Old 4th January 2014, 14:53   #1041  |  Link
LigH
LigH's Avatar
As far as I can read the sources, not really being a C coder (m2audio_lpcm.cpp / m2audio_rawav.cpp):
"NicLPCMSource" is for headerless integer PCM audio which requires all attributes explicitly; Motorola (Big Endian) order – as usual for DVD and Blu-ray PCM – is supported by negative sample bits, it may also support the (4LSB-interleaved) 20-bit sample format in DVD Video LPCM streams.
"RaWavSource" is for uncompressed intel (Litte Endian) integer and IEEE float PCM content in WAV and W64 container, it contains a RIFF / RF64 chunk parser.
New German Gleitz board
Old 5th January 2014, 13:55   #1042  |  Link
Wilbert
Yes i saw that when reading the sources (that's why i deleted my post, must have crossed your reply). Thanks anyway!
Old 27th January 2014, 22:56   #1043  |  Link
siella
siella's Avatar
All extensions update as last versions of encoders. i added dts encoder and fgh aac encoder estensions. Also I added logo.
All extensions is start with @ now
The files in this folder can be included in BeHappy folder or in a subfolder called 'encoder'.
If the subfolder 'encoder' exists, all the encoders must be inside it.
Some files are interfaces created by BeHappy team and are included here, but the rest must be obtained from the authors.
Some special versions with STDIN input are included also, when the old link don't work.
There are also Bepipe.7z with the command line Bepipe.exe and some sample.
Here are the last know url to download the encoders and the last version tested:
WavSplit.exe (Included. Author Tebasuna, to split in mono/stereo wav's instead multichannel output)
-- lossless encoders
flac.exe (free lossless FLAC encoder http://www.rarewares.org/lossless.php, v1.3)
ttaenc.exe (free lossless TTA True Audio encoder, special v3.4.1 with STDIN input, included)
wavpack.exe (free lossless WV WavPack encoder http://www.rarewares.org/lossless.php, http://www.wavpack.com/ v4.70)
-- lossy multichannel encoders
neroAacEnc.exe (free AAC-MP4 encoder from Nero, http://www.nero.com/eng/technologies-aac-codec.html v1.5.4.0)
aften.exe (free AC3 encoder by Justin Ruggles, in http://code.google.com/p/wavtoac3encoder/downloads/list v)
oggenc2.exe (free OGG encoder, http://www.rarewares.org/ogg-oggenc.php v2.85)
enc_aacPlus.exe (Included. Author Dimzon and BeHappy team, interface for enc_aacplus.dll http://www.un4seen.com/filez/4/enc_aacPlus.zip)
enc_aacplus.dll (free AAC CT encoder , from full Winamp 5.66)
nscrt.dll (needed for enc_aacplus.dll, from full Winamp 5.5)
libmp4v2.dll (needed for enc_aacplus.dll mp4 output, from full Winamp 5.66)
ffmpeg.exe (many options, maybe: http://ffmpeg-builds.sourceforge.net/)
enc_AudX_CLI.exe (Included. Author Dimzon, interface for audxlib.dll)
audxlib.dll (free MP3 encoder with surround features, http://www.aud-x.com/)
mp3sEncoder.exe (free MP3 Fraunhofer encoder, http://www.all4mp3.com/tools/sw_fhg_cl.html)
qtaacenc.exe (Apple quicktime aac encoder, it needs QuickTime 7.6.2 or later and VC2008 runtime http://tmkk.undo.jp/qtaacenc/
fhgaacenc.exe (interface for enc_fhgaac.dll, http://tmkk.undo.jp/tools/fhgaacenc-20120624.zip)
enc_fhgaac.dll (Fraunhofer FHG AAC Encoder, new version of AAC CT encoder, needed for fhgaacenc.exe from winamp 5.66)
nsutil.dll (needed for enc_fhgaac.dll, from full Winamp 5.66)
dcaenc.exe (dcaenc free DTS encoder,http://aepatrakov.narod.ru/index/0-2, v2)
-- lossy only stereo encoders
lame.exe (free MP3 encoder http://www.rarewares.org/mp3-lame-bundle.php, v3.99.5)
twolame.exe (free MP2 encoder, http://www.rarewares.org/mp3-others.php#twolame, included v0.3.13)
mpcenc.exe (free MPC MusePack encoder, http://www.musepack.net, v1.30)
Notes:
The GUI's to capture the encoder parameters are implemented in the main BeHappy.exe or in *.extensions files in the 'extensions' subfolder.
The *.extensions files can be edited with Notepad or similar to change a not supported option.
To change parameters to GUI encoder included in BeHappy.exe you need change the sources *.cs and compile.
The files in 'extensions' subfolder can also be placed at BeHappy folder.
The *.extension files can implement also DSP functions (ConvertSample, DownMix, DuplicateChannels, SSRC and UpMix), and AviSynth decoders (BassAudio.extension).
The mppenc v1.16 (SV7) was deprecated and the new MusePack encoder SV8 is named mpcenc.exe (actually v1.30) if you want use it you need edit MusePack.extension file.
For nero encoder information look at http://wiki.hydrogenaudio.org/index.php?title=NeroAAC
siella is offline   Reply With Quote
Old 28th January 2014, 00:55   #1044  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by siella View Post
... i added dts encoder and fgh aac encoder estensions. Also I added logo.
(I never know how to add a logo)
Old 28th January 2014, 16:32   #1045  |  Link
Tom Keller
Tom Keller's Avatar
I've got some additional Extensions:
  • one for the usage of qaac (if someone prefer it over qtaacenc)
  • and another one for opusenc
The logos are *.png files as Base64 coded text. So you simply have to create your logo with the graphics software of your choice, then use one of the many Base64 online converters to upload and convert the image... and add it to your *.extension file afterwards.
Tom Keller is offline   Reply With Quote
Old 28th January 2014, 17:03   #1046  |  Link
tebasuna51
tebasuna51's Avatar
New options:
Old 30th January 2014, 09:53   #1047  |  Link
LigH
LigH's Avatar
I wonder if extensions are configurable in another way. This huge bunch of radio buttons makes me uncomfortable. Especially for QAAC, where I would prefer more options between quality 73 and 100 (I often prefer 82, but would never consider using the lowest possible). Using radio buttons to choose between CBR, CVBR and (t)VBR, and then having combo boxes to select the bitrate or quality level, may be more convenient, but would have to be supported by the extension designer features.
Old 30th January 2014, 16:25   #1048  |  Link
Tom Keller
Tom Keller's Avatar
Yes... i know - or some kind of slider for choosing the bitrate would be much more comfortable too. But as far as i understand, that's (sadly) not possible with the XML based extension scripts.
Old 2nd February 2014, 17:59   #1049  |  Link
siella
siella's Avatar
That's right. Behappy written C# language also is open source and maybe some person who know C# programmer add radio button.
Old 2nd February 2014, 21:26   #1050  |  Link
Reino
Reino's Avatar
Also I added logo.
How do you translate a picture to characters of code you can use in a text file?
[edit]Strange, I completely overlooked that paragraph. Thanks, LigH[/edit]
My hobby website
Reino is offline   Reply With Quote
Old 2nd February 2014, 21:37   #1051  |  Link
LigH
LigH's Avatar
@ CoRoNe:
Old 5th February 2014, 14:43   #1052  |  Link
Tom Keller
Tom Keller's Avatar
I think that's highly unlikely, since no programmer was interested in the further development of BeHappy for quite a while.
Old 9th February 2014, 18:45   #1053  |  Link
tebasuna51
tebasuna51's Avatar
Warning!
Bug detected in FraunhoferMp3.extension in the package of previous post.
Use this one instead:
Edit: file updated.
Sorry, I don't see the Siella edition of next post until now
Old 10th February 2014, 10:06   #1054  |  Link
siella
siella's Avatar
Warning!
Thanks tebasuna51
-if - -of "{0}" -q 1 -eof -res {2} -br 0 -m 1 -sr {1} -res {2} -c {3} -vbri
but why did you write -res {2} command double?
Old 7th May 2014, 17:10   #1055  |  Link
siella
siella's Avatar
FFmpegSource2 extantion
I made ffaudio extension to use geting and decoding directly audio files from avi,mkv,mp4,flv,m2ts and ts container.
You need to download ffms2.dll and put in to avisynth plugin folder
https://ffmpegsource.googlecode.com/svn/trunk/doc/ffms2-avisynth.html
Also it request installed hali media splitter on your pc.
FFAudio create index file in path of your video.
FFAudioNoindex doesnt creat file. It writes on ram. But If you dont have enough ram I dont recommend. it use ram above 200 mb for hd video.
Old 7th May 2014, 17:18   #1056  |  Link
LigH
LigH's Avatar
Certainly a useful extension.
Slightly more useful may be an L-SMASH Works extension, though; the splitters of LAVFilters are more reliable, LwLibavAudioSource() doesn't need the help of Haali to read MPEG containers.
Old 8th May 2014, 11:10   #1057  |  Link
siella
siella's Avatar
LSMASHSource Extension
Well I made extension for l-smash as a alternative. Diffirent is if you use LWAudioNoindex spend ram more less than FFAudioNoindex. But if use LWAudio index file size more than FFaudio
Download here https://drive.google.com/folderview?id=0BwV03nn6LPd9OXJUWVVMMXZmNUU&usp=sharing
Copy LSMASHSource.dll to avsynth plugin folder. Also you need msvcr120.dll (not 64bit) put in to system32 folder. (if your system 64bit put in to SysWOW64)
LWAudio create index file in path of your video.
LWAudioNoindex doesnt create index file.
Old 8th May 2014, 11:47   #1058  |  Link
LigH
LigH's Avatar
Or much more reliable: Install Microsoft's Visual C++ Redistributable Packages für Visual Studio 2013 32-bit (vcredist_x86.exe).
P.S.:
Old 8th May 2014, 11:51   #1059  |  Link
siella
siella's Avatar
Thanks LigH
Behappy
BePack.v3.3BeHappy,BeSweet,BeLight,BeSplit,BeSliced,BdAC) with last plugin, encoder and extensions.
Avisynth Movie Screenshot, thumbnails creator
Old 9th May 2014, 17:06   #1060  |  Link
siella
siella's Avatar
I change dts extension. Dcaenc doesnt support 24 bit or 32 bit float. Now it will be auto convert 32bit int.
Behappy
behappy
