Old 5th August 2013, 17:29   #201  |  Link
easyfab
I think MSVC is shared ( you need Microsoft Visual C++ Redistributable Update 3 ) and MinGW is static.
Perhaps try to select STATIC_LINK_CRT in cmake to see the difference
easyfab is offline   Reply With Quote
Old 5th August 2013, 18:08   #202  |  Link
gnaggnoyil
Nooooooooooooooob
gnaggnoyil's Avatar
I can make sure that crt is static linked using MSVC. STATIC_LINK_CRT is set true and the generated executable can run without Microsoft Visual C++ Redistributable.
And the executable is just 1.5MB file size.
vapoursynth auto deint script
gnaggnoyil is offline   Reply With Quote
Old 5th August 2013, 18:26   #203  |  Link
Isn't x265 GPL? If so you have to supply the source code as well, per GPL. Failure to comply will result in your posts being deleted. Also, no foreign languages in your signature. Thank you.
Old 5th August 2013, 18:51   #204  |  Link
nevcairiel
He just created a vanilla build with a special flag on the build command line, how does that require sources? o.O
Old 5th August 2013, 18:57   #205  |  Link
gnaggnoyil
Nooooooooooooooob
gnaggnoyil's Avatar
sorry i didn't thought that it is a kind of "redistribution". i've uploaded a screenshot instead.
Old 7th August 2013, 06:42   #206  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
It is, but the GPL actually only requires "source code on request"; pointing to the exact git revision on bitbucket would satisfy the requirement, unless you applied any patches.
Old 13th August 2013, 17:51   #207  |  Link
roa
I made some tests for HEVC HM 9.0 and h.264 (ffmpeg).
For a video in CIF format, with a Gop size of 4, in lossy mode - 1bit/pixel I got the following results:
=> PSNR luma for h.264 = 30 dB
=> PSNR luma for HEVC = 31 dB
Does anyone have any idea? I think I should obtain much more better results with HEVC.
Thank you in advance
roa is offline   Reply With Quote
Old 13th August 2013, 18:27   #208  |  Link
x265_Project
Originally Posted by roa View Post
I would use HM 10.1 or 11 for your tests. The trick to running the HM reference encoder is to create the right configuration file for your video input. In the HM distribution there is a cfg subfolder that contains standard configuration files. I would start with encoder_randomaccess_main.cfg. In this cfg folder there is a per_sequence subfolder that has the File I/O settings for each standard test sequence. You have to edit this section for your cfg file to match your input test video.
PSNR values will depend on the bit rate for each encoder, as well as the settings for all of the many decisions that encoders must make (run fast, or take your time and find the best possible result). PSNR values alone are meaningless. We have to look at PSNR vs bit rate, and at the same time, PSNR vs encoding speed. Of course, experts will also tell you that PSNR isn't the best measure of visual quality (and they're right)... but that's another topic.
By the way... we've posted a new Evaluator's Guide on the x265 repository... https://bitbucket.org/multicoreware/x265/downloads/x265%20Evaluators%20Guide%2008-12-13.pdf
Tom
MulticoreWare
x265_Project is offline   Reply With Quote
Old 15th August 2013, 18:03   #209  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
Possible someone make x265.exe build with last source?
thx.
Le Sagittaire ... ;-)
1- Ateme AVC or x264
2- VP7 or RV10 only for anime
3- XviD, DivX or WMV9
Old 15th August 2013, 18:58   #210  |  Link
MasterNobody
thx.
x265+src.zip version 0.3+355-23d8d29c5242 (rev 3512)
MasterNobody is offline   Reply With Quote
Old 16th August 2013, 12:46   #211  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
well http://www.sendspace.com/ don't work. It's really bad idea to use that for download. I download a lot of spyware. It's really ... big and beautifull shit ... ;-). Anyway thx.
Old 16th August 2013, 12:49   #212  |  Link
phate89
It is enough read well and avoid to download the file with their download manager and it works well..
phate89 is offline   Reply With Quote
Old 16th August 2013, 13:01   #213  |  Link
LigH
LigH's Avatar
Maybe MediaFire has less annoying and confusing ads. (Hope you don't mind the mirror, MasterNobody.)
__
P.S.: Did I miss them already being available, or are AviSynth compatible decoders (e.g. LAV / L-SMASH) "planned soon™"?
New German Gleitz board
Old 16th August 2013, 13:42   #214  |  Link
nevcairiel
ffmpeg/Libav have a decoder in the works, which still needs a lot of cleanup, but is otherwise functional .. it may appear somewhat "soon" in the source tree, an exact time plan is impossible to say of course.
Old 16th August 2013, 13:45   #215  |  Link
LigH
LigH's Avatar
Well, x265 can read raw YUV or Y4M only still, so testers will get used to its handling rather soon.
What are currently recommended filename extensions for the raw H.265/HEVC output?
Old 16th August 2013, 15:20   #216  |  Link
easyfab
With the hevc decoder patch for libav, the raw extension are : "hevc,h265,265"
And yes the decoder seems to work well with x265. Hope HEVC file format in mp4 and mkv will be soon available.
Old 16th August 2013, 15:30   #217  |  Link
LigH
LigH's Avatar
The MP4Box in GPAC 0.5.1 Nightly Builds multiplexes HEVC into MP4. I just tested the Sintel trailer which took ~1:23h with defaults.
x265.exe sintel_trailer_1080.y4m -o sintel_trailer_1080.hevc
mp4box.exe -add sintel_trailer_1080.hevc#trackID=1:fps=24.0 -new sintel_trailer_1080_hevc.mp4
And its Osmo4 plays it ... well ... possibly not multi-threaded, it can hardly cope with FullHD resolution (1080p).
The default quantization of x265 (QP = 32) is too coarse. My result had ~360 kbps which is too little for FullHD; yet, it had a few surprisingly sharp details.
Old 16th August 2013, 15:40   #218  |  Link
easyfab
Yes I know that GPAC can mux hevc in mp4 and there is also a Divx muxer for mkv and xhevc muxer for flv, but no real standard, if I remember correctly JEEB said that the HEVC file format is under certification procedure and the final draft is not available yet.
Old 16th August 2013, 21:27   #219  |  Link
xooyoozoo
DivX has released a plugin for their web player if you want to try playing HEVC in your browser. You'd need to use their MKV mixer, and they claim a quad core i5 can do realtime 1080p decoding with their Tears of Steel clips.
I haven't tested it, but maybe their decoder could be more optimized.
Just remember that, by default, biprediction is currently turned off in x265, which makes bitrate to quality assessments a bit more difficult unless you're explicit interested in low-delay scenarios.
I imagine all the fades in the Sintel trailer would also benefit from turning on weighted prediction too, and all this is currently quite unoptimized and slow.
xooyoozoo is offline   Reply With Quote
Old 17th August 2013, 12:36   #220  |  Link
jq963152
What about MMT container:
http://en.wikipedia.org/wiki/MPEG_media_transport
jq963152 is offline   Reply With Quote
