25th October 2009, 21:48 | #483 | Link |
Is there an issue with DTS? I went to demux a DTS track with DGMPGIndexNV and it doesn't show the track, yet in the regular dgindex it shows it and will demux it.
Source is multiple vobs from a DVD rip. PS) I'm still running beta 11, not ready to move forward to your new release 2 yet. Last edited by Jeff Flowerday; 25th October 2009 at 23:09. |
25th October 2009, 23:06 | #484 | Link |
Win7 64bit.
No problems here so far on 2 encodes.
http://www.7-zip.org/ |
26th October 2009, 04:40 | #486 | Link |
26th October 2009, 09:19 | #487 | Link |
Yes, but there have been no other reports of DTS not working. So chances are, the problem is limited to the source you are having problems with.
26th October 2009, 09:20 | #488 | Link | |
Or is it all streams?
26th October 2009, 16:55 | #493 | Link | |
I hope this problem was not already adressed elsewhere, at least I found nothing:
I am using DGVC1DecNV (latest beta) and MeGUI (latest version too). Since approx. 2 weeks, I get an error that I was so far unsuccessful to solve. First of all, the system: GTX 260, driver 191.07., Win XP MeGUI 0.3.1.1056 AviSynth 2.5.8 When I use a standard avisynth-script with MeGUI, for example Quote:
I always get the error: DGSource: Multiple instances not supported. In most of the cases the CUVID-Server crashes afterwards. When I then restart MeGUI, I am able to open the script, but encoding fails (same error). As already mentioned earlier in this thread, DGMulti can not be used with MeGUI, so what should I do? In my opinion there is no other instance running (already checked this using the taskmgr). In principle, that is using directshow or AVC (not NV), MeGUI works fine. Furthermore, I encoded serveral other files two weeks ago without problems, but did not change anything meanwhile... Thanks, Josh |
26th October 2009, 18:52 | #495 | Link | |
I need to back off this check to have things continue to work in MEGUI. I'll try to do it in the next few days. |
27th October 2009, 00:00 | #498 | Link | |
http://neuron2.net/dgavcdecnv/dgdecnv200b1.zip I removed the multi-instance check. |
27th October 2009, 00:43 | #499 | Link | |
LoadPlugin("C:\Program Files\DGIndexNV\DGMultiDecodeNV.dll") DGMultiSource("F:\Work\00999.dgv", resize_w=1280, resize_h=720) |
