6th March 2010, 03:30 | #41 | Link |
thanks for the update teba
StaxRip at Doom9's | StaxRip at Sourceforge [RSS] | StaxRip Donations | TheMTiNFo |
2nd April 2010, 09:13 | #42 | Link |
Which chain of command should I use in useac3to to extract and convert the core of a DTS-THDMA track?
I use Code:
-core %_.ac3 -640 -2pass Code:
Please specify the source and dest files first and then the options. |
2nd April 2010, 10:58 | #43 | Link |
Please put the full log to know the input file (DTS-MA or TrueHD?, audio only or container source?. 5.1 input or 6.1-7.1?, ArcSoft decoder installed or not?).
First dest file (Track Input (if source is a container) and Output format): %_.ac3 After the parameters, no matter the order: -640 (not needed because is the default) -2pass (not needed because is the default if eac3to detect a overflow in first pass) -core (not recommended if source is lossless) If source is lossless 6.1 or 7.1 DTS-HD (and you have the ArcSoft decoder, if not -core is the default) or TrueHD is better use: -down6
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 2nd April 2010 at 11:12. |
2nd April 2010, 12:26 | #44 | Link |
Arcsoft not installed, but not working when I installed ArcSoft Total Media Theatre.
MediaInfo: Code:
General Complete name : E:\qqqqq.mkv Format : Matroska File size : 6.50 GiB Duration : 2h 0mn Overall bit rate : 7 729 Kbps Encoded date : UTC 2009-09-30 13:38:59 Writing application : mkvmerge v2.6.0 ('Kelly watch the Stars') built on Mar 24 2009 15:23:17 Writing library : libebml v0.7.7 + libmatroska v0.8.1 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 8 frames Muxing mode : Container profile=Unknown@4.1 Codec ID : V_MPEG4/ISO/AVC Duration : 2h 0mn Bit rate : 5 426 Kbps Nominal bit rate : 5 581 Kbps Width : 1 280 pixels Height : 528 pixels Display aspect ratio : 2.40:1 Frame rate : 23.976 fps Resolution : 8 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.335 Stream size : 4.56 GiB (70%) Title : Eight.Below.2006 Writing library : x264 core 68 r1183M f21daff Encoding settings : cabac=1 / ref=8 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=9 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=12 / nr=0 / decimate=0 / mbaff=0 / bframes=4 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=5581 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.80 Language : English Audio #1 ID : 2 Format : DTS Format/Info : Digital Theater Systems Codec ID : A_DTS Duration : 2h 0mn Bit rate mode : Constant Bit rate : 1 510 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Surround: L R, LFE Sampling rate : 48.0 KHz Resolution : 24 bits Stream size : 1.27 GiB (20%) Title : DTS-HDMA core 1536k Language : English Code:
eac3to v3.18 command line: "E:\useac3to\eac3to.exe" "E:\zzzzzzz\ddddd TN 2 DTS-HDMA core 1536k - en-English.dts" -progressnumbers -log="E:\useac3to\UsEac3To.log" ------------------------------------------------------------------------------ DTS, 5.1 channels, 2:00:24, 24 bits, 1510kbps, 48khz Last edited by chagos; 2nd April 2010 at 12:37. |
3rd April 2010, 03:57 | #45 | Link |
DVD Magistrate
the arcsoft decoders work fine in xp sp3...only for version two of total media theater though!!!
try: If EAC3to says it cannot find Arcsoft Decoders, do the following (try in this order): 1. Add to the PATH envirnonment variable in XP C:\Program Files\Common Files\ArcSoft\Bin 2. Goto C:\Program Files\ArcSoft\TotalMedia Theatre\Codec and open DOS window and enter regsvr32 ASAudioHD.ax Or goto Start and then Run and copy: regsvr32 C:\Program Files\ArcSoft\TotalMedia Theatre\Codec\ASAudioHD.ax hit enter!!! #2 should work in MOST if not ALL cases. 3. do #2 above for arcdemux.ax, asaudio.ax, asudioeffecthd.ax, and asaudiohd.ax of #2 alone does not work 4. DTS decoding may only work when you copy MagCore.dll, MagPCMac.dll, MagUIEngine.dll and MagUIInter.dll from Program Files\Common Files\ArcSoft\Bin\ to eac3to\ (last item to try) NOTE: In DOS window typing EAC3to -test (or see GUI for Test) will let you see available filters. Choose "none" as decoder option in EAC3to to decode DTS with Arcsoft Decoders. You can also unregister all the decoders if you want, then register just the DTS one: after installing TMT, open up a command prompt, cd to the directory that contains the filters and run: for /F %i in ('dir /B') do@regsvr32 /u /s %i you then just regsvr32 the ax/dll's you need for DTS decoding. The names of the dlls are pretty obvious. |
3rd April 2010, 13:56 | #47 | Link |
I've found this working solution:
1. Copy the next files from an ArcSoft Total Media Theatre 3.0.1.170 Platinum Retail installation to eac3to folder: ASAudioHD.ax DtsDec.dll dtsdecoderdll.dll MagCore.dll MagPCMac.dll MagUIEngine.dll MagUIInter.dll 2. Copy checkactivate.dll from a Total Media Theatre 2 trial version installation to eac3to folder 3. Register ASAudioHD.ax I've notice that in this case eac3to encode in a single pass. |
18th April 2010, 16:21 | #49 | Link |
The WAVs extracted with tsmuxer are broken, use eac3to instead.
Drag & Drop the folder with BRip over UsEac3to, select feature (if more than 1), select track and ac3 output (with -down6 and/or -resampleTo48000 if necessary) If you want encode to DTS (not recommended) you can select 'wavs' output to obtain 6 monowavs and encode to DTS with a external encoder.
18th April 2010, 16:53 | #50 | Link |
The blu-ray has already an ac3 @640 kbps audio stream.
Your concern is about quality of pcm->dts encoding or about the size of the audio stream ? Already read that ac3 @640 kbps is almost good as dts @1536 kbps, but I'm not sure. What is your opinion ? |
18th April 2010, 20:03 | #51 | Link |
Less size, more compatible, and maybe more or at least equal quality.
To distinguish between PCM-source and the DTS-1536/AC3-640 encodes you need: 1) A room acoustic condioned. 2) A very good audio equipament (receiver and speakers). 3) Good ears. I haven't that room, my audio equipment is not so good (~1000€) and my ears are very old. Someone say than the AC3-640 is more close to PCM-source than DTS-1536. I don't know for me is the same.
25th May 2010, 02:28 | #52 | Link |
Light update (only the GUI): UsEac3to07.7z
v0.7 2010-05-25 eac3to Help, Track input filled with only audio, Settings improved.
18th July 2010, 22:12 | #53 | Link |
Life's clearer in 4K UHD
I've been meaning to ask...
Can your application be used to split the "core" and "HD" audio streams into separate streams?
19th July 2010, 13:09 | #55 | Link |
19th July 2010, 18:05 | #56 | Link |
With:
... 1: h264/AVC, 1080i60 /1.001 (16:9) 2: DTS Master Audio, 7.1 channels, 24 bits, 96khz (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48khz) Select 'Frequent parameters': core, 'Add' Now the command line is: 2: %_2.dts -core Press 'RUN Command line' and you have the dts core, with: 2: %_2.dtshd you have the full DTSMA If the Bluray source have a TrueHD track (3) 3: %_3.ac3 extract the included ac3 track 3: %_3.thd extract only the thd part 3: %_3.tdh+ac3 extract the full track
19th July 2010, 19:26 | #57 | Link |
Thanks for that...
Is it possible to extract the DTS HD audio stream without the core? Cheers
19th July 2010, 19:46 | #58 | Link |
nope...core is mandatory for dts-ma!
_
if you ask a question and somebody give you the correct answer don't forget to leave a "thank you" note... Visit The Land Of Dracula (Romania - EU)! |
19th July 2010, 20:42 | #59 | Link |
Yes, I understand that the "core" is mandatory for use with the Blu-ray disc format.
But does this also mean the inclusion of the core is mandatory for DTS-HD MA and DTS-HD HR streams as an audio format? If this is the case, I guess I'll need a method of transcoding the DTS-HD element to say, PCM or FLAC
20th July 2010, 09:18 | #60 | Link |
Yes, the HD part is a complement to core part.
You need the ArcSoft DTS-HD decoder http://forum.doom9.org/showthread.ph...77#post1398577
