6th January 2006, 00:28 | #61 | Link |
Angel of Night
mkvmerge has the --engage native_mpeg4 flag, although of course raw->avi->mkv is no better (slightly worse...) than raw->mp4->mkv. ;_;
6th January 2006, 00:36 | #62 | Link |
clueless n00b
I've always been wondering, is there an overhead difference between VfW compatibility mode and native mode?
6th January 2006, 01:03 | #63 | Link |
Indeed there is, at least for h.264 MP4 vs. h.264 in AVI. Playback on my machine takes significantly more cpu in AVI mode, and the usage spikes are much higher. A file that plays back ok in native mode often stutters slightly in AVI mode.
6th January 2006, 08:46 | #64 | Link | |
MKVToolNix author
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
6th January 2006, 08:47 | #65 | Link | |
MKVToolNix author
6th January 2006, 20:37 | #66 | Link | |
Though using splitting/combining in mkvmerge is almost as convinient (but usually still need avi file to determine exact GOPs to reencode). |
11th January 2006, 10:31 | #67 | Link | |
HDConvertToX author
problem muxing speex file
using this string for muxing (generated by mmg)
mkvmerge.exe -o "D:\DVDMAGIC\movie.mkv" -d 1 -A -S D:\movie.mp4 -D -A -S "D:movie T01 3_2ch 384Kbps DELAY -23ms.spx" --track-order 0:1,1:0 i got this error Quote:
00000000h: 4F 67 67 53 00 02 00 00 00 00 00 00 00 00 78 71 ; OggS..........xq 00000010h: 00 00 00 00 00 00 E4 89 07 97 01 50 53 70 65 65 ; ......ä‰.—.PSpee 00000020h: 78 20 20 20 73 70 65 65 78 2D 31 2E 31 2E 36 00 ; x speex-1.1.6. 00000030h: 00 00 00 00 00 00 00 00 01 00 00 00 50 00 00 ; ............P.. Any tips ? BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
11th January 2006, 13:17 | #69 | Link |
HDConvertToX author
Ouch ...
.... so... how mux mp4 and speex in any other container ? BHH
12th January 2006, 23:48 | #71 | Link |
Mosu: any key to disable strict check on AVC streams merge? I mean when codec private data is same length but different content.
1.6.0 older builds mux everything fine, and since last build for 1.6.0 and 1.6.5 mkvmerge fails to merge those. |
13th January 2006, 08:15 | #72 | Link | |
MKVToolNix author
13th January 2006, 22:43 | #73 | Link | |
16th January 2006, 14:02 | #74 | Link |
When i create an audio file with BeSweet, using aac v2 dll, with "v5" parameter ("Dual Channels"), the infos of the generated aac are not stored correctly when i mux it in an mkv. With MatroskaProp I can see that number of channels is set to 0, and so, Haali splitter can't play the file saying that it has invalid number of channels
19th January 2006, 15:27 | #75 | Link | |
MKVToolNix author
19th January 2006, 21:17 | #76 | Link |
See both aac and mkv here :
http://lemoi.fr.free.fr/test_cod/ |
27th January 2006, 09:15 | #77 | Link | |
MKVToolNix author
Unfortunately this is way more than I'm willing to implement in mkvtoolnix. Therefore such files will never be supported properly. I might even refuse to mux them in the first place. Unless someone provides a patch for mkvtoolnix which implements this.
27th January 2006, 09:18 | #78 | Link | |
MKVToolNix author
27th January 2006, 10:26 | #79 | Link | |
27th January 2006, 13:59 | #80 | Link | |
MKVToolNix author
