5th July 2008, 21:41 | #2442 | Link |
New encoding problem with 3.0.0.1014
First off I should say a big thank you for such a beautiful program. It does a lot for me an I appreciate it very much.
But.. I have a script which worked fine, but slow (12 fps), before the recent core update but now when I get to around 14% of a two hour encode now, the encoding fps rate drops to around 3 and then it just stops encoding. There is no error message and Megui hasn't frozen but there is no longer any CPU activity? Would this be a memory issue? I am using the new TempGaussMC_beta in an otherwise simple script so apologies if I'm out of line for posting this here but I had no problems previously in Megui using this. Other scripts (the couple I tried) seem to work as they did previously. Thanks in advance. Last edited by murrsturr; 5th July 2008 at 21:45. |
6th July 2008, 01:41 | #2443 | Link |
phjbdpcrjlj2sb3h
@73Char: Read the dgdecode manual (part of dgindex)
@murrsturr: doesn't sound like a MeGUI issue, sounds like an input issue. if you can encode the file correctly without megui (read: you use an identical commandline in cmd.exe and it works), report it as a bug |
6th July 2008, 03:40 | #2444 | Link |
Mr. Sandman
@murrsturr: MeGUI just feeds the .avs to x264.exe and reads the encoder stderr/stdout. the .avs doesnt influence the "reading" so i highly doubt it's a MeGUI problem. If the avs is complex or it includes particularly memory hungry filters, ensure you set enough memory in the script (SetMemoryMax() function).
6th July 2008, 08:42 | #2445 | Link | |
Doom9 Lover
Creativity is the birth of a new era, will you be creative also? |
6th July 2008, 15:30 | #2446 | Link |
Mr. Sandman
it will always recompress so you will loose quality. if the bitrate is not too different or equal to the original you wont loose too much though.
FYI "downsampling" means another thing... it's about the sampling rate...
7th July 2008, 04:28 | #2447 | Link | |
Aminei
Hello Sharktooth
I reformatted my machine and reinstalled .NET, so MeGUI is running. But there is a new problem now. In AviSynth Script creator if I choose not to "resize", (but choosing the "auto crop" function to remove the black bars) then the AutoEncode> Queue is giving me an error related to AviSynth script resolution. Then I am getting a Fatal Error, but Megui keeps running. The script is as follows: Quote:
Lastly, what exactly is this "*Scratchpad*" avisynth profile? In the guide I founf the profile to beset as "default" in AviSynth Script Creator tool. Please help me out Thank you... Last edited by arrirc; 7th July 2008 at 04:30. |
7th July 2008, 04:38 | #2448 | Link |
Thanks, I found it, but the manual didn't answer my question.
AVS Script creator analyzes a certain mpeg2 video source(m2v or ts) and sometimes adds "info=3", sometimes not, and I don't know why. BTW, the colors in the preview window still don't match those displayed by mpc-hc. (latest stable 3 version). |
7th July 2008, 09:21 | #2450 | Link |
phjbdpcrjlj2sb3h
73char: I'm not sure about that either sorry. Regarding MPC-HC: which renderer are you using? Different renderers have different levels of sanity, in particular avoid VMR*. Haali's is generally the best choice, you can also choose between the 609 and 710 matrix if that sort of colour correction is a big deal for you.
7th July 2008, 12:05 | #2451 | Link |
info=3 forces DGDecode to output "hints" via avisynth. This hints are used by colormatrix to determine the source color space. Unfortunately, this information was wrong in some recent versions of DGDecode, but the problem should be fixed in the latest one provided in megui's autoupdate.
7th July 2008, 13:13 | #2452 | Link |
Mr. Sandman
@arrirc: what's not clear in what megui told you?
"This could cause problems"... Use a mod 16 res (overcrop to mod 16 or resize to mod 16).
7th July 2008, 15:19 | #2453 | Link |
If the Auto Crop option is using the autocrop avisynth plugin, there are two parameters: wMultOf(default 4) and hMultOf(default 2) that can be used to ensure the final width/height is a multiple of x. Since autocrop seems to be an "I'm lazy, do everything for me" option I think it would make sense to use them.
7th July 2008, 15:28 | #2454 | Link |
Mr. Sandman
it's not the avs autocrop function.
7th July 2008, 16:25 | #2455 | Link |
phjbdpcrjlj2sb3h
@squid: Out of interest, does that over or under-crop? Or is that also configurable?
@berrinam: Why would some files have info=3 and some not? Did previous builds of MeGUI remove it while it was borked? |
7th July 2008, 18:39 | #2458 | Link |
Mr. Sandman
however why should we force a mod16 crop when we have a mod16 resize? overcropping is not always good.
7th July 2008, 19:23 | #2459 | Link | |
Aminei
If I resize the final output according to the suggested resolution: 720x364, then anyway it is a resize! So what exactly should I do so that the original wxh is maintained (that is no resizing)? Very sorry Sharktooth, but I have no idea what exactly are you asking me to do. Thank you for relying. |
7th July 2008, 19:41 | #2460 | Link |
Mr. Sandman
OMG...
ok, you dont want to resize? then adjust the CROP so the final width and height can BOTH be divided by 16 (MOD 16!) If you still dont understand... RTFM! http://mewiki.project357.com/wiki/Co...es/Video/Mod16
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 7th July 2008 at 19:46. |
megui |
