7th December 2016, 23:34 | #321 | Link | |
tested in winxp sp3 32bit in VirtualBox the last Intel redist package is the problem, use this https://software.intel.com/sites/def...2016.1.146.zip
See My Avisynth Stuff Last edited by real.finder; 7th December 2016 at 23:37. |
8th December 2016, 01:03 | #322 | Link |
Broadcast Encoder
Thanks for the "trick".
With that, it works just fine. Tested a few minutes ago with: nnedi3_resize16(target_width=1280, target_height=720, mixed=true, thr=1.0, elast=1.5, nns=4, qual=2, etype=0, pscrn=4, threads=0, kernel_d="Spline", kernel_u="Spline", taps=12, f_d=1.0, f_u=2.0, sharp=0) to downscale from 1080p to 720p. Thanks for the update! |
19th December 2016, 14:34 | #323 | Link |
I found something odd in the nnedi3 code, and i think there is an error :
for (int y=0; y<ydia; ++y) { const uint8_t *srcpT = srcp+y_stride; for (int x=0; x<xdia; ++x, ++input) { sum += srcpT[x]; sumsq += srcpT[x]*srcpT[x]; input[0] = srcpT[x]; } y_stride+=stride2; } const float scale = 1.0f/(float)(xdia*ydia); mstd[0] = sum*scale; mstd[1] = sumsq*scale-mstd[0]*mstd[0]; Code:
mstd[1] = sumsq*scale*scale-mstd[0]*mstd[0]; Last edited by jpsdr; 19th December 2016 at 14:37. |
19th December 2016, 22:30 | #326 | Link |
Not knowing exactly what that part is for, but yeah, it sure looks odd.
Breaking it down, if - sum is just the sum of srcpT's, whatever those are. - sumsq is the sum of the squared srcpT's. - "sqsum" is the square of the sum (introducing my own variable). then - mstd[1] = (sumsq - sqsum*scale)*scale which looks weirdly unbalanced. Either - mstd[1] = (sumsq - sqsum)*scale or - mstd[1] = (sumsq - sqsum)*scale*scale would look better. I guess it's the latter (same as your suggested edit) because mstd[0] already has one scale, so squaring that has two. Edit: Then again, squaring scale is also weird, becase it's basically (the number of elements in the sum)^-1, so it's a normalization factor. Maybe it's supposed to be (sumsq - sqsum)*scale ? Like feisty said, try and see the results. Last edited by ajp_anton; 19th December 2016 at 22:39. |
20th December 2016, 00:33 | #327 | Link |
There's definitely something wrong, but you should look at entire source to figure out how to correct it.
Sadly any documentation in the source is missing. Here is my take. Disclaimer i understand nothing of the source. Most of the fun seems to be happing in the function evalFunc_2 in nnedi3.cpp. The code: Code:
void evalFunc_2(void *ps) { ... const int qual = pss->qual; const float scale = 1.0f/(float)qual; void (*extract)(const uint8_t*,const int,const int,const int,float*,float*); void (*wae5)(const float*,const int,float*); if (opt==1) wae5=weightedAvgElliottMul5_m16_C; else wae5=weightedAvgElliottMul5_m16_SSE2; ... if (fapprox&2) // use int16 dot products { if (opt==1) extract=extract_m8_i16_C; else extract=extract_m8_i16_SSE2; ... } else // use float dot products { if (opt==1) extract=extract_m8_C; else extract=extract_m8_SSE2; ... } ... extract(srcpp+x,src_pitch,xdia,ydia,mstd,input); ... wae5(temp,nns,mstd); ... if (opt>1) castScale_SSE(mstd,&scale,dstp+x); else dstp[x]=min(max((int)(mstd[3]*scale+0.5f),0),255); ... } castScale_SSE is defined nnedi3_asm.asm, but i don't know how to read asm. The function weightedAvgElliottMul5_m16_C which is called in evalFunc_2 (and is set to wae5) gives another clue: Code:
void weightedAvgElliottMul5_m16_C(const float *w,const int n,float *mstd) { ... if (wsum>min_weight_sum[0]) mstd[3]+=((5.0f*vsum)/wsum)*mstd[1]+mstd[0]; else mstd[3]+=mstd[0]; } Later on in the code, extract_m8_i16_C/extract_m8_i16_SSE2/extract_m8_C/extract_m8_SSE2, is set to extract. The function extract is called as Code:
extract(srcpp+x,src_pitch,xdia,ydia,mstd,input); Code:
void extract_m8_C(const uint8_t *srcp,const int stride,const int xdia,const int ydia,float *mstd,float *input) { ... const float scale = 1.0f/(float)(xdia*ydia); mstd[0] = sum*scale; mstd[1] = sumsq*scale-mstd[0]*mstd[0]; mstd[3] = 0.0f; if (mstd[1]<=FLT_EPSILON) mstd[1]=mstd[2]=0.0f; else { mstd[1]=sqrtf(mstd[1]); mstd[2]=1.0f/mstd[1]; } ... } If we change 'mstd[1] = sumsq*scale-mstd[0]*mstd[0];' to 'mstd[1] = sumsq*scale*scale-mstd[0]*mstd[0];', it implies that mstd[1] and mstd[0] differ a factor scale, but mstd[1] is overwritten by its square root later on, so 'mstd[1]=sqrtf(mstd[1]);'. So now mstd[1] and mstd[0] have the same scale which is consistent with the above. So you need to change that in all four functions. What i don't understand what mstd[2] is supposed to do. It has scale^(-1) compared to mstd[1]. I don't see where mstd[2] is used, and thus if its scaling is correct. Last edited by Wilbert; 20th December 2016 at 00:54. |
20th December 2016, 00:45 | #328 | Link |
mmm scale in evalFunc_2 is set to '1.0f/(float)qual;' with qual being an input parameter (being 1 or 2). While scale in extract_m8_C is equal to '1.0f/(float)(xdia*ydia);'.
qual doesn't seem equal to xdia*ydia to me?? xdia and ydia are set by Code:
pssInfo[i].xdia = xdiaTable[nsize]; pssInfo[i].ydia = ydiaTable[nsize]; Code:
const int xdiaTable[NUM_NSIZE] = {8,16,32,48,8,16,32}; const int ydiaTable[NUM_NSIZE] = {6,6,6,6,4,4,4}; Last edited by Wilbert; 20th December 2016 at 00:49. |
20th December 2016, 10:09 | #329 | Link |
Finaly, after viewing things in statistic way, it's good. mstd : probably Mean STandard Deviation.
mstd[0] is mean, mstd[1] is mean standard deviation, which is the square root of : mean of the sum of the squares, less the square of the mean. Sorry, my mistake. Last edited by jpsdr; 20th December 2016 at 10:12. |
20th December 2016, 12:43 | #330 | Link | |
Your post is a bit cryptic. I think you are right that it should be Code:
mstd[1] = sumsq*scale*scale-mstd[0]*mstd[0]; |
20th December 2016, 14:42 | #331 | Link |
Again error from my side, the mean standard deviations is not what i've said after checking (my memory was not exactly right). We are not far, but it's not exactly what is calculated here.
But, what is done here is the mean of the squares less the square of the mean, and viewing like this, it can somehow make sense. So, maybe the formula is correct. |
20th December 2016, 17:27 | #332 | Link | |
I give up. Leave the bugs in.
VAR[X] = E[(X-E[X])^2] = E[x^2]-E[X^2], SD[X] = sqrt(VAR[X]) |
20th December 2016, 17:51 | #333 | Link | |
I'm Siri
EDIT: Var(x) = E((x-E(x))^2) = E(x^2 - 2xE(x) + E(x)^2) = E(x^2) - 2E(x)E(x) + E(x)^2 = E(x^2) - E(x)^2 Last edited by feisty2; 20th December 2016 at 17:58. |
20th December 2016, 19:37 | #334 | Link |
So, finaly there is probably no bug, sumsq*scale-mstd[0]*mstd[0] produce the variance.
E(x^2)=sumsq*scale E(x)^2=mstd[0]*mstd[0] No...? Still not been able to get 16bits working, and i can't figure out where it's going wrong.... Last edited by jpsdr; 20th December 2016 at 19:43. |
20th December 2016, 22:45 | #335 | Link | |
Anyway. This scale factor is 1 by default (= qual input parameter). Could you make some screenshots voor qual=1 and qual=2 and compare them? |
20th December 2016, 23:59 | #336 | Link | |
Merry Xmas Wilbert et al. [Latin dont count as a foreign language as only dead Romans speak it + a few Swiss Romansch nearly Roman speakers [bout 10,000 I believe]]
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 21st December 2016 at 06:34. |
21st December 2016, 18:22 | #337 | Link |
After a bloody and painfull struggle, i've been able to make the 16bits working.
Can someone explain to me why this is working : Code:
const uint8_t *srcp = pss->srcp[b]; const uint8_t *srcpp = srcp-(ydia-1)*src_pitch-xdiad2m1; Code:
const uint8_t *srcp = pss->srcp[b]; const uint8_t *srcpp = srcp-((ydia-1)*src_pitch-xdiad2m1); Thanks again again to feisty2 for the code, it was very usefull, especialy for the init part and weight calcul adjustment. And future thanks also for the part i'll begin to work in : the ASM ! The code will be helpfull. |
21st December 2016, 18:44 | #338 | Link | |
Groucho's Avisynth Stuff Last edited by Groucho2004; 21st December 2016 at 18:50. |
21st December 2016, 19:42 | #340 | Link |
Great news, I suppose the hard thing was having uint16_t instead of a byte, does it automatically work for e.g. 10 bit videos? (Ideally all filters that work for 16 bits should also support 10, 12 and 14 bit videos)
