Old 28th July 2012, 20:50   #21  |  Link
sirt
x264 fan
sirt's Avatar
Originally Posted by jmac698 View Post
My theory doesn't seem right. I looked at a subtracted fields. There does seem to be some pattern however.
Thanks for reflecting about this ! Anyway it is too complex for me, the only thing I can do is test and see what happens.
sirt is offline   Reply With Quote
Old 28th July 2012, 21:09   #22  |  Link
mandarinka
mandarinka's Avatar
if it is regular enough, fft3dfilter could remove it if you supply a proper pattern image (the pattern mode).
mandarinka is offline   Reply With Quote
Old 28th July 2012, 21:46   #23  |  Link
sirt
x264 fan
sirt's Avatar
Thanks, do you have a configuration suggestion ?
Old 28th July 2012, 21:54   #24  |  Link
Wilbert
I don't see anything "blended" in this sample. The problem is that the fades were done after the telecine. I.e. those same-(24p)frame fields that are spread between two 30i frames have different brightness because of that, and don't fit together anymore.
I completely agree with Didee. You will have to undo the fading before ivtc-ing it (but i'm not sure whether this is possible to do in an acceptable way):
SeparateFields()
UnFade()
Weave()
Telecide(order=1, guide=1).Decimate(cycle=5)  #IVTC
Old 28th July 2012, 21:58   #25  |  Link
sirt
x264 fan
sirt's Avatar
SeparateFields()
UnFade()
Weave()
Thanks for your answer. What is that UnFade() ?
Old 29th July 2012, 00:58   #26  |  Link
Wilbert
The opposite of fade, but sadly such a filter doesn't exist.
Old 30th July 2012, 16:20   #27  |  Link
[bump after re-open]
Old 31st July 2012, 11:29   #28  |  Link
mirkosp
I know it's meant to deal with moving text, but wouldn't ivtc_txt60mc get a perfect result anyway? A fade should hopefully be easy enough to interpolate with good results. That said, even if you don't get the fade back to linear it's not that big of a problem, it's going to look fine anyway in motion. So alternatively to ivtc_txt60mc, the simple solution is just to use vinverse (as it was already suggested) after you do proper ivtc (you most likely want to tell your matcher to avoid postprocessing the frames and perhaps you might have to manually make sure the matches are correct).
Hell, I'd say ivtc_txt60mc isn't really required to get back to linear. Ideally you could do this by doing a high quality bob, then just doing an overlay at 0.5 with the fields that need to be overlayed to get a linear fade.
mirkosp is offline   Reply With Quote
Old 31st July 2012, 13:03   #29  |  Link
cretindesalpes
cretindesalpes's Avatar
On a 3:2 telecine pattern, vinverse() the 2-field image, and for the 3-field image, average the 1st and 3rd fields, match with the 2nd field and vinverse() the result to smooth the remaining combing. But sometimes vinverse() cannot cancel the combing, especially on oblique, thin and and highly contrasted lines (mostly with anime/cartoon sources). In this case you could replace vinverse() with daa(). You could also limit the changes by the difference between the average lumas of the two fields.
dither 1.28.1 for AviSynth | avstp 1.0.4 for AviSynth development | fmtconv r30 for Vapoursynth & Avs+ | trimx264opt segmented encoding
cretindesalpes is offline   Reply With Quote
Old 31st July 2012, 13:33   #30  |  Link
sirt
x264 fan
sirt's Avatar
Thanks for your help, I saved the filter as an AVS file but I don't know how to make it work. I've tested ivtc_txt60mc(23.976) on the iVTCed video but it doesn't work (invalid parameters) and with ivtc_txt60mc(24) it doesn't work as well because it doesn't appl on the frame I need.
Thanks, this is a comparison with daa() :
As you see the lines are solved but it looks like the video is also filtered, probably because it is an aliasing filter. But, at least, it seems to always work without needing to be adjusted (like vinverse). Do you maybe know something similar like this ? I think we are on the way !
Old 2nd August 2012, 11:25   #31  |  Link
sirt
x264 fan
sirt's Avatar
Any idea ?
Old 18th June 2013, 13:49   #32  |  Link
GMJCZP
GMJCZP's Avatar
sirt, try this version of daa() that I modified to make it more smooth.
# Anti-aliasing with contra-sharpening by Didée (thanks to Didée, modded for this case with nnedi3)
# Is required VerticalCleaner
function DAAMod(clip c)
nn = c.nnedi3(field=-2) #or use nnedi2
dbl = mt_average(selecteven(nn),selectodd(nn),U=3,V=3)
dblD = mt_makediff(c,dbl,U=3,V=3)
shrpD = mt_makediff(dbl,dbl.removegrain((width(c)>1100) ? 20 : 14),U=3,V=3).verticalcleaner(mode=2)
DD = shrpD.repair(dblD,9)
return dbl.mt_adddiff(DD,U=3,V=3)
GMJCZP is offline   Reply With Quote
Old 30th December 2016, 11:15   #33  |  Link
feisty2
I'm Siri
feisty2's Avatar
@sirt
got an accurate solution for this issue.
but you'll have to switch to vaporsynth to test it cuz I don't do avisynth plugins
feisty2 is offline   Reply With Quote
