
1st September 2013, 01:05 | #229 | Link |
Just FYI, some days ago they switch the fixed GOP structure into alternating P/B frames. Maybe it's a half step in preparation for other things, and I'm really hoping to see intelligent/adaptive frame decisions soon. In the meantime, though, quality dropped quite a bit compared to the old HM-like random access structure.
1st September 2013, 02:23 | #230 | Link |
x265 [info]: HEVC encoder version 0.3+614-0e0a822fd344
x265 [info]: build info [Windows][GCC 4.8.1][32 bit] 8bpp https://shared.com/pwb6xve8kg |
1st September 2013, 06:47 | #231 | Link | |
I have tried some 4K .mp4 file as input but no one works. Last edited by edison; 1st September 2013 at 09:15. |
2nd September 2013, 06:47 | #232 | Link | |
PC: FX-8320 GTS250 HTPC: G1610 GTX650 PotPlayer/MPC-BE LAVFilters MadVR-Bicubic75AR/Lanczos4AR/Lanczos4AR LumaSharpen -Strength0.9-Pattern3-Clamp0.1-OffsetBias2.0 |
2nd September 2013, 12:12 | #239 | Link |
You do realize that the devs are much more likely to implement the actual video coding, instead of some silly input plugins?
I don't think they consider it really ready for real-world usage, so those input things don't matter yet.
