19th January 2010, 08:40 | #3141 | Link |
@stax76
Blu-ray workflow in StaxRip ideas: load Blu-ray folder or .m2ts scan source with eac3to StaxRip then processes the info from eac3to then either joins video tracks for seamless branching Blu-ray Discs, demux video track to raw .h264, .vc1 , mux to .mkv or skip video to index with DGIndexNV, FFMS2, DDS, DSS2 handle audio only like demux core tracks -core, convert to .flac, .m4a etc depending on what settings users set in StaxRip eac3to Command Line Syntax Usage Examples
StaxRip at Doom9's | StaxRip at Sourceforge [RSS] | StaxRip Donations | TheMTiNFo Last edited by MuLTiTaSK; 19th January 2010 at 09:23. |
19th January 2010, 13:35 | #3142 | Link |
@MuLTiTaSK
That don't seem to be compatible with StaxRip's audio handling. In StaxRip you have a audio source file, static command line based profiles and new dynamic GUI based profiles and in case a profile cannot handle the input format or cutting is used a intermediate conversion is performed. Here you don't have files but playlists and the only tool that can work on these playlists is the one that generated the playlist, eac3to. Currently I don't have a interest to develop a GUI for this playlist handling or try to integrate it with StaxRip's audio handling, maybe I develop a interest later. Greif's stream extractor is IIRC already included, it's in the eac3to folder and I'll make it available from Tools > Launch. It makes more sense to investigate MKV handling, currently everybody is using AnyDVD and eac3to to handle title extraction simply because these tools were available first and people develop habits quickly and easily. I don't have any habits yet and with my limited experience MakeMKV seems to be much better plus fits in StaxRip's audio handling because you have regular file, only thing that's new is that it can contain multiple streams, that's difficult to support but possible. Besides that MKV is a much better container supporting more formats, rich meta data and has little overhead, I've heard m2ts overhead is insane, that's one of the reasons I'm resistant to add m2ts output but favor MKV which is DivX Plus compatible which I fully support because I think it's great to have play MKV in the web browser and mkv compatible Blu-ray players and streaming players. Also people at DivX try their best to support my GUI and the encoding community and so do I with DivX. MakeMKV should be much faster. Also I didn't get an reply from SlySoft (requested 2 days before) to sponsor me a AnyDVD license, not that it's a problem since MakeMKV appear to be a much better solution anyway.
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 19th January 2010 at 13:48. |
19th January 2010, 16:19 | #3143 | Link | |
Ok, that's why I was confused. Ok |
19th January 2010, 16:20 | #3144 | Link |
HDConvertToX author
i would suggest the makemkv route.
it's free (now) and easy to integrate. Only one MKV output file, and easy to process with eac3to (for extraction audio tracks) don't try to use tsmuxer for demuxing audio from mkv since it has some problem with dts and other audio format BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
19th January 2010, 17:02 | #3145 | Link |
@stax76
i will send you the money for a AnyDVD-HD license?
StaxRip at Doom9's | StaxRip at Sourceforge [RSS] | StaxRip Donations | TheMTiNFo |
19th January 2010, 17:08 | #3146 | Link |
@MuLTiTaSK
Thanks for the offer but if a company isn't interested in their product being supported why should I care then? I rather support companies and programmers that support StaxRip like DivX, neuron2, Mosu etc. So far I've just sent a private message so maybe they didn't read it so far.
19th January 2010, 17:28 | #3147 | Link |
@stax76
Just in case this kind of info is usefull for you: mediainfo.dll 0.7.27 is available http://mediainfo.sourceforge.net/fr/Download/Windows you can get more recent ffmpeg builds there: http://ffmpeg.arrozcru.org/autobuilds/ |
19th January 2010, 17:35 | #3148 | Link |
@M4ST3R
Sure it's useful thanks, I don't have a clue how many applications and libraries StaxRip bundles, certainly many and it's constantly growing. I update some application more often then others, depends on how popular the application is, if it has important bug fixes, new features or optimizations etc.
19th January 2010, 18:19 | #3149 | Link |
When I click on Filters, a menu appears listing the source filters: automatic, mpeg-2, mpeg-2 deblocked, avc,...
But there's also a sub menu named advanced containing more or less (labels are a bit different) the same source filters. Is there a difference between selecting a filter from the main menu or from the advanced one? |
19th January 2010, 18:20 | #3150 | Link |
Thank you stax76 and MuLTiTaSK - I did get the CLI working by adding the full path to the input file. I normally reduce the frame rate of 720p to 29.97, but the only place I find frame rate mentioned is the %target_framerate% macro. Do I need to create a filter to reduce 59.94 to 29.97? Thanks!
19th January 2010, 18:27 | #3151 | Link | ||
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 19th January 2010 at 18:29. |
19th January 2010, 19:17 | #3152 | Link | |
I was going to stop asking questions now, but that reminds me that I saw the Decomb plugin installed, but I don't see an obvious way to use it? |
19th January 2010, 20:47 | #3153 | Link | |
20th January 2010, 01:29 | #3154 | Link | |
21st January 2010, 14:48 | #3157 | Link | |
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 21st January 2010 at 14:55. |
21st January 2010, 22:23 | #3158 | Link |
Acid fr0g
I am trying to encode a BD with StaxRip and DGToolsNV. I have created the .dgi file and imported as source in StaxRip. When I try to manually crop and exit, the windows stays there and StaxRip stops responding, with a minimum ~10% CPU occupation. Any idea of what is it doing?
Please fix this bug, I wouldn't use RipBot again
@turment on Telegram |
21st January 2010, 22:28 | #3159 | Link |
@tormento
Do you use the latest test build 1.1.4.3?
22nd January 2010, 07:11 | #3160 | Link |
I'm using the latest build 1.1.4.3 with DG NV tools build 2003 and I'm having trouble using the gpu deinterlacer. I've set the following options under profiles: DGSource = DGSource("%source_file%",deinterlace=1,resize_w=0,resize_h=0). When I look at the avs file it creates after it runs DGNVIndex it still shows deinterlace=0. I've tried to change the script manually as well as through "Show File-Avisynth Script", but as soon as it begins processing it still shows deinterlace=0. I like Yadiff, but I prefer to deinterlace with DG NV tools. Is there an easy way to fix this or am I missing a setting?
gui, h.264, h.265, hevc, mkv, x264, x265 |
