28th January 2009, 04:50 | #921 | Link | |
Thanks.. |
28th January 2009, 05:35 | #922 | Link |
AVISYNTH should be enabled by default when you install ffdshow..... you just gotta have AVISYNTH installed on your PC that's all.
Only things I had to manually enable in ffdshow was mpeg2 and VC-1. Not sure if JD wants to add more info to that.... but that's how I have it set and it's been pretty much all successful since, especially now that 0.18.07 addresses the slight audio out of sync issue on seamless branching Blurays.
MBK |
28th January 2009, 22:25 | #925 | Link |
Same issue new encode
BD-9 movie only....Play back on PS3 movie skips.
Config MODE=1 QUICK_EXTRAS=0 PRIORITY_CLASS=1 RESIZE=0 ENCODE_QUALITY=2 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all TRELLIS=1 COLOR_BOOST=1 DTS_REENCODE=1 AC3_REENCODE=1 AC3_640=0 AVCHD=- AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=0 TARGET_SIZE=7910 AUTO_BURN=0 VERBOSE_STATUS=0 [Paths] SOURCE_PATH=C:\LAKEVIEW\VOLUME_ID\ WORKING_PATH=C:\BD_RB WORK\ Log Can't find my log. I'm going back to version 0.17.13 tonight using the same movie & setup to see if there are any issues. |
29th January 2009, 03:33 | #927 | Link |
I can also now confirm that the two BDs I did with 0.18.07 (X-Files & Mummy 3) skips every couple seconds on my daughters' PS3 as well.... not sure what was changed in version 0.18.07 that is causing this, but did not have the Strict AVCHD checked, and never had any problems for movie only BD-9s prior to this???
I don't remember if I tested any BD-9s that I did with 0.18.04.... but 0.17.13 was definitely not a problem for the PS3.
MBK |
29th January 2009, 03:41 | #928 | Link |
Max Payne, which I did with 0.18.04 is also skipping every couple seconds on her PS3....
All BD-9s play perfectly on my Sony BDP-BX1 player...... hmmmm, wonder what may have caused it JD?? Wonder if this is related to the AUXDATA folder issue?? It isn't on any other BD-9s prior to 0.18??
MBK |
29th January 2009, 08:53 | #929 | Link |
Im getting no audio on my conversions, brilliant video though, tried 4 different movies all versions of BD RB only success ive had was with the 1st version and Kill Bill Volume 1 when it was released. Thought it might have been media tried 3 different dvd9 discs and 2 dvd5. All movies ripped with ANYDVD-HD , the iso plays in PowerDVD when mounted ... any ideas thanks.
[08:04:10] BD Rebuilder v0.18.7 (beta) - Source: LOGICAL_VOLUME_ID - Input BD size: 29.51 GB - Approximate total content: [01:57:57.069] - Target BD size: 4.27 GB - MOVIE-ONLY mode enabled [08:04:13] PHASE ONE, Encoding - [08:26:03] Reencoding: VID_00046 (1 of 3) - [09:39:29] Reencoding: VID_00047 (2 of 3) - [10:44:49] Reencoding: VID_00048 (3 of 3) [11:06:53]PHASE ONE complete [11:06:53]PHASE TWO - Rebuild Started - [11:06:53] Rebuilding BD file Structure [11:11:40] - Encode and Rebuild complete [11:11:40] BURNING BD structure to disc - Burn-to-disc completed successfully [11:28:49]JOB: LOGICAL_VOLUME_ID completed. [Status] LABEL=LOGICAL_VOLUME_ID VERSION=v0.18.7 (beta) SOURCE_SIZE=31690997760 SOURCE_VIDEO_SIZE=31690997760 TARGET_SIZE=4581228544 REDUCTION=.14455930288766 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all BACKUP_MODE=1 QUICK=0 PASS=0 COMPLETED=3 REBUILD_COMPLETE=1 [00046] M2TS_TARGET=2070621973 RATE=3941 AUDIO=1000000000 NSIZE=1659322368 FLINK=-1 MLINK=0 [00047] M2TS_TARGET=1833750846 RATE=3932 AUDIO=1000000000 NSIZE=1469386752 FLINK=-1 MLINK=0 [00048] M2TS_TARGET=676855725 RATE=3821 AUDIO=1000000000 NSIZE=540696576 FLINK=0 MLINK=0 Last edited by mech61; 29th January 2009 at 23:22. |
29th January 2009, 13:20 | #930 | Link |
since using the .18.07 I have been getting skipping every 2-3 seconds. It stops if you rewind/ff but starts again after the video has played for 2-3 seconds.
Odd .17 version works well. example : cars UK blu ray version .18.07 skips every 2 seconds version .17.04 absolutely fine. This is all on a uk ps3 |
29th January 2009, 13:31 | #931 | Link |
Video Maniac
Greetings Again jdobbs
I Have Successfully Encoded Pirates Of The Caribbean World's End (Australia-B) To BD-25 Using V 18.07 However I Did Notices That The Output Was Undersized Target Was BD-25
(23,000MB) Output Was (22,000MB) I Only Mention This Becuase As We All Know The More Space You Can Chew The Better The Quality... Also I Noticed Someone Else Asked For A Method Of Encoding Quicker And You Gave Them A Command To Add The Ini File... Is There A Command That Can Be Added That Will Tell BD-RB To Remux The Original Audio Tracks Instead Of Encoding Them (DTS-HD For Example) P.S. I Attached The Zip For World's End Setup Files... And Once Again For Everything! |
29th January 2009, 14:53 | #932 | Link | |
Pirates Of The Caribbean - Curse of the Black Pearl (UK region B) encoded fine using v18.07. I had a similar result with the sizing. The final size was 22GB, with 23GB set as output size. Also encoded Casino Royale (region free) ok with v18.07, however again the output was under size (21.8GB using target size of 23GB). Let me know if you need the logs. On both discs the uncompressed LPCM audio was converted to Dolby successfully. On a side note, I'm with ds9delta in being curious if there is any simple way to keep the original HD audio tracks, without you having to write the function into the software at this time? This isn't simple ( ), but i'm gonna try this temp solution... 1) Use tsMuxeR to demux the HD audio track. You can then see the HD audio file size. 2) Use BD-RB to re-encode using a custom output size of 23GB, minus the HD audio file size (i.e. 19GB, allowing for 4GB of HD audio). 3) Use tsMuxeR to mux the original HD audio (from step 1) into the BD-RB re-encoded main M2TS file, replacing the re-encoded Dolby/DTS audio. Save as a new M2TS file, giving you an M2TS of the same name containing the re-encoded video from BD-RB, the original HD audio, plus any other audio tracks and subs). 4) Delete and replace the BD-RB re-encoded main M2TS file with the new M2TS file from step 3. Thanks |
29th January 2009, 17:52 | #933 | Link | |
Video Maniac
Tried That A Couple Of Times
And Again Jdobbs For The Great Work! |
29th January 2009, 18:04 | #934 | Link | |
In a different thread, Jdobbs mentioned that he re-coded the "only movie" process from 0.17.13 to 0.18.4 so I think something happened then in the process. That is why PS3 is now skipping as many are mentioning and Denon BD-3800 is not even playing. I have both Denon/PS3 and both was working with v0.17.13 movie only / DVD-5 & DVD-9. Full movie mode is always working good in Denon nor PS3. |
29th January 2009, 21:10 | #936 | Link | |
I believe there were issues with the chapter points in earlier versions but jdobbs has sorted now. Thanks for the tip about BD-Edit. I'll have crack with v18.07 and let you know how i got on. Cheers |
29th January 2009, 22:20 | #937 | Link |
LPCM Being Encoded Even When I Tell It Not To BUG
Hello Again,
I was happy to see the LPCM bug I reported earlier as being FIXED but there's still a glitch...perhaps with the GUI. When I double-click the LPCM track to give it a red X, it encodes it anyway (even though there's an AC3 track right after it). I learned long ago that an AC3 2nd track following an LPCM is simply a 6 channel remix and the LPCM track can be trashed (until someone figures out how to encode it into a better 8 channel format). One can verify this by comparing the size of the AC3 encoded LPCM and the 2nd AC3 tracks...they're identical! Great job jdobbs, KC |
30th January 2009, 11:29 | #939 | Link | |
Did some more testing of Casino Royale last night and it appears there are a few small issues. - The menu system has no audio. This may be because i didn't include all audio. - The video that play in the background of the menu system hangs after about 5 seconds. - After you select the movie to play from the menu, just before and just after the copyright warning message plays, the image goes a light shade of grey. The grey screen last maybe 5 seconds. v18.07 was used. I'll give it another try with all audio tracks included and let you have my log files. Thanks |
30th January 2009, 15:04 | #940 | Link |
Hey guys, I just thought of an idea, since I had a couple BD-9s that was having skipping issues on PS3s, I decided to split the 7.3 GB m2ts file into two (using HDBDSplitGUI), then remuxed into a two part Bluray, then burned them to two single layer DVD+Rs.... beats putting a test remux onto a Dual Layer only to find out it still has skipping issues on a PS3...
This will see if it's an encoding problem with version 0.18.07 for the PS3s, or a remuxing error if the remux fixes the every 2 to 3 second skipping.
MBK |
