19th August 2008, 04:11 | #3922 | Link |
Mr. Sandman
say thanks to kurtnoise. he did it and it's even not yet finished.
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 19th August 2008 at 13:43. |
19th August 2008, 12:22 | #3923 | Link |
Mr. Sandman
0.3.0.2002 - (kurtnoise) [JobWorkerWindow] revert to previous state...
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 19th August 2008 at 13:42. |
27th August 2008, 17:21 | #3924 | Link |
Swallowed in the Sea
@Sharktooth: you've made a small typo in the x264-950 package at http://megui.org/auto/stable/...(zip extension twice).
Updater fails. |
27th August 2008, 17:25 | #3925 | Link |
Mr. Sandman
fixing...
edit: done.
28th August 2008, 13:56 | #3926 | Link |
Mr. Sandman
0.3.0.2003 - (kurtnoise) [CodecManager] vertical alignment. - (kurtnoise) Now use DriveInfo class to retrieve free space from hard drives. - (kurtnoise) updated MediaInfo library and its wrapper to the latest release (0.7.7.5) - (kurtnoise) [MKVMuxer] some cleanup in the code. - (sharktooth) [FilmCutter.cs] Fixed the fades syntax.
29th August 2008, 14:31 | #3927 | Link |
Mr. Sandman
0.3.0.2004 - (kurtnoise) [VideoPlayer] allow control via the Left and Right arrows keys (Feature Request #2064673) for the prev/next frame buttons. - (kurtnoise) [x264] Anchor = Top & Left only. - (kurtnoise) [xvid] misc. - (kurtnoise) [xvid] added custom command line & several other tunings. - (kurtnoise) [Form1] better errors catching for retrieving free disk spaces. - (kurtnoise) [VistaStuff] added GPL header. - (kurtnoise) Now, ListViews & Treeviews components use the neat and clean Vista theme. :p - (kurtnoise) added VistaStuff class.
29th August 2008, 15:28 | #3928 | Link |
core_0_3_0_2004.zip is corrupted via updater
and from http://megui.org/auto/stable/ |
29th August 2008, 15:32 | #3929 | Link |
Mr. Sandman
yup.. it's a 7z archive renamed as zip... my mistake.
edit: should be fixed now. ensure to clear the update_cache dir before re-updating.
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 29th August 2008 at 15:37. |
29th August 2008, 19:30 | #3930 | Link |
@Sharktooth: Just wondering, if upgrading to a new Core Version, is it best to clear/delete everything in the 'update_cache' folder and then 'force-reinstall' everything? (Or i guess what i mean is.. would it be wise to just 'delete' older versions of things in the Update Cache?
{Sorry if this doesn't belong here} |
1st September 2008, 15:11 | #3932 | Link |
Heya,
1/ I'm able now to find the correct values for channels. 2/ Patch to use this for the d2v creator is coming. 3/ The OneClickEncoder doesn't support it yet. /me haPpY... Last edited by Kurtnoise; 1st September 2008 at 16:42. |
1st September 2008, 15:27 | #3933 | Link |
phjbdpcrjlj2sb3h
Are you still interested in migrating to Trac? If you would like me to continue running Trac as is I am happy to, but an indication of when a final decision will be made would be appreciated :-)
2nd September 2008, 02:15 | #3935 | Link |
Mr. Sandman
i found i have a problem in my "patch" bin... so i have to check a $#!7load of code i commited in the past. im sorry if that caused bugs or any other bad behaviours...
3rd September 2008, 14:01 | #3936 | Link |
Mr. Sandman
0.3.0.2006 - (kurtnoise) [VobinputWindow] demuxTracks disabled by default. - (kurtnoise) [VobinputWindow] added "Demux All Tracks". - (kurtnoise) [VobinputWindow] updated GetAudioInfos(). - (kurtnoise) [IFOparser] added a verbose param for GetAudioInfos() to retrieve complete informations from the file. - (kurtnoise) [IFOparser] added GetAudioLanguageCodeExt() to the parser. - (kurtnoise) [IFOparser] GetVideoInfos() : use a StringBuilder for verbose mode. - (kurtnoise) remove trailing white space from ChangeLog.txt - (kurtnoise) [IFOparser] added a verbose param for GetVideoInfos() to retrieve complete informations from the file. - (kurtnoise) [IFOparser] vertical alignment & better string format for videodesc.
4th September 2008, 18:14 | #3937 | Link |
Mr. Sandman
0.3.0.2007 - (kurtnoise) [FilmCutter] fixed issue #2090575 Code:
0.3.0.2008 - (sharktooth) [AVCLevels.cs] Fixed all level limits, part 2. Differentiation between baseline/main and high profiles CPBs. - (sharktooth) [AVCLevels.cs] Fixed all level limits.
13th September 2008, 14:05 | #3938 | Link | |
Update failes here with following error:
WebClient.Proxy = Nothing I've no clue why all of the sudden this is needed, if nobody else reports it to MeGUI or StaxRip then I guess there is something unusual with my system. Did you fix the last write date for zip extraction btw.?
13th September 2008, 14:16 | #3939 | Link |
Mr. Sandman
auto-update works here. the zip file extraction date is not yet fixed since we're all particularly busy with real life issues.
however here it is the latest update: Code:
0.3.0.2009 - (sharktooth) [MkvMergeMuxer.cs] --delay -> --sync for compatibility with mkvtoolnix 2.3.0 - (kurtnoise) [AVS Creator] added "Apply auto Preview" feature. When it's checked, Crop & Resize modifications will be applied automatically in the video preview. No need to click anymore on "Preview AVS Script" button with this... - (kurtnoise) [AVS Creator] use input filename as default for the save dialog.
13th September 2008, 14:48 | #3940 | Link | ||
File.SetLastWriteTime(pathname, entry.DateTime);
development, megui, not a help thread |
