Old 26th July 2006, 19:49   #401  |  Link
Doom9
clueless n00b
And are you 200% sure that once you press the autoencode button, you set the radio button to No Target Size (use profile settings) and that in the profile, the mode is set to ABR, Const. Quality or Const. Quantizer?
Especially the former is important.. you never confirmed that you're doing this. My 1P-Intermediate is set to ABR (so downloaded by the autoupdater).. but you MUST change that radio button or all will be for nothing. Unless you set the radio button to that particular setting, the number of passes configured in the settings will be taken.. and since the minimum there is 2 passes, you'll get two passes irrespective of the profile. I've tried this about 10 times now and the result is always the same..
Doom9 is offline   Reply With Quote
Old 30th July 2006, 09:38   #402  |  Link
thuongshoo
I try to encode with Xvid but isnot success . I copy these command and run them in cmd but the message is the same
Starting job job55 at 4:43:30 AM
 encoder commandline:
-i "C:\Documents and Settings\shooshoo\My Documents\mnet.avs" -single -cq 8 -smoother 0 -vhqmode 4 -qpel -gmc -closed_gop -lumimasking -bvhq -threads 1  -mkv "C:\Documents and Settings\shooshoo\My Documents\mnet.mkv"
successfully started encoding
Processing ended at 4:43:32 AM
Log for job job55
Usage : xvid_encraw [OPTIONS]
Input options:
 -i      string : input filename (default=stdin)
 -type   integer: input data type (yuv=0, pgm=1, avisynth=2)
 -w      integer: frame width ([1.2048])
 -h      integer: frame height ([1.2048])
 -frames integer: number of frames to encode
Output options:
 -dump    : save decoder output
 -save    : save an Elementary Stream file per frame
 -o string: save an Elementary Stream for the complete sequence
Bitstream options:
 -par  aspect_ratio : pixel aspect ratio ([VGA11; PAL43; NTSC43; PAL169;
                                           NTSC169]) (default=VGA11)
 -custom_par  X Y   : custom pixel aspect ratio
 -divx_ud           : write DivX-userdata
General encoding options:
 -quality    integer: quality ([0..6]) presets
 +hqacp             : high quality ac prediction
 +inter4v           : use 4 motion vectors per MB
 -gmc               : use global motion compensation
 -interlaced        : use interlaced encoding (this is NOT a deinterlacer!)
xvid_encraw - raw mpeg4 bitstream encoder written by Christoph Lampert 2002-2003Avisynth input is based on Avs2YUV by Loren Merritt
 -i_tff             : top field first (interlaced encoding)
 -i_alt             : alternate scan (interlaced encoding)
 +greyscale         : greyscale mode, all chroma is ignored
 +cartoon           : use 'cartoon' mode
 +chroma_opt        : enable chroma-optimizer pre-filter
 -frame_drop integer: frame drop ratio (in percent)
BFrames options:
 -max_bframes   integer : max bframes (default=0)
 -bquant_ratio  integer : bframe quantizer ratio (default=150)
 -bquant_offset integer : bframe quantizer offset (default=100)
 -bf_thres      integer : bframe threshold modifier (default=0)
 -closed_gop            : closed GOP mode
Rate control options:
 -framerate         float    : target framerate (>0 | default=25.0)
 -bitrate           integer  : target bitrate
 -single                     : single pass mode
 -pass1             filename : twopass mode (first pass)
 -pass2             filename : twopass mode (2nd pass)
 -zq starting_frame float    : bitrate zone; quant
 -zw starting_frame float    : bitrate zone; weight
 -max_key_interval  integer  : maximum keyframe interval
Single Pass options:
 -reac_delay     integer    : reaction delay factor
 -avg_period     integer    : averaging period
 -smoother       integer    : smoother
Pass 1 of 2 options:
Pass 2 of 2 options:
 -size           integer    : target size of video (use instead of bitrate)
 -close_i_red    intA intB  : I frames closer than A frames are reduced by B %
 -ccp_high       integer    : high bitrate degradation (in percent)
 -ccp_low        integer    : low bitrate improvement (in percent)
 -max_oi         integer    : max overflow improvement (in percent)
 -max_od         integer    : max overflow degradation (in percent)
 -overf_cs       integer    : overflow control strength (in percent)
 -vbv_size       integer    : buffer size (bits)
 -vbv_initial    integer    : initial buffer occupancy (bits)
 -vbv_maxrate    integer    : max processing bitrate (bps)
 -vbv_peakrate   integer    : max average bitrate over 3 seconds (bps)
Zone options:
 -z "zone_type starting_frame quant/weight [extended options]"
             zone_type : q (quant zone) or w (weight zone)
        starting_frame : frame number of zone begin
          quant/weight : average quantizer or weight (float)
      extended options : all options that are listed as "+"-options
                         in this display may be used to enable/disable
                         certain features. Additionally the -bf_thres option
                         can be used. An option only available in zones is:
                   -if : force I-frame at the beginning of the zone
Quantization options:
 -iquants        min max  : I-frame quantizer restriction ([1.31])
 -pquants        min max  : P-frame quantizer restriction ([1.31])
 -bquants        min max  : B-frame quantizer restriction ([1.31])
 +trellis                 : use trellis based R-D "optimal" quantization
 -mpeg_quant              : use MPEG quantization instead of H.263
 -mpeg_cqm       filename : use custom MPEG quantization matrix (intra & inter)
 -mpeg_intra_cqm filename : use custom MPEG quantization matrix (intra only)
 -mpeg_inter_cqm filename : use custom MPEG quantization matrix (inter only)
 -lumimasking             : use lumimasking/adaptive quantization algorithm
Motion estimation options:
 +hpel       : use half pixel ME
 -qpel       : use quarter pixel ME
 +chromap    : use P-Frame chroma for ME
 +chromab    : use B-Frame chroma for ME
 +me_advd16  : use advanced diamonds as search pattern
 +me_advd8   : use advanced diamonds for extended 8x8 search
 +me_sqr16   : use squares as search pattern
 +me_sqr8    : use squares for extended 8x8 search
 +me_hpelr16 : enable halfpel refine 16
 +me_hpelr8  : enable halfpel refine 8
 +me_qpelr16 : enable quarterpel refine 16
 +me_qpelr8  : enable quarterpel refine 8
 +me_gmer    : enable GME refine
 +me_exts16  : extend PMV by more searches
 +me_exts8   : extended 8x8 search
Rate disortion options:
 -vhq         integer  : R-D presets ([1.4])
 +rated                : enable R-D
 +rd_simple            : use simplified R-D mode decision
 +rd_bf                : enable R-D for B-frames
 +rd_hpelr16           : use R-D halfpel refine 16
 +rd_hpelr8            : use R-D halfpel refine 8
 +rd_qpelr16           : use R-D quarterpel refine 16
 +rd_qpelr8            : use R-D quarterpel refine 8
 +rd_chk_pred          : check vector equal to prediction
 +rd_exts              : perform R-D-based search using square patterns
Turbo options:
 -turbo     : turbo preset
 +t_fr16    : low-complexity 16 refinement
 +t_fr8     : low-complexity 8x8 sub-block refinement
 +t_skipds  : skip b-frame delta search
 +t_fmi     : partly skip interpolate mode
 +t_bfes    : stop b-frame search early
 +t_dsm     : detect stationary scenes
Other options
 -asm            : use assembly optmized code
 -stats          : print stats about encoded frames
 -debug          : activates xvidcore internal debugging output
 -vop_debug      : print some info directly into encoded frames
 -help           : prints this help message
NB: You can define 64 zones repeating the -z[qw] option as many times as needed.
The current job contains errors. Skipping chained jobs
Starting job job56 at 4:43:45 AM
-i "C:\Documents and Settings\shooshoo\My Documents\mnet.avs" -single -cq 8 -smoother 0 -vhqmode 4 -qpel -gmc -closed_gop -lumimasking -bvhq -threads 1  -o "C:\Documents and Settings\shooshoo\My Documents\mnet.m4v"
Processing ended at 4:43:45 AM
Log for job job56
Input options:
Output options:
Bitstream options:
BFrames options:
Zone options:
 +rated                : enable R-D
Turbo options:
Other options
thuongshoo is offline   Reply With Quote
Old 30th July 2006, 10:37   #403  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
I could not reproduce the error with the same command line. Run update and make sure all components are current.
Old 30th July 2006, 11:46   #404  |  Link
Doom9
clueless n00b
You're using an encraw release by S_0. You need to use the latest one by squid80 which you can download via autoupdate in megui.
Old 30th July 2006, 23:28   #405  |  Link
SCIF
AMD fan
Originally Posted by SCIF
Hi everybody!
I am translating contexthelp.xml to Russian now.....
...How you think about possibility change or select contexthelp language, while installing megui?
Does nobody want to help translate MeGUI?
Russian GK manual for newbie.
SCIF is offline   Reply With Quote
Old 31st July 2006, 02:39   #406  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
I uploaded some updates in the autoupdate server (x264, profiles, dgdecode and dgmpgdec).
If you encounter some bugs (expecially with dgindex) please report them in the bug report thread.
I can translate it in Italian...
Old 31st July 2006, 08:24   #407  |  Link
SCIF
AMD fan
Sharktooth, see this post, please.
I finished Russian translate. With Sharktooth's translate MeGUI will have 3 variants of ContextHelp
Old 31st July 2006, 08:47   #408  |  Link
Henrikx
Henrikx's Avatar
Does someone translate into German ?
Am I to ask in the german doom9 forum?
Henrikx
Henrikx is offline   Reply With Quote
Old 31st July 2006, 12:46   #409  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
the description is right. the lower the quantizer the lower the compression.
Old 31st July 2006, 23:26   #410  |  Link
SCIF
AMD fan
Yes, i think so too. But for what you set minimum quantizer?? I think nobody set min q to get a frames with good quality, but it set's for "wasting bits". I am right, isn't it?
Old 7th August 2006, 00:36   #411  |  Link
SCIF
AMD fan
Is thread dead, again?
Old 7th August 2006, 01:18   #412  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
Actually I already included the swapped descriptions in my local, whenever my next patch shows up and gets included it should be available.
Old 7th August 2006, 02:47   #413  |  Link
SCIF
AMD fan
And how about translate's?
Old 8th August 2006, 00:27   #414  |  Link
Limobar
aka Rabomil
Hi!
I was doing a 2-pass encode (x264) and during the second pass I found out that I was using an average bitrate (1934 kbit) that was too high. My question is: Can I use the first pass stats again, but then with a lower bitrate (1659 kbit)?
Limobar is offline   Reply With Quote
Old 8th August 2006, 10:36   #415  |  Link
berrinam
berrinam's Avatar
Yes, it should be fine.
However, the larger the difference, the worse the quality.
berrinam is offline   Reply With Quote
Old 9th August 2006, 14:01   #416  |  Link
spunch
berrinam, could you check your PM?
spunch is offline   Reply With Quote
Old 9th August 2006, 19:34   #417  |  Link
Carpo
Carpo's Avatar
i have ripped a file dvds to my hdd use dvd decryptrt 3.5.4.0 in file mode and when i tell megui to make a d2v from the vobs it stick up a box saying
could not find dvd decrypter generated info file
is this save to ignore or does it require that i rip the dvd in ifo mode ?
The Internet: where men are men, women are men, and children are FBI Agents
Carpo is offline   Reply With Quote
Old 10th August 2006, 10:21   #418  |  Link
Doom9
clueless n00b
If you have the info file it'll show you the proper audio tracks and languages.. if not, you just have to figure out that info on your own and if you e.g. select track 8 and there's no track 8.. you just won't get any audio.
but it runs without that file, it's just always good to have it. And file mode... if your titleset contains additional content, you realize that file mode is going to get you that additional content (e.g. fbi warning, mpaa ratings and other annoying stuff) as well.. and it has nothing to do with file versus ifo mode.. it's about activating the info file option in dvddec.
Old 10th August 2006, 11:47   #419  |  Link
Morte66
Flying Skull
Morte66's Avatar
I'd appreciate a quick reality check on something... I've been away for a bit, last time I dropped by I saw the beginnings of development on interlaced encoding in x264. AFAICT, this hasn't got far enough to be integrated into MeGUI yet. Am I right, or is it sitting there in some menu that I'm ignoring?
Morte66 is offline   Reply With Quote
Old 10th August 2006, 12:15   #420  |  Link
nurbs
Interlaced has not been added to x264 yet because it slows down progressive encoding.
See here.
megui
