17th April 2005, 17:38 | #801 | Link |
About b-frames.
When using them, BSPlayer refuses to play the file and gives me this error message: "List index out of bounds (0)" Also, the same file acts strange in videolan. It shows artefacts like this: Same file plays fine in Media Player Classic.
AMD Athlon 64 3000+ 2.0 GHz Nvidia GeForce FX5200, 256 MB Gigabyte nForce3 250, 512 MB RAM Maxtor 80 GB 7200rpm XP PRO 5.1 (Build 2600) SP2 TDK DVDRW882N|TEAC CD-W540E|ASUS E616 |
18th April 2005, 04:01 | #802 | Link | |
interlace this!
another thing i'd really love to see is a "segment re-encode" feature (maybe this is best suited to Virtualdub's interface?). ie. you watch the movie, and note all the crappy bits. you then set I-frame (or IDR frame for AVC, i suppose) in and out points, and re-encode the bad part using the same GOP structure. i know DVDMaestro offers this (and it's reeeeally nice to use if you've got the Spruce MPX3000 encoder card plugged in - seamless integration with the authoring app). it'd be good to see this built into an mpeg-4 solution - this would mean if your encode is undersized, it's not a problem. it also means if you're using a not-so-good encoder (WMV? Divx 3?) you can still get nice encodes if you re-do enough segments (this is exactly what the feature is for in Maestro - mpeg-2 isn't the best codec, and sometimes a client just wants so much video on a disc that the bitrates go way down). well, this is also a pipe dream, but i'm sure lots of tweekers would find it useful (the kind who use YATTA for instance )
sucking the life out of your videos since 2004 |
19th April 2005, 04:08 | #803 | Link |
I hadn't heard of YATTA before. Judging from its description, it sounds like it gets about halfway there for what I was wanting to do to clean up combing artifacts. I'll have to check it out. Thanks.
And since you mention setting IDR frames... part of my pipe dream includes the ability to force IDR frames at specified frames. This would be used in combination with the Nero-style chapters that have been recently integrated into mp4box. Chapter seeking would be very fast if the chapter is always set on an IDR frame. Anyway, that would be something nice to have built into x264, although not essential. And another cool feature to have in x264 would be the ability to use different deblocking strengths for different zones. Maybe that was already planned anyway? I think I've done maybe 30 or 40 encodes of Matrix3, and no matter what x264 parameters I set, I can't get rid of that damn horrendous blocking behind Merv on his balcony. But if I could jack up the deblocking strength to, say, 6, just for that scene, then I'd consider that progress. That would at least be one possibility for improving such troublesome scenes. Other possibilities all have to do with fancy AVS wizardry, so I suppose I'll save 'em for another thread. |
19th April 2005, 09:17 | #804 | Link | |
clueless n00b
21st April 2005, 23:53 | #806 | Link |
Senior n00b
some problems here when using b-refs with revision 215... but that's likely a skipping issue so probably a long-standing one. Very weird artifacts due to exaggerate skipping, or maybe some probs with direct mode + brefs, dunno. Anyway, cmdline:
x264 -m 3 -b 3 --b-pyramid --frames 300 -q 27 -o x264-r215-brefs.mp4 ~/mplayer/main/test-2.avs The result is available here (627 KB). Look at frames 200 and following. The mess on the woman's face is evident. Frame 230 (according to MPlayer's numbering, ffdshow's may differ) seems the worse. I got a report (thanks to AlexW) that even decoding with JM the artifacts are there, so it's definitely an encoding issue. The quantizer of bvops is 28-29 here so nothing exceptionally low; not enough to justify such problems, at least. Similar problems happen (maybe even worse) when using -m 5 so it's not directly related to the ME type. Last edited by virus; 21st April 2005 at 23:55. |
21st April 2005, 23:58 | #807 | Link | |
i saw that especially with -q 20 -b 5 --b-bias 100 --b-pyramid btw the new --progress option rocks! would be cool if it gets enabled by default
Between the weak and the strong one it is the freedom which oppresses and the law that liberates (Jean Jacques Rousseau) I know, that I know nothing (Socrates) MPEG-4 ASP FAQ | AVC/H.264 FAQ | AAC FAQ | MP4 FAQ | MP4Menu stores DVD Menus in MP4 (guide) Ogg Theora | Ogg Vorbis use WM9 today and get Micro$oft controlling the A/V market tomorrow for free Last edited by bond; 22nd April 2005 at 00:05. |
22nd April 2005, 05:10 | #808 | Link | |
x264 developer
28th April 2005, 16:39 | #809 | Link |
feature request: Choosing SAR values from the vfw version...
(I know I've asked that before in this same thread, but I hadn't mentioned the vfw version specifically and at the time this feature had already been introduced in the CLI version) |
28th April 2005, 18:06 | #810 | Link |
Why don'y use the CLI x264 encoder?
It isn't hard to use than vfw and more up-to-date imho. But still i hope x264 devs or other contributors can update this vfw @rushin_911: You can transmuxing the video to MKV and changing the D/SAR via MKVtoonix. I've tried with MKVToolnix, the D/SAR is ignore by ffdsohw(or haali matroska splitter?)... Only MPlayer is respect the MKV D/SAR value. EDIT: nasty typo... Last edited by Yong; 28th April 2005 at 18:39. |
28th April 2005, 18:26 | #811 | Link |
retired developer
I'm thinking about adding CLI in RealAnime, instead of only using the VFW one. Since it supports AVS, it will be easy to implement.
Detritus Software |
29th April 2005, 11:56 | #812 | Link | |
As for the MKVtoolnix I already use the DAR values from it when muxing into MKV, unfortunatly though it“s, as you have stated, ignored by ffdshow even when enabling overlay and also ignored by Media Player Classic (my player of preference)... My request for the SAR values to be visible in the VFW however are for when I mux the media files created into the MP4 format. |
29th April 2005, 13:06 | #813 | Link |
@rushin_911:
@echo off IF '%1'=='' GOTO EOF title X264 Encoder start /belownormal /b /w X264 -p 1 --stats "%userprofile%\desktop\X264[%~n1].log" -o nul: %1 --progress start /belownormal /b /w X264 -p 2 --stats "%userprofile%\desktop\X264[%~n1].log" -o "%userprofile%\desktop\%~n1.mp4" %1 --progress pause :EOF u can try to add other cli option if u need like, --b-pyramid, --weightb and --subme 5. |
1st May 2005, 05:44 | #814 | Link |
BUGS...
can anyone play those video clip normally from VSoft's h264 free video clips download section?
http://www.vsofts.com/h264/videoclips.html Mplayer and ffdshow hang when playing those CIF and D1 video clips... (becareful, my computer almost freeeeeeze when playing with ffdshow ) Second, i think there may be a problem in x264 encoders , when playing x264 encodeds with libavcodec in grayscale mode, mplayer and ffdshow both show some random big green blocks when playing(extra, flashing green in mplayer), but HD video clip from apple website doesn't have this kind of problem... stupid typo again... Ok, finally i found some playable clips from LEAD h264 free video clips , forget the buggy VSS video clips Last edited by Yong; 1st May 2005 at 06:06. |
1st May 2005, 06:47 | #815 | Link |
dead
Can anyone help tell me which values in the VFW are relative to the CLI values? I can pick out all but two, b-frames reduction % and bitrate variability %. I encode mainly Anime, and want to jump to the CLI version to have some of the newer options. My current setup im working with looks like:
@echo off start /belownormal /b /w x264 -I 300 -i 30 -b 2 -A all -w --b-pyramid --no-chroma-me -p 1 --stats "X264[%~n1].log" -o nul: %1 --progress encode.avs start /belownormal /b /w x264 --merange 32 -I 300 -i 30 -b 2 -f 1:0 -B 1453 -r 8 -A all -w --me esa --b-pyramid --chroma-qp-offset 2 -p 2 --stats "X264[%~n1].log" -o "encode.mp4" %1 --progress encode.avs Thanx in advance... |
1st May 2005, 10:46 | #816 | Link | |
clueless n00b
http://forum.doom9.org/showthread.php?s=&threadid=73022 you'll see that the AVC Main profile does not support custom quantizer matrices.
1st May 2005, 12:05 | #817 | Link |
Testeur de codecs
good quality with good speed
x264.exe --bframe 2 --ref 5 --pass 1 --stats "x264_stat.log" --qcomp 0.75 --ipratio 1.10 --pbratio 1.30 --analyse "all" --weightb --progress -o x264-HDTV.mp4 HDTV.avs x264.exe --bframe 2 --ref 5 --bitrate 2500 --pass 3 --stats "x264_stat.log" --qcomp 0.75 --ipratio 1.10 --pbratio 1.30 --analyse "all" --weightb --progress -o x264-HDTV.mp4 HDTV.avs x264.exe --bframe 2 --ref 5 --bitrate 2500 --pass 2 --stats "x264_stat.log" --qcomp 0.75 --ipratio 1.10 --pbratio 1.30 --analyse "all" --weightb --progress -o x264-HDTV.mp4 HDTV.avs "esa" is too slow and quality improuvement is really small bpyramid don't improve quality and playback is not good
Le Sagittaire ... ;-) 1- Ateme AVC or x264 2- VP7 or RV10 only for anime 3- XviD, DivX or WMV9 |
1st May 2005, 13:03 | #818 | Link | |
no b pyramid: x264 [info]: PSNR Mean Y:42.93 U:46.83 V:46.70 Avg:43.66 Global:41.87 kb/s:604.7 b pyramid: x264 [info]: PSNR Mean Y:42.56 U:46.74 V:46.66 Avg:43.30 Global:42.00 kb/s:601.0 EDIT: So far i haven't encountered any playback problem with b-pyramid... Last edited by Yong; 1st May 2005 at 13:05. |
1st May 2005, 13:21 | #819 | Link | |
- they use wav audio (good for the bandwidth...) - they place avc in a bastard version of the .ogm format (not listed as video stream) - they give the .ogm files the .avi extension - they dont seem to like p-frames, as their streams mainly use b-frames and a few i-frames funky
1st May 2005, 13:32 | #820 | Link | |||
i see the "RIFF" in the top of file Quote:
Hey Bond, can u play the free VSS h264 video clips normally? in my test, mplayer and ffdshow both crashed when playing |
