11th June 2013, 00:01 | #15161 | Link |
Submit a patch...
MPC-HC 2.2.1 |
13th June 2013, 15:20 | #15162 | Link |
Ass subtitles is garbled when av splitter connected to ffdshow subtitles filter.
http://forum.avmedia.su/viewtopic.php?f=19&t=183 http://forum.avmedia.su/viewtopic.php?f=11&t=194 http://forum.avmedia.su/download/file.php?id=230 Last edited by shunely; 13th June 2013 at 15:39. |
13th June 2013, 16:01 | #15163 | Link |
Should be fixed in r4516.
MPC-HC 2.2.1 |
16th June 2013, 08:24 | #15164 | Link |
SuperVirus
r4516 at xvidvideo.ru
14th July 2013, 17:00 | #15168 | Link |
Then you are looking in the wrong place. It is in the VFW codec, not in the DirectShow filter.
MPC-HC 2.2.1 |
18th July 2013, 09:42 | #15170 | Link |
Why is it if I play a 10bit file with ffdshow raw active (on a default profile with no options ticked) it outputs NV12?
I know I could unticket all output options but P010 which hopefully avoids any conversion (does it?) but I shouldn't have to. I have all output options ticked so shouldn't it default to P010? What's going on? |
18th July 2013, 09:44 | #15171 | Link |
ffdshow raw does not support 10-bit input, so its converted before it reaches ffdshow already, IIRC.
19th July 2013, 07:42 | #15174 | Link |
Several VfW codecs have been removed from the VfW configuration's Encoder tab (e.g. the generic MPEG4-ASP codec with insanely detailed configurability but only experimental, in comparison to Xvid not really practical capabilities). But there are still a few essential codecs left. Namely the unsubstitutable lossless codecs (FFV1 and Huffyuv with YV12 support), as well as the top quality Motion-JPEG and DV implementations.
24th July 2013, 12:42 | #15177 | Link |
Wrong. The video has a too small size. That is fault of encoder.
MPC-HC 2.2.1 |
6th September 2013, 12:33 | #15180 | Link |
I thought I had installed everything correctly ... but then I got the old known error in VirtualDubMod again: "Source format not acceptable (-2)" when loading an AviSynth script which outputs YV12 video. I knew that it can be solved by registering a VfW handler for the "YV12" FourCC in the Registry.
So I called the VFW Configuration of ffdshow and checked the "Codecs" page in the "Decoder" register. Raw formats: "all supported". Set to "none"; [Apply]; Set back to "all supported"; [Apply]; still Error -2 in VDubMod. RegEdit; search for "vidc."; found some in: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Drivers32 HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows NT\CurrentVersion\Drivers32 But neither contains "vidc.yv12". Manually added String value "vidc.yv12=ff_vfw.dll" for both. Works again. — But why disappeared this entry, and why is ffdshow not anymore able to register itself? Last edited by LigH; 6th September 2013 at 12:39. |
