5th September 2017, 01:28 | #81 | Link |
Thanks for the tip. With that in mind, I am able to compile r7 on Ubuntu 16.04 without too much difficulty.
Any ideas when gnu will offer support for that version of data()? It looks like the makefile is already geared up with that flag: Code:
AM_CXXFLAGS = -O2 -std=c++1z -msse2 -mfpmath=sse $(STACKREALIGN) -Wall -Wextra -Wno-unused-parameter -Wshadow |
1st November 2017, 02:13 | #84 | Link | |
https://drive.google.com/file/d/0Bxn...ew?usp=sharing You have to put all DLLs under plugins64 directory as my build is not as static as feisty2's and has two dependencies. I also added libfftw3-3.dll.bak file for any reason that your version of FFTW might not work, just rename back to .dll to use it. |
12th February 2018, 13:00 | #85 | Link |
Does your mvtools version has some other dependency except libfftw3-3.dll ? It works on my Desktop PC but not on a Win server 2012. I installed every c/c++ runtime I could think of.
This is the script I'm using https://forum.doom9.org/showthread.p...33#post1833133 I get this error using VS R43 x64: Code:
Problem Event Name: APPCRASH Application Name: vspipe.exe Application Version: 0.0.0.0 Application Timestamp: 5a721c1c Fault Module Name: libmvtools_sf_em64t.dll Fault Module Version: 0.0.0.0 Fault Module time stamp: 59492968 Exception code: c000001d Except Offset: 00000000000ea5fd OS Version: 6.2.9200.2.0.0.272.7 Locale ID: 1031 Additional information 1: e868 Additional Information 2: e8684f6eaacb2ee3a8b23fd72a9ac907 Additional information 3: b387 Additional Information 4: b38712ff53fac18241870cc7b35aa182
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 12th February 2018 at 13:02. |
12th February 2018, 20:51 | #87 | Link |
It's a i7 3770, only AVX https://ark.intel.com/de/products/65...up-to-3_90-GHz
//Edit: The compiled dll by chawl works, thx!
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 12th February 2018 at 21:47. |
6th May 2018, 21:42 | #88 | Link |
Could someone compile a new x64 binary (non avx2) of this filter? chawl's version produces some green frames with R43. Thank you!
10th May 2018, 09:13 | #89 | Link |
Thank you HolyWu.
But something is still not right. Both compiled version (sse and avx) produces also broken images. The sse version shows a green overlay I think. The strange part is, that all dlls work fine with my ryzen 1700(supports AVX2). But on a i5 3770 it's garbage.
12th July 2018, 12:51 | #90 | Link |
Professional Code Monkey
So this plugin requires the double precision fftw3 dll? Or am I mistaken?
VapourSynth - proving that scripting languages and video processing isn't dead yet Last edited by Myrsloik; 12th July 2018 at 13:07. |
14th May 2020, 21:50 | #93 | Link |
I'm Siri
major update:
- the mvmulti python module is now deprecated, all mvmulti stuff has been embedded into the C++ plugin. - mvsf.Degrain can now handle arbitrary radius (not limited to 24) - mvsf.Degrain1/Degrain2/.../Degrain24 are removed, the only MDegrain function is now mvsf.Degrain, which works for any radius. - mvsf.Analyse is removed, type "Analyze" instead - new parameter "radius" for mvsf.Analyze, when specified, mvsf.Analyze generates a compound vector clip that works for mvsf.Degrain/Compensate/Flow/Recalculate - mvsf.Compensate/Flow/Recalculate automatically output compound results when provided a compound vector clip - mvsf.Degrain automatically deduces the radius from the compound vector clip, you don't need to specify the radius - when "radius" is specified for mvsf.Analyze, "isb" and "delta" are ignored. - new parameter "cclip" for mvsf.Compensate/Flow, same as in the mvmulti python module, only takes effect for compound outputs. Code:
#MDegrainN sup = core.mvsf.Super(clip) vec = core.mvsf.Analyze(sup, radius=6, overlap=4) vec = core.mvsf.Recalculate(sup, vec, blksize=4, overlap=2) clip = core.mvsf.Degrain(clip, sup, vec, thsad=400) #motion compensated dfftest sup = core.mvsf.Super(clip) vec = core.mvsf.Analyze(sup, radius=6, overlap=4) vec = core.mvsf.Recalculate(sup, vec, blksize=4, overlap=2) clip = core.mvsf.Compensate(clip, sup, vec) clip = core.dfttest.DFTTest(clip, tbsize=2*6+1, tmode=0) clip = core.std.SelectEvery(clip, 2*6+1, 6) the windows binary is currently unavailable because msvc does not support tons of C++20 core language features. |
15th May 2020, 07:02 | #94 | Link |
Wow that's awesome
How is the speed compared to your previous implementation? Does this version also supports 8..16 bits per sample?
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 15th May 2020 at 07:05. |
15th May 2020, 10:31 | #96 | Link |
I'm Siri
can someone please build a binary for windows?
the binary I built relies on a bunch of Cygwin dlls. to build the binary, you need to: 1) get "Include" folder from vsFilterScript 2) place "VapourSynth.h", "VSHelper.h", "fftw3.h" in the "Include" folder 3) compile and link "vapoursynth.lib", "libfftw3-3.lib" |
15th May 2020, 10:43 | #97 | Link |
It doesn't build on Linux
g++ -std=c++20 -IvsFilterScript -I/usr/include/vapoursynth -shared -fPIC -march=native -Ofast -o libmvtoolssf.so src/EntryPoint.cxx -lvapoursynth -lfftw3 In file included from /usr/lib/gcc/x86_64-pc-linux-gnu/10.1.0/include/g++-v10/cmath:45, from vsFilterScript/Include/Infrastructure.hxx:15, from vsFilterScript/Include/Range.hxx:2, from vsFilterScript/Include/Plane.hxx:2, from vsFilterScript/Include/Frame.hxx:3, from vsFilterScript/Include/Clip.hxx:2, from vsFilterScript/Include/Map.hxx:2, from vsFilterScript/Include/Plugin.hxx:2, from vsFilterScript/Include/Core.hxx:2, from vsFilterScript/Include/Interface.hxx:2, from src/EntryPoint.cxx:1: src/Overlap.h:5:16: error: expected unqualified-id before numeric constant 5 | constexpr auto M_PI = 3.1415926535897932384626433832795; | Code:
$ LANG=C gcc --version gcc (Gentoo 10.1.0 p1) 10.1.0 Copyright (C) 2020 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. |
15th May 2020, 11:11 | #99 | Link |
Nice. Only has a quick overview on the code.
The "auto"-count is shocking I had to look up cpp documentation frequently for the used syntax elements. I can see that probably because of the large - but hugely simplified - code base the used coding conventions are mixed (std::int32_t, int32_t, auto; reinterpret_cast vs traditional cast). Or is there an intentional difference on their usage? Overlaps is still not 100% floating point, it still inherits the original code's two phase integer scaling 32 and 64 (32*64 is 2048 integer scale factor). (Neither did I eliminate it completely in avs mvtools, I'm still using integer base (lack of time) but there is no other intermediate scaling happens when dealing with float clips) |
