Old 10th August 2010, 07:24   #9121  |  Link
KarstenS
Feedback about dreamworks movies with secondary video and playback in TMT3: After doing my workaround to drop the 2nd audio stream, now the result run fine in TMT3 without audio issue.
KarstenS is offline   Reply With Quote
Old 10th August 2010, 08:12   #9122  |  Link
pididdi
pididdi's Avatar
no german ac3 stream
i have problems with a ripped bd. i use bd rebuilder v0.34.06 beta. all audio options are set correctly so that bd rb must demux all audiotracks (at least english dts and german ac3), but it demuxes only the english dts stream and reencodes it. i use the "full backup" methode and the mainmovie-original is splitted in 14 parts!
i hope the next beta will solve the problem!
and by the way, what´s about the ugly pixel effect (pixelfragments) at the beginning or end of the rebuilded m2ts stream and the delay of -250 until -260 ms (i use tsmuxer to correct it)?
pididdi is offline   Reply With Quote
Old 10th August 2010, 12:51   #9123  |  Link
bluestarCVO
What is the movie??? I don't have any problems with "pixel fragments" on any of my 50+ backups. Do you have the correct helper apps installed as per the first post of this thread?
bluestarCVO is offline   Reply With Quote
Old 10th August 2010, 14:00   #9124  |  Link
jdobbs
Your system is very probably misconfigured. Do a complete reinstall per the instructions in the first post of this thread.
Website: www.jdobbs.net
Old 10th August 2010, 20:53   #9125  |  Link
ps3z
ps3z's Avatar
hi,i have one movie around 45gb and main movie files existing from 23 parts like chapters but they made this movie as 23 parts and playlist,also another special features parts are bigger than main movie parts,bd rebuilder's quicker mode encoding the main movie files as low bitrates,how i can change that size of special features videos 1080p to 720p? for get capacity to main file?i want to leave the main movie files as 1080p and reduce the bitrate 23000 to 15000-17000 for fill to bd25
Note:if i leave to bdrebuilder for do automatic encoding in bd25 mode,movie files being around 10000mbps,it seems like unquality,i would to keep high the bitrates for main movie
Thanks in advance
Matt
ps3z is offline   Reply With Quote
Old 10th August 2010, 21:09   #9126  |  Link
jdobbs
BD Rebuilder v0.34.07 (beta)
I've updated the first post of this thread with a link to the latest release (v0.34.07) of BD-RB. Changes for this version:
- Fixed an error in which a secondary audio stream that
  was originally DD+ can be incorrectly flagged as DTS
  Express in the CLPI file output.
- Corrected an error introduced in v0.34.05 that could
  result in "CreateAVS() 00000".
- Corrected an error that could result in a display of
  "Error 2501 SourceCheck() 00009".
- Updated the included version of X264.EXE to the
  latest release (r1688).
- Other minor corrections and cosmetic fixes.
I mainly wanted to get the fixes out for a couple of errors, DTS Express support is still being worked for the next release.
Old 10th August 2010, 22:21   #9127  |  Link
KarstenS
Scanning of "Cars" now without error message. Rebuilding and testing now.
I'll test a pip movie of Dreamworks (Monster vs. Aliens) after I am ready with Cars. I've got a little bit hope, that this will also fix the TMT3 issue.
Old 11th August 2010, 00:24   #9128  |  Link
MilesAhead
MilesAhead's Avatar
I just downloaded the latest. It has the same minor bug as 06. I use one pass abr "good" profile. The last thing I check before hitting the Backup Button is Encoder Settings. It shows Idle priority, Good profile and One Pass Abr checked. I hit Backup, and the log tells me it's using 2 pass abr mode. The fix is to go into Encoder Settings, uncheck One Pass Abr Mode, then check it again, then start the backup. Then it will use One Pass Abr Mode.
A minor thing. Looks like something isn't getting written out unless you kick it.
edit: Don't know if it's a clue but I didn't have this issue in .05 beta. I noticed the log text is different. It used to say either one pass abr or two pass abr. Now it tells you 2 pass on 2 pass abr, but if it's one pass, it just says abr.
I'm doing the first encode and everything is proceeding fine though.
"I don't want to belong to any club that would have me as a member."
- Groucho Marx
MilesAhead is offline   Reply With Quote
Old 11th August 2010, 00:38   #9129  |  Link
AcePuppy
I have noticed that some of my rips freeze at a certain point in the movie and the only way to get past that point is by starting the movie over and fast forwarding past that spot? I'm getting this on both Standalone and PS3. For example this occurred on Valentine's Day but not Kick-Ass. On the PS3 after about a minute it goes to 'The data is corrupted', but what I don't understand is how can it be corrupt if when you fast forward past that one small part it works fine?
BTW, I have never had any errors in BD Rebuilder and use the default settings except for changing 1080p to 720p. Any help would be greatly appreciated!
AcePuppy is offline   Reply With Quote
Old 11th August 2010, 00:55   #9130  |  Link
jdobbs
That sounds like bad media.
Old 11th August 2010, 01:16   #9131  |  Link
AcePuppy
JDobbs: The media can't be bad, after everything is ready to burn before even put on CD, I've tested to see if it locks at the same point as it does on the PS3 and standalone and it does on the computer.
If it helps even more, this is on a fully refresh Windows 7 machine, pretty bare. This occured on Windows XP as well. There is no freeze after a complete rip using AnyDVD only after rebuild is complete.
Old 11th August 2010, 01:59   #9132  |  Link
jdobbs
Thanks for the report. I've fixed it for the next release.
Old 11th August 2010, 02:00   #9133  |  Link
jdobbs
It locks up during playback on the computer? Are you sure you have a good rip? I've done over a thousand discs in testing and have never had a single "lock up".
Old 11th August 2010, 02:05   #9134  |  Link
AcePuppy
The rip is solid, I've played the full file without fast forwarding it with no stutters or freezes. I only get the issue after BD Rebuilder does the backup. Like I said Kick-Ass worked perfectly after a backup, however Valentine's Day had I believe 2 or 3 freezes after backup. This also occurred on She's Out of My League towards the end of the movie once.
Edit: JDobbs, if this is not some issue with the program, do you or anyone else have any idea what hardware issue this could be, as it doesn't really make sense to me as this computer is about a year old and nothing is considered old and I work in the IT industry, so I can tell old from semi-new.
Old 11th August 2010, 03:39   #9135  |  Link
Capsbackup
@AcePuppy:
perhaps a test at full 1080P resolution rather than resize to 720P, just to rule that out as a possibility?
Also, are these full disc backups or movie only?
For standalone testing, what are you using to burn with, IMGBurn? or other software?
Capsbackup is offline   Reply With Quote
Old 11th August 2010, 12:38   #9136  |  Link
datman
I can not encode The last Emperor. I get no audio. I tried 34.05,06 and 07.
datman is offline   Reply With Quote
Old 11th August 2010, 13:00   #9137  |  Link
extravirgin
If this isn't a bug and I'm just being dumb tell me and I'll leave you alone
I've been playing around with BD-Rebuilder for the last couple of days to create a full backup to BD-9. As far as I'm aware I've followed the instructions to the letter and get OK checks for Haali etc. I also allow BD RB to burn using ImgBurn. On completion it appears I've created a BD-9 but every disk I create will only show up as 'Data' on my PS3. I don't seem to get any errors in the log file either. Well, not that I'm aware.
So it's either a bug, the source is at fault or I'm doing something wrong. Any help would be appreciated.
[22:46:38] BD Rebuilder v0.34.06 (beta)
  - Source:  THE_GIRL_WITH_THE_DRAGON_TATTOO
  - Input BD size: 40.11 GB
  - Approximate total content: [03:06:56.473]
  - Target BD size: 7.84 GB
  - Windows Version: 6.1 [7600]
  - Quality: High Quality (Default), Two Pass
  - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640
[22:46:38] PHASE ONE, Encoding
 - [22:46:38] Extracting A/V streams [VID_00000]
 - [22:46:40] Reencoding: VID_00000 (1 of 6)
 - [22:46:40] Collecting video information
   - Rate/Length: 23.976fps, 356 frames
   - Bitrate: 2,295 Kbs
 - [22:46:40] Reencoding: VID_00000, Pass 1 of 2
 - [22:46:47] Reencoding: VID_00000, Pass 2 of 2
 - [22:46:58] Video Encode complete
 - [22:46:58] Reencoding audio tracks (if req'd)
 - [22:46:58] Multiplexing M2TS
 - [22:46:59] Extracting A/V streams [VID_00002]
 - [22:47:05] Reencoding: VID_00002 (2 of 6)
 - [22:47:05] Collecting video information
   - Rate/Length: 24.000fps, 1,385 frames
   - Bitrate: 4,581 Kbs
 - [22:47:05] Reencoding: VID_00002, Pass 1 of 2
 - [22:47:39] Reencoding: VID_00002, Pass 2 of 2
 - [22:48:30] Video Encode complete
 - [22:48:30] Reencoding audio tracks (if req'd)
 - [22:48:30] Multiplexing M2TS
 - [22:48:31] Extracting A/V streams [VID_00004]
 - [23:00:47] Reencoding: VID_00004 (3 of 6)
 - [23:00:47] Collecting video information
   - Rate/Length: 24.000fps, 132,801 frames
   - Bitrate: 4,736 Kbs
 - [23:00:47] Reencoding: VID_00004, Pass 1 of 2
 - [00:09:42] Reencoding: VID_00004, Pass 2 of 2
 - [02:04:12] Video Encode complete
 - [02:04:12] Reencoding audio tracks (if req'd)
 - [02:06:40] Multiplexing M2TS
 - [02:07:38] Extracting A/V streams [VID_00005]
 - [02:19:27] Reencoding: VID_00005 (4 of 6)
 - [02:19:27] Collecting video information
   - Rate/Length: 24.000fps, 134,051 frames
   - Bitrate: 4,766 Kbs
 - [02:19:27] Reencoding: VID_00005, Pass 1 of 2
 - [03:27:54] Reencoding: VID_00005, Pass 2 of 2
 - [05:23:51] Video Encode complete
 - [05:23:51] Reencoding audio tracks (if req'd)
 - [05:26:19] Multiplexing M2TS
 - [05:27:19] Extracting A/V streams [VID_00009]
 - [05:27:20] Reencoding: VID_00009 (5 of 6)
 - [05:27:20] Collecting video information
   - Rate/Length: 24.000fps, 301 frames
   - Bitrate: 1,400 Kbs
 - [05:27:20] Reencoding: VID_00009, Pass 1 of 2
 - [05:27:26] Reencoding: VID_00009, Pass 2 of 2
 - [05:27:33] Video Encode complete
 - [05:27:33] Reencoding audio tracks (if req'd)
 - [05:27:33] Multiplexing M2TS
 - [05:27:33] Extracting A/V streams [VID_00010]
 - [05:27:34] Reencoding: VID_00010 (6 of 6)
 - [05:27:34] Collecting video information
   - Bitrate: 1,289 Kbs
 - [05:27:34] Reencoding: VID_00010, Pass 1 of 2
 - [05:27:40] Reencoding: VID_00010, Pass 2 of 2
 - [05:27:47] Video Encode complete
 - [05:27:47] Reencoding audio tracks (if req'd)
 - [05:27:47] Multiplexing M2TS
[05:27:47]PHASE ONE complete
[05:27:47]PHASE TWO - Rebuild Started
 - [05:27:47] Rebuilding BD file Structure
[05:27:48] - Encode and Rebuild complete
[05:27:48] BURNING BD structure to disc
 - ImgBurn completed successfully
 - WORKFILES folder removed.
[05:56:21]JOB: THE_GIRL_WITH_THE_DRAGON_TATTOO finished.
extravirgin is offline   Reply With Quote
Old 11th August 2010, 13:00   #9138  |  Link
worknstiff
The Last Emperor Audio
I had the same problem, I was doing movie only and BD_RB didn't have any selectable audio even though you know there has to be something there. If I remember correctly, running it thru Clown_BD fails also, but I used tsMuxeR_GUI output to bluray format to finally get a 224K stream that BD_RB recognizes. Then if you set BD_RB to use 224 audio it comes out fine. (THIS IS FOR MOVIE ONLY OF COURSE). This kind of audio has shown up on a couple other foreign disks. Happy Encoding!
worknstiff is offline   Reply With Quote
Old 11th August 2010, 14:03   #9139  |  Link
AcePuppy
Originally Posted by Capsbackup View Post
@AcePuppy:
The test is run at full 1080p when it's run from AnyDVD and shows no problems, I have not done a backup with the resolution to be 1080p only resize to 720p, but I don't think that would be the issue, but I'll try this weekend.
I have tried both full disc backups as well as movie only and get the same result with the movie.
For burning, I use IMGBurn.
This is probably more a hardware or codec issue, then BD Rebuilder it's-self, but what I don't understand is almost all of my hardware is less than a year old and was customized built by myself. I did a clean refresh to Windows 7 with no codecs previously installed and only installed BD Rebuilder and AnyDVD, following the instructions on the first page but still have a random freeze that never unfreezes at the certain point in each movie, but if I go past that point it works fine unless there is another freeze. I also get this same probablem if I DL x264 720p's off other places. So any help fixing this issue would be great.
Old 11th August 2010, 14:41   #9140  |  Link
jdobbs
I noticed you have only "English" selected to keep. Is there and english track on the original?
