9th April 2006, 11:06 | #141 | Link |
Video Engineer
Fast subpixel motion estimation
Ever thought of implementing fast subpixel ME by fitting the subpixel resolution vector to the SAD-curvature samples calculated at integer vector positions ?
Instead of interpolating an intermediate 2x resoution "blow-up" image to perform the search at half-pixel positions, you have to search only in the original size image to find the SAD minimum integer position, then approximate the subpixel position from the values of SAD-minimum and its 4 (or 8) neighbours. Searching blocks in lower resolution saves a lot SAD-calculations, making ME much faster. Curve-fit approximation of the block vectors (yielding resolution of 1/2-pixel or beyond) can be implemented fast and easy. (If you doubt, ask me to go into detail.) |
5th June 2006, 19:34 | #142 | Link |
AviSynth plugger
I released new MVTools version 1.3.0 (beta?)
Implemented overlapped block motion compensation to MVCompensation(mode=1). Changed default to mode=1 in MVCompensation as the most universal. Added sharp subpixel interpolation method for pel=2. Fixed bug for blksize=16 with YUY2. (To-do list: assembler SSE speed optimization for new compensation and interpolation methods.)
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. |
5th June 2006, 20:32 | #143 | Link |
brainless
would it be possible to implement edge directed internal sampling to increase subpixel accuracy over the linear subpixel accuracy?
Don't forget the 'c'! Don't PM me for technical support, please. |
5th June 2006, 21:42 | #146 | Link |
AviSynth plugger
Answer: Yes, it is possible to imlement any pixel interpolation.
Really I firstly want to add Wiener interpolation. But "true" Wiener (local adaptive) is complex. So, I implement sort of invariant Wiener 6 taps interpolation (do not know why ). Coeffs= (1; -5; 20 ; 20; -5; 1)/32 About edge-directed. Really Manao used horizontal, vertical and diagonal bilinear interpolation.
7th June 2006, 12:04 | #147 | Link |
Hey, a big Thank-You, Fizick. Block overlapped compensation is doing a very good job, and the sharp interpolation comes nice, too.
- One bug discovered: An error is thrown when compensating after "padding(x,y)": Code:
vectors = source .padding(4,4) .mvanalyse( [parameters] ) comp = source .padding(4,4) .mvcompensate(vectors, [parameters]) .crop(4,4,-4,-4) I noticed this when just plugging MVT 1.3.0 into a script where a manual block overlapped ME+MC is done. Probably no big deal, since padding() isn't documented, hence not used very much. Still, it's not exactly the expected behaviour ... - A question: "sharp" interpolation can only be specified in MVAnalyse(). Now, in case if compensation is done with new interpolation: Code:
vectors = source_1 .mvanalyse( sharp=1, idx=a ) comp = source_2 .mvcompensate( vectors, idx=b, mode=1 ) - Question / Suggestion: Compairing the block overlapped estimation + compensation with the scripted approach I tried, your method seems clearly superior in, say, 80% to 90% of the problematic areas. (Darn you! ) However, there are some percent left. What I tried was a different method, more kind of a "best match": - create vectors on orignal, and on padded original - create compensations with both vectors - weight both compensations acc. to their amount of difference to the original (including some 8x8-block-restricted spatial blurring of all three clips) It seems feasable that in areas where compensation #1 shows an obvious bigger difference to the original than compensation #2, the weighting of compensation #1 should be reduced (and vice versa). Does your block summation method already include something like this? If not, it could be worth a try.
9th June 2006, 02:58 | #150 | Link |
JuSt a PoWer uSEr
I went to the site and don't really understand what to do?
i just want to try it out in some low bitrate encode 1500 avg bitrate.. I want to try motion blur. thanks EDIT: @Fizick sorry thanks for pointing it out
Birthdays are good. Statistics show that the people who have the most live the longest. Last edited by dirio49; 9th June 2006 at 13:51. |
9th June 2006, 04:45 | #151 | Link |
AviSynth plugger
Didйe,
1. edges processing is not implemented. I never used "padding" command. Will look later. 2. MVCompensate use same (sharp) interpolation (reckognizing some flag in the vector clip) in mode=1 and mode=0. 3. your suggestion is interesting, but it may produce some blocking. One of aims of my current overlapped procesing is deblocking. Will try strives for perfection later. drio49, MFlowblur? But please post your "usage" questions to "usage" forum: http://forum.doom9.org/showthread.php?t=84770
10th June 2006, 05:23 | #152 | Link |
AviSynth plugger
Didйe,
I disabled external "Padding" function since MVTools v.1.1.1. We do not need in external double-sided padding (but only bottom and right). Now I simply fill it by source pixels. Try use addborders or mirrorborders as a workaround now. May be I will implement better padding internally some time.
22nd November 2006, 21:00 | #153 | Link |
Huh?
Would there be any way to make MVTools work with tsp's multithreaded version of Avisynth?
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it. |
23rd November 2006, 03:27 | #154 | Link |
Only if you buy Fizick a dual core system to debug the new code with....
Have you looked at Motion by mg262/clouded? It isn't as sophisticated, but it might work with MT Avisynth. Last edited by Pookie; 23rd November 2006 at 03:39. |
23rd November 2006, 03:42 | #155 | Link |
Use 2 PCs to process 1st/2nd half of the source. Very stable solution, and available right now.
If short of a 2nd PC, you can simulate it like this: first do the 1st-PC's part, then do the 2nd-PC's part, and join both parts afterwards. [*running man*]
23rd November 2006, 06:25 | #156 | Link |
AviSynth plugger
You also may try run two AVS (two part of file) in separate threads
Seriously, some time I will look to it. I am afraid I firstly must remove all IDX, but it will run slower.
23rd November 2006, 11:52 | #157 | Link |
Huh?
That's good to hear, and your suggestion is actually a pretty good idea. Take your time, good things do tend to take lots of time .
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it. Last edited by Chainmax; 17th December 2006 at 05:19. |
24th November 2006, 18:36 | #158 | Link |
@Chainmax,
If you really want to run MVtools in Dual-CPU, make sure to get a big HDD and encode 2 avs files to lossless. I always do this with MVBOB. I then encode after I'm done. The process is alot faster. The speed increase for me is about 70%.
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake? Curly: Burned at the stake! Moe: Why? Curly: A hot steak is always better than a cold chop. Last edited by Revgen; 24th November 2006 at 18:39. |
18th December 2006, 22:32 | #159 | Link |
But it is not that straight-forward, mvbob for example can only be used in one encoding at a time unless you specify different idx values for every thread. With the new 1.5 mvtools and the 2x-clip it's probably easier.
Most of the time it works using different idx-values for each thread, but avisynth tends to mix different values of the same variable name, so better no reuses of the same name. Tracking these bugs is very difficult (only sporadically visible). |
