3rd May 2010, 18:04 | #21 | Link |
I have to confirm what flebber already noticed - v.0.40 is pretty unstable. Besides of the crash during the analyse there are some crashes during the encoding.
And also one more remark - VidCoder 0.40 behaves like an app which must run in realtime. It horribly slows down apps which run concurrently, which is irritating, e.g. YoWindows (screensaver) opens in nearly a minute, closes even more sluggish. |
4th May 2010, 18:14 | #23 | Link |
VidCoder Author
Well, hopefully getting a stable release of the HB core will help the stability issues. Also it would help if I had a source file that caused a crash so I could see if I can isolate what the problem is.
In the next version I'll add in lowering the CPU priority during encodes, that defaults to below normal and is customizable. |
6th May 2010, 17:51 | #25 | Link |
I try to recode this video http://www.youtube.com/watch?v=L_fCqg92qks to mp4 FFMPEG 2pass for my phone and crash just when u press stat.
Problem signature: Problem Event Name: APPCRASH Application Name: VidCoder.exe Application Version: 0.4.0.0 Application Timestamp: 4bdca10e Fault Module Name: hb.dll Fault Module Version: 0.0.0.0 Fault Module Timestamp: 4bd23e06 Exception Code: c0000005 Exception Offset: 0005647d OS Version: 6.1.7600.2.0.0.272.7 Locale ID: 1033 Additional Information 1: 0a9e Additional Information 2: 0a9e372d3b4ad19135b953a78882e789 Additional Information 3: 0a9e Additional Information 4: 0a9e372d3b4ad19135b953a78882e789 |
9th May 2010, 19:43 | #27 | Link |
Same that from Youtube. I reinstalled, restarted windows and it was worked fine.
I encoded few music videos from some Original Music DVD with AnyDVD installed and that was working perfect. All 23 Songs converted in few minutes. Some of them with 350 fps 2 pass in x264 this time. |
10th May 2010, 02:27 | #28 | Link |
I've been trying out this new app today, looks very promising! Created two MKV files from 4-5 minute test files (MKV and M2TS). Very easy to use, excellent results.
However, I'm unable to open any DVD folder structure from the hard drive. Tried several different ones, always with a "Vidcoder has stopped working" error. Tried on 2 computers, both with Windows 7. One has Ultimate x64, the other Professional x86. Same results on both. |
18th May 2010, 03:57 | #30 | Link |
VidCoder Author
New release: 0.4.1:
Changes: * Marks system as "working" to prevent computer from sleeping during an encode. * CPU priority changed to BelowNormal during encodes. * Encode percentage displayed on progress bar. * Added additional options for custom format auto-naming: {preset}, {date}, {time} and {quality}. * Fixed crash on re-opening settings window. * Fixed crash on adding SRT subtitles. * Fixed null reference exception on some batch encoding. * Fixed exception when HandBrake logs an empty line. * Fixed video encoder not updating on revert or change of preset. Should prompt you to update next time you close VidCoder. |
19th May 2010, 14:39 | #32 | Link |
Practising Schemer
Updated to 0.4.1 and my previous issue with flv files http://forum.doom9.org/showthread.ph...13#post1396513 and the new version has resolved it. I have just completd a successful encode. Like the progress bar to . good stuff.
14th June 2010, 23:30 | #33 | Link |
I just want to thank you for this amazing front-end! I'm in the process of converting my TV collection from DVDs to my NAS, and the ability to choose multiple titles from the DVD rip has been a lifesaver.
Out of curiosity, is there a way to increase the gain when using faac? The resulting audio's volume is noticeably quieter than when I used the Nero aac encoder with MeGUI. |
28th June 2010, 01:17 | #37 | Link |
VidCoder Author
VidCoder 0.5.0 is out. Should auto-update when you next close it.
* Adds a Completed Items list, where you can check up on the encode time, status (Succeeded/Failed) and play the finished file by double-clicking. * Also added Apple presets, but the advanced x264 options are wrong for the iPad preset... just delete them and it should be fine; will be fixed in the next patch. * Fixed a few more bugs, updated the folder picker dialog, added peak framerate control, and added the smart title picking from Handbrake (can pick out the correct title from a bunch of scrambled ones). lilhobo: That's odd. Does it happen with all source material you try? |
29th June 2010, 01:19 | #38 | Link |
AAC Audio encoding is really bad can you fix that!
NS93_[SAMPLE].mkv http://www.mediafire.com/download.php?knqojyzmzmy NS93_[SAMPLE][VidCoder].mkv http://www.mediafire.com/download.php?onizmqqamfy Last edited by fAy01; 29th June 2010 at 01:29. |
29th June 2010, 13:40 | #39 | Link |
Im aware this is more of a Handbrake issue, but I'll throw it out there anyways...
x264 has been using presets for encoding speed for a while now. Is it possible to get a list of vidcoder x264 settings that match up to the presets? IE If I want to encode similar to "slow" preset, then I must set option 1 to x, and option 2 to y, etc... Otherwise, awesome app |
29th June 2010, 16:39 | #40 | Link | |
